Old 12-03-2005, 09:54 AM   #1
DirtyBurb86
Narcissistic Prick
DirtyBurb86's Avatar
Angry Door Won't Close Securely...
Now that it's winter time again (or, as close to winter as we get in SoCal), I busted the 'Burb out of storage and started driving it again. PROBLEM - I can't get the driver door closed all the way. The mechanism grabs and seems to go through both stages of locking, but the door still moves like 1/2 inch in and out. The rattling is driving me insane. Any suggestions on what to check out would be hugely appreciated. Thanks...
-Shawn
  • '86 GMC Suburban K2500, 3/4, 4x4, 350/400, 4" susp lift, 35" BFG M/Ts
  • '96 Oldsmobile Aurora, Pure Luxury!!!
  • '03 Mazda6 Sport, V6, 240hp Dead Stock
DirtyBurb86 is offline   Reply With Quote
Old 12-03-2005, 10:50 AM   #2
koreric75
83C10SWB
koreric75's Avatar
Re: Door Won't Close Securely...
i had the same problem on my 83 chevy, all i did was get a torx bit for the striker bolt and adjust it further in so the door would seat against the weather stripping when closed. if that doesn't help maybe some striker bolt bushings, i just wrapped black tape around the striker bolt until i got the right socket for the striker as a temp fix.
Koreric75
2003 Suburban Z-71 4x4
5.3L
83 C10 SWB FOR SALE
350ci/700Raptor Jr
Picture&Progress Page
koreric75 is offline   Reply With Quote
Old 12-03-2005, 12:23 PM   #3
SlapFish
Real Men Wear Orange
Maybe your door isn't being shut hard enough? Both my doors are like that, and it annoys me when I tell people to give the doors hell when they get in and out, and the people neglect to understand that. Now I won't take responsibility if you shatter glass and break some hinges shutting it, but perhaps the latching mechanism is somewhat stiff...
SlapFish is offline   Reply With Quote
Old 12-03-2005, 03:09 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
electrical tape (or duct tape) on the striker. Give that a shot for the ghetto cheap fix. What shape are the hinges in, cause that might be the root of the problem.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 12-03-2005, 04:23 PM   #5
ureckme
ureckmefixit2@cox.net
5/8 heater hose around the striker
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 12-03-2005, 07:20 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The strikers are available in the HELP section at auto parts stores for just a few dollars. Maybe the plastic bushing droke off of it?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-03-2005, 07:26 PM   #7
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Yup....striker bolt worn out or out of alignment. If it gets grounded down too much the door won't close right.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 12-06-2005, 04:28 AM   #8
DirtyBurb86
Narcissistic Prick
OK, the general consensus seems to be the striker/bushings. I tried wrapping electrical tape around the striker (there is no bushing), but it didn't do the trick. I'll get some new bushings from HELP! products or try the 5/8" hose if I can't find any. If that doesn't do it, I'll try adjusting the striker itself. Thanks for all the help y'all, I'd be screwed without ya. I'll report back with what works out.
Thanks again,
Shawn
Old 12-06-2005, 10:35 AM   #9
woody96
woody96's Avatar
Exclamation Re: Door Won't Close Securely...
Guys, great thread...I have the same problem.......new question about the striker bolt...if I replace it....it just screws out right? There is no nut on the inside right? Or is there?? THX!!
"Fighting for our freedoms....."
woody96 is offline   Reply With Quote
Old 12-06-2005, 10:38 AM   #10
swb85
On a budget like Fred Sanford
swb85's Avatar
There's a square hole (if I remember right) in the door jam that allows the adjustment. The striker threads into a flat metal plate "nut". You can reach behind the door jam and feel it. That's how it is on my 85 anyway.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-06-2005, 10:43 AM   #11
woody96
woody96's Avatar
So that nut is part of the door frame right?........in that I don't need to put a wrench on it to keep it still while I thread on the new striker bolt??
Old 12-06-2005, 10:49 AM   #12
Bad Karma
Magnificent bastard
Bad Karma's Avatar
It will fall into the body if you don't hold it (personal experience here ). I replaced mine with a nut, but I was able to fish out the original nut-plate thing with a magnet later on.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 12-06-2005, 10:58 AM   #13
woody96
woody96's Avatar
I am not with my truck right now----so, is this nut in plain view or do I need to get behind some trim material or something behind the door jamb???
Old 12-06-2005, 11:30 AM   #14
TrainD5115
North Coast, baby!
TrainD5115's Avatar
If you reach around behind the striker bolt you will feel the square nut that it tightens up to. As previously stated, it will fall down on the cab floor if you don't keep hold of it. To adjust the striker you only have to loosen it, move it about where you want it then snug it up. Close the door and if it shuts good, then torque it down a little.
Brad
79 Scottsdale C20
350/350
3.73's
Old 12-06-2005, 11:44 AM   #15
woody96
woody96's Avatar
Thx!!!!!!!
Old 12-06-2005, 12:41 PM   #16
Eyegore
What Hump?
Eyegore's Avatar
Great thread, thanks, I needed to adjust mine also.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-04-2023, 11:18 PM   #17
Whamp48
Junior Member
I did say 1972 C10....they don't have striker bolts.
Whamp48 is offline   Reply With Quote
Old 07-05-2023, 07:09 AM   #18
TKCR
TKCR's Avatar
Im confused. This is an 18 year old thread, but nowhere did anyone say this was for a 1972.
I would doubt that anyone would ask a question about a 72, when this is a 73-87 Thread.
TKCR is online now   Reply With Quote
