04-20-2006, 10:34 PM | #201 |
Re: Project Penicillin~ 68 crewcab build up!
To The Top
Im like a lil kid on Christmas(The Nondenominational Holiday for the politically correct) waiting to open my presents... More Pics
Always looking for a 2wd blazer |
05-03-2006, 09:10 PM | #202 |
saving one more
any updates? Please???
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
05-11-2006, 08:09 PM | #203 |
Old School, New Style
ttt
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
05-12-2006, 12:49 PM | #204 |
great work ROKCRLN, i have really enjoyed reading this thread. it has reallg gottem me thinking about my project again. i'm looking forward to finishing the mods on the frame this week.
a quick question if you don't mind. i know you have a pile of tools your using to do the mods and repairs so i was wondering if you might give us a little run down of the tools your using and possibly a a pic or two of your favorites. thanks, ondrew |
05-14-2006, 02:33 PM | #205 |
One of my kids. Cute eh?
Been awhile since we had an update. Any new progress?
Mike |
05-14-2006, 09:46 PM | #206 | |
I had to create a door pillar gap at the 4th door front edge and here is what I did for the upper gap. First I marked out what I wanted for a nice gap and then I had to cut down the door to create the space. I cut the leading edge of the window rail and in doing so I exposed the three layers of metal that make this area up. So what I had to do was cut the gap about 1/16" larger than I wanted and then stitch it back up. That is the easy part, the hard part is then grinding the welded edge to a perfect straite edge because you can not use body filler in this area. Once I had it with in a bout 1/16" I turned to a hand file for the fine tunning. This is alot of work but if you want it to look correct than you just have to do it. Kevin LFD Inc. |
05-14-2006, 09:56 PM | #207 |
Now the lower part of the door where it meets the front door had to be seamed in order to finish it off. When I built the door I ended up with a single layer of metal along the front edge. This single layer needs to be made stronger and fine tuned to create a nice gap. This was alot easier then the top edge because I did not need to worry about the over lap of metals. What I did added a wire edge to get everything how I wanted it. You start with TIG welding rod as your filler and tack it in place along the inside edge of the door to add strength and you can also adjust the wire in and out to get your gap how you want it. I started at the bottom of the door and started tacking it and bending it as I went up the door edge. Once you get it tacked then go back and start welding it all in solid by doing several passes with tack welds untill it is all linked. Then start grinding the edge down untill it is close to where it needs to be then pull out the long file and finish it up by hand to fine tune the edge. The last part I had to do was finish off the B pilar bottom between the two doors with a small cap. Now that this is done I think I am finished with the drivers side and will start the passenger side this week.
Kevin LFD inc. |
05-15-2006, 01:14 AM | #208 |
Lovin' Life in Miss.!
Tomatocity talked about you alot. (All good) Feel bad I never made it over your way before I moved. I don't think I would have said anything though. I would have wanted to just watch.
Thanks for sharing this with us.
The truck... you hear that? No really, you did hear that?!!! |
05-15-2006, 01:31 PM | #209 | |
05-15-2006, 03:22 PM | #210 |
Licensed to Thrill!
Wow.
Just...wow. |
05-15-2006, 03:33 PM | #211 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-15-2006, 04:05 PM | #212 |
It's ok to stare...
Just too We need to have a nothern Cali mini meet when this thing is done.
05-15-2006, 08:00 PM | #213 |
I think I have enough truck to make a mini meet at my house, ask my neighbors, they will agree. They seem to follow me home. I can only keep so many before I had to turn them away, but I still have room at my daughter's house.
05-15-2006, 08:05 PM | #214 |
not to be a cridical a=hole, i know you didn't do the roof but do you have plans on staightening the skin? it looks prety flat in the rear in comparisom to the front
common sense isn't so common anymore |
05-15-2006, 08:36 PM | #215 | |
Kevin LFD Inc. Last edited by Rokcrln; 05-15-2006 at 08:46 PM. |
05-15-2006, 08:44 PM | #216 |
Here is th ework for the night. I removed the cab corner and most of the 3rd door rocker and it was not as bad as I thought it would be. The metal is in decent shape and the lower "C" post was in fact their. When we felt inside the cab corner before it felt as if it was chopped out with an Axe. In fact what they did was cut off the Truck lower post an dthe upper Burb post and then over layed them. I will keep this part as is even know we have a new piece for it, I just do not see any reason to replace it. As you can see in the last Pic the bottom of the "B" post is mostly gone and the PO covered it all up with fiber glass so we did not see it untill this project was under way. I need to fix this area before removing the rest of the rocker then I will replace the 3rd door rocker and inner. After that is done I will brace the sh!t out of the windshield and dash area before I remove the entire windshield post due to rust. After it all back inplace I will finish up the front rocker.
Kevin LFD Inc. |
05-15-2006, 11:10 PM | #217 |
Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
05-15-2006, 11:20 PM | #218 |
your workmenship is incredable and it's amazing what you get done ine your spare time. it seems when i'm working nothing at all gets done at home on my truck or anything else
05-15-2006, 11:50 PM | #219 |
As long as I am alone I get alot done. Also my head has to be into what I am doing otherwise I go no were!
Kevin LFD Inc. |
05-16-2006, 09:26 AM | #220 |
looking good
05-16-2006, 11:48 AM | #221 | |
Licensed to Thrill!
05-16-2006, 08:20 PM | #222 |
Ok the rear rocker and cab corner will be ready to go back in once this stuff dries. I finished trimming everything away back to good (well better) metal and than coated the sh!t out of everything with a rust inhibitor product I am trying out. I even got way up in side the rear cab suport with this stuff. It is suposed to convert rust into a none rust somthing or other. You can weld right over it or paint over it as well. It goes on like Elmers glue but dries to a black finish. Thursday I should have the B pillar finished and start getting the 3rd rocker and corner in place. While I am doing the corner and rocker I think I will tweak things abit to get the door to fit right at the bottom. I don't know what it is but almost every Burb that I have seen has the same problem as this one does. The bottom rear of the door below the body line sticks out past the door jamb just a bit. This one was worse than most so now is the time to correct that. Also I had to cut the bottom of the B pillar open inside the rocker in order to get out all the durt and rust that has bult up over the years. It was packed solid and I had to jab and pry some of it out but it is now nice and clean.
Kevin LFD Inc. Last edited by Rokcrln; 05-16-2006 at 08:23 PM. |
05-16-2006, 11:29 PM | #223 |
Rockrln, I know what you mean about welding up door edges. I did the same thing to all of the gaps on a 67 shelby gt 500 that the customer wanted better than new. I also hand filed all of the gaps to match all the way around the door. I also did that with all of the fiberglass and scoops on the car. Lots of fun. Nice job on this one.
05-17-2006, 03:16 AM | #224 |
More and more miracle work with a hammer, and a welder
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
05-18-2006, 09:24 PM | #225 |
Had some time tonight to get the rear cab corner welded in and lined up with the door body line. I am not sure what was off but with the top body line alined the bottom one was about 3/8" to low. The corner was not replaced before but the truck cab could have been just a bit off from the burb door opening so I adjusted things before welding. I also brought the corner profile in line with the door since the door also did not line up that way! Next will be the rear rocker and "B" post bottom repair. I left the edge of the corner that wraps around the jamp un welded for now until the rocker is ready to weld incase I need to tweek things abit.
Kevin LFD Inc. |
