Old 11-20-2006, 10:50 PM   #26
89 crew
Re: This is pathetic. What's broke?
I would start by checking the electrical, rotor, coil, wires, we are dealing with a 454 they have enough ponies you can loose a bunch and not notice them without a big load. you might try putting a load on it and see if it tells you more. If those are ok, I would then do compression check.
89 crew is offline   Reply With Quote
Old 11-21-2006, 10:37 AM   #27
EDOUBLE33
Active Member
EDOUBLE33's Avatar
3.33 mile to the gallon sucks.
EDOUBLE33 is offline   Reply With Quote
Old 11-21-2006, 11:10 AM   #28
magnethead
7000 #'s of american IRON
magnethead's Avatar
Originally Posted by lurch115 View Post
not knowing how many miles are on it...i would investigate more towards the cam....just had to put a new cam in a friend's truck....his gas mileage went to crap so he parked the truck for a couple of weeks....started it back up and it was misfiring out of one cylinder.....after pulling the valve covers we found a flat lobe on the cam....and after pulling the cam found several worn down lobes.....put a Lunati RV2 cam in and now that thing gets good milage and can pull like no other.....another reason why i say it could be cam related is from timing chain wear...valves not opening close enough to the right time will have a big effect on milage
This is something i repeatedly keep coming back to. As many stress miles are on this motor, i'm not doubting that the valve lash, valve overlap, valve extension, and valve timing are pretty far off. I can tell from the exhaust note that the cam is on it's last straw, it sounds closer to a single cylinder flathead than it does a V8. We don't know how many miles are on it either. How much is the lunati? An RV cam is what i'm looking for, bring up the powerband from 500/1000-4,000 RPM for more ttorque..If i can get torque, throw horsepower out the door.
enough ponies? It's only a 250 horse, torque is where it's at. I guess that'll give me something to do today, pull a few plugs and pop the dizzy cap.
magnethead is offline   Reply With Quote
Old 11-21-2006, 11:24 AM   #29
magnethead
magnethead's Avatar
just checking, these are KITS, correct? It says includes lifters, are they 1.5 or 1.6 lifters?
Jegs #'s
638-60200LK
638-60201LK
270-133904
270-133934
Old 11-21-2006, 11:32 AM   #30
piecesparts
Parts and more parts
piecesparts's Avatar
1) Look at the choke being closed when it should be open.
2) Look at the oil for saturation of fuel into it, could be a float is sticking the carb.
3) Look at the tank for any leakage.
4) Check the motor for a good tune and operation.
Old 11-21-2006, 11:38 AM   #31
magnethead
magnethead's Avatar
I'm just about to switch this thing to manual choke...i've been battling it for a year, replaced the stat coil, just can't get it to work right. I'll check if it's opening sometime, may put a default-to-open return spring on it if i have to. The tank isn't leaking, and i'm going to go over the motor today.
Old 11-21-2006, 11:58 AM   #32
magnethead
magnethead's Avatar
how well named...the title says "what's broke?"
the answer: the clip that holds the rod from the choke stat to the choke lever..so the choke was flapping around as it pleased, the rod was just sitting there hooked to nothing.
Old 11-21-2006, 12:10 PM   #33
magnethead
magnethead's Avatar
Just pulled the #2 plug, its gapped at 45 and is thoroughly tan, that's a good A/F ratio, right?
Hardly any carbon buildup, it looks by my guide like it's somewhere between normal and high speed glazing.
Old 11-21-2006, 01:35 PM   #34
magnethead
magnethead's Avatar
ok, so i made about 4 trips walking around my truck with a rubber mallet. Who wants to guess how much of what was on the ground when i moved the truck afterwards?
Old 11-21-2006, 03:30 PM   #35
84 400
Sb 400 club
84 400's Avatar
i know that feeling man my old 85 was really bad abpout leaving parts behind
i used to hit the frame with a sledge lightly and listen as a ton of flakes fell on the ground ahhh well
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-21-2006, 08:30 PM   #36
magnethead
magnethead's Avatar
actually in this case, it was 5 gallons/60 pounds of mud and tar (our road just got paved).
Old 11-21-2006, 11:53 PM   #37
7387chevys
sounds fun
7387chevys is offline   Reply With Quote
Old 11-22-2006, 12:45 AM   #38
magnethead
magnethead's Avatar
I fixed the choke lever, looked in my box of wiring and made myself a 1" length of bare 22AWG solid copper wire. Bent it around the groove twice, made it tight with pliers, and i don't think it'll go far.
All that mud (very little was actually tar) had been there for a very long time, so i should be down from 6680 to 6620 or even 6600 pounds even.
Also, i found another mileage culprit: the aircleaner. Apparently is till have an OE replacement paper element- i cranked the air compressor to 60 PSI output and held the nozzle straight to the paper, i couldn't hardly feel anything directl across the element from the nozzle. Is that restricting or what?
