Old 05-01-2002, 05:43 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Post Frame Replacement Bolts
I have a couple of crossmembers that I am replacing tonight and will need nuts and bolts to replace the old rivet. What size diameter are those rivet holes and what strength bolt is recommended?
2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it
1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-01-2002, 05:47 PM   #2
69 longhorn
Post
the rivet holes are probably 3/8. I have replaced anything that was out of the longhorn with 7/16 grade 8 hardware& pinch lock nuts.......69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-01-2002, 05:50 PM   #3
1971Stepside
Almost Satisfied
Post
Sorry 69 to be dense. Should I go with the 3/8 or the 7/16? I live a ways from the hardware store and don't want to make a second trip if possible. Any help would be greatly appreciated.
Old 05-01-2002, 06:06 PM   #4
69 longhorn
Post
My goof,I should have stated that I drilled the hole oversized to fit the 7/16 bolts. Im guessin trans crossmember,& farther back...69
Old 05-01-2002, 06:38 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Post
I replaced over 60 rivets on my 4x4 frame. I ground a flat spot on the rivet head. Then center punched them. Drilled them with a 1/8 drill about a 1/4 or so deep. Then drilled them with a 3/8 drill the same depth. I didnt want to oval out the hole. Then i took a chizle ond knocked the head off and punched the rivet out..After that i drilled all the holes out at 7/16 because a 7/16-20 bolt measures .429 to .431 and i wanted them to fit tight like a rivet. Then i sand blasted everything and painted it. When i assembled everything i put a flat washer on both sides and put red locktight in the bolt and torqued em down. I can't remember the torque speck.. The bolts were 7/16-20x1" long grade 8.....
Randy
72 k/10 short wideside
72 k/5 Blazer
72 custom/10 8' bed
69 c/10 8' bed
71 k/5......rusty!! IT WENT TO THE SCRAP YARD
72 custom/10 short stepside
70 C-30 Longhorn, its Longhornmail's now.
70 K-5 Blazer
chester county pennsylvania
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 05-02-2002, 01:31 AM   #6
Duallie
Duallie's Avatar
Post
For critical frame bolts (like suspension and crossmembers) I like to use lugstuds PRESSED into a reamed-to-fit hole and cinched down with a lubricated nylock nut. Looks just like a rivet on the outside, and splined and pressed in for immobility. I have been known to use old studs from whatever old suspension I have layin' around, but new is good, too. Use a generic GM stud from a malibu, for instance.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 05-02-2002, 08:57 AM   #7
1971Stepside
Almost Satisfied
Post
Thanks for all your help. I got some 3/8 grade 8 3/4" Bolts and they fit the holes perfect and were just the right length. Replacing the first crossmember (in front of the engine) was a job! But, I won in the end.
My truck was a manual to begin with years ago and after I got the cab off the frame I found the new auto trans crossmember only had two bolts holding it in the frame!!! That has been corrected!!
Old 05-03-2002, 11:25 PM   #8
sevenwonder
Post
Lug bolts sounds like a good ideal. I'm going to cheak that out myself. If using bolts be sure to use grade 8.
70 short,step on a 72 frame.
sevenwonder is offline   Reply With Quote
Old 05-06-2002, 08:24 AM   #9
MOTHERTRUCKERS
Post
grade 8 has a better clamping strength but a lower shear strength, grade 5 is the recommended bolt to use for frames that flex.
www.mothertruckers.net
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
