Old 03-22-2002, 04:00 PM   #1
Cal69Chevy
Cal69Chevy's Avatar
Post Acceleration problems...HELP!
I have a '69 with a crate 350 with not more than 5,000 miles. It has the original Qjet and a TurboTrans 400. It's a daily driver and has been very dependable and smooth running. The trans shifts smooth and the engine is strong.
Just yesterday it started to hesitate off idle. It sounds like the engine sputters off idle and then finally kicks in. However, in neutral and park I can rev it slow or quicly off idle and it runs fine (no sputtering).
What are some of the possibilities and how do I determine which of these possibilities is the likely the cause?
Thanks in advance for any help.
Ken
'69 Chevy, 4X4-SB 350 TBI-TH350 Trans-205 Transfer Case-Dana 44 Front-14 Bolt Rear-Front Disc Brakes-Factory A/C-P/S
Ken's '69 Page
Cal69Chevy is offline   Reply With Quote
Old 03-22-2002, 04:55 PM   #2
67Blacksheep
Post
Cal 69-
I'm in a similiar boat. Strange animals when your actually trying to move, huh? I have a Holley 750 on mine. I have pretty much narrowed it down to the power valve. For yours, you could be looking at a minor carb problem in the transition between idle and acceleration. Have you tried re-building the carb? Or running a high test gas? I once got some really poor pump gas and it caused havock until I ran it out. Good Luck!
'94 GMC Seirra Ext. Cab
'67 Formula Firebird
'89 GSX-R 750
67Blacksheep is offline   Reply With Quote
Old 03-22-2002, 05:07 PM   #3
Gordo
Talking
Take a look at the accelerator pump,,,should see a nice squirt in the primaries when you move to WOT (engine off please), if not, rebuild time. If you have points (check dwell) and/or HEI check your advance also.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 03-22-2002, 05:14 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Also good indication of a plug starting to fowl, or a plug wire that got burned and is shorting out.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-22-2002, 07:08 PM   #5
Cal69Chevy
Cal69Chevy's Avatar
Post
So these suggestions would still apply even if it doesn't happen in park/neutal? I can go from idle to 3000 RPM's slow or quick and it doesn't stumble...only seems to stumble when in gear.
Ken's '69 Page
Old 03-22-2002, 08:38 PM   #6
bigjimzlll
bigjimzlll's Avatar
Post
do you have a vacuum gauge? sounds like a carb stumble or advance prob..a vacuum gauge can help narrow it down.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-22-2002, 09:06 PM   #7
Gordo
Talking
10-4
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1951 Wife
