Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-01-2007, 07:48 PM   #1
Frizzle Fry
Frizzle Fry's Avatar
My Factory AM Radio is now mp3 Compatible!
I’m the type that likes the look of a stock dash and radio but wants a modern sound system. A few weeks ago I bought a Rockford Fosgate Omnifi mp3 player. It’s basically a 20gig hard drive based system (easily upgradeable to 120gig) that allows you to transfer mp3s from your computer to your car via USB or optional wireless (which I have).
I had planned to run it stand-alone directly to my cross-over/amps, but I soon found out that it has no built in pre-amp, so no volume control. My existing 10+ year old CD player had no audio inputs either (the way the Omnifi was designed to be installed). I looked at the USA-1thru6 options, but didn’t really want a new deck.
I decided that all really needed to run this thing stand-alone was some sort of volume control capability and power antenna signal. So I did a little google’ing and found info on in-line RCA volume control. A trip to Radio Shack and I was ready to do a little radio surgery.
I picked up some 0-10k ohm potentiometers and surface-mountable RCA jacks. I later discovered that 0-10k was insufficient and went to 0-1M ohm. The 0-10k pots only adjusted volume from 100% down to about 90%. The 0-1M pots adjust volume from 100% down to about 5% (plenty low). A further improvement may be possible using this configuration. My setup works just fine, though it does get a little touchy/sensitive near full volume, meaning a little adjustment goes a long way in volume. But it's not enough to be an issue.
When you remove the covers from the radio you can see there is plenty of room to do this. Just take out a few components behind the volume knob. I didn’t use nor did I plan to use the radio as an actual AM radio.
The existing volume/tone knob has two pots (two are required for stereo volume control) so at first glance I thought this was going to be easier than expected. But they are not matched and are the wrong specs for the job. But the amazing thing is that the annulus (resistive disc - more info here), is nearly identical in size/shape from stock to new. A little clearancing on the new ones and they fit perfectly.
Frizzle Fry is offline   Reply With Quote
Old 03-01-2007, 07:54 PM   #2
Frizzle Fry
Re: My Factory AM Radio is now mp3 Compatible!
Now, the other thing I learned is that the stock sweepers don’t work very well with the new annuluses. They look like they will but when I tested them in this configuration there were open spots in the volume range. So, tried gluing the new sweepers onto the stock sweeper discs. That seemed to work ok, but when I went to the 1M pots I decided to use the new sweepers AND their plastic discs. I did this because the centering of the sweeper on the annulus and shaft is critical. I just drilled holes in the center of the black plastic sweeper discs to fit them over the shafts.
Old 03-01-2007, 08:01 PM   #3
Frizzle Fry
Drilled holes and mounted the RCA jacks. I would move them forward or to the bottom of the deck if I had it to do over because they are pretty close to the wiper motor as is.
Another great thing about the stock pot housing is that it has a built in switch. This was the main reason I chose to stick with the stock pot housing instead of trying to find a compatible dual-gang pot. I wired the switch up to the existing power jack in the back of the radio. So two of the spades in that jack are now used for power antenna (on/off signal to the crossover, amps, and mp3 player), and the other spade is now connected to the internal light. I later wired the radio light to the dash light circuit so it will be on/off/dim with those. You could wire it to the knob switch if you want it to switch on/off with your system, but I like the back lighting on and dimmable even when the system is off.
Old 03-01-2007, 08:06 PM   #4
SactoJim
SactoJim's Avatar
Holy Crap....what are you..a rocket scientist!
That's impressive and a little (way) beyond me!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-01-2007, 08:13 PM   #5
Frizzle Fry
I left the tuning mechanism alone so the kids can sill push the preset buttons and watch the needle move all day long. But you could build a balance/fader knob on that side if you wanted using the same technique and simply wiring one pot inversely as is also explained here.
I installed a new bulb while I was in there (also put all new bulbs in the rest of the dash).
This set-up would work for any audio device that is designed to be run through AUX inputs in a deck and has its own control interface.
Here it is installed. The faceplate is pretty thin and could be mounted anywhere, but it's going here for now (hot glued on so it's easily reversible).
Next install; my new covered fiberglass kick panels thanks to this FAQ
Old 03-01-2007, 08:23 PM   #6
67arch
WTB:Patience and Talent
67arch's Avatar
Nice post!! That is exactly what I would like to do.
69 shortwide
67arch is offline   Reply With Quote
Old 03-01-2007, 08:26 PM   #7
sdkid
That is so cool. I'm not sure I'm that smart for this though. It also needs to be moved to the FAQ forum.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 03-01-2007, 08:28 PM   #8
jaros44sr
jaros44sr's Avatar
I'm alittle old, well make that a lot old, but what is mp3. Your work is impressive even tho I don't know what you said. I'll have to go back and reread it. That is awesome to see it look stock. Congrats on your success... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-01-2007, 08:53 PM   #9
jimmydean
jimmydean's Avatar
Nice work indeed!
I was going to get the OmniFi setup until I saw the limitations and the price. One thing let to another and I am now planning a system around a Mac Mini. I will do it in stages, I still need to modify the dash to accommodate the screen,
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-01-2007, 08:59 PM   #10
You`re a frickin`genius Frizzle Fry.Shoot me your address.I`m sending 1/2 dozen radios your way. That`s great!
Old 03-01-2007, 10:35 PM   #11
Frizzle Fry
Thanks guys. The basic idea was pretty simple, but making it work the way I wanted it to using some of the factory parts took a little trial and error. Now that it's all figured out it would be cake to do again. I just wired up the radio back light today so I went outside a few minutes ago to check it out after sun down and it looks great
I think I'll move the Omnifi face-plate somewhere else in the future and put the ashtray back, but for now this works.
You could run a stand-alone CD changer or HD-Radio unit this way too.
Here's a link for jaros http://en.wikipedia.org/wiki/Mp3
Old 03-01-2007, 10:46 PM   #12
cdowns
cdowns's Avatar
will it play 8-tracks??
Old 03-01-2007, 11:22 PM   #13
flatheadnut0
New Member
That's the coolest thing I ever saw. How the hell did you come up with that?
flatheadnut0 is offline   Reply With Quote
Old 03-02-2007, 12:22 AM   #14
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
that's awesome.
IvelDesigns is offline   Reply With Quote
Old 03-02-2007, 12:25 AM   #15
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
holy crap man!! this is awsome!!
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-02-2007, 02:13 AM   #16
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 03-02-2007, 07:36 AM   #17
jaros44sr
jaros44sr's Avatar
Thanks Fry, but that was way to much info. Are you saying it plays CD's? Your work is way too cooool! Wish I knew what you were talking about.... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 03-02-2007, 10:11 AM   #18
oj70chevy
250 V-6 Club
oj70chevy's Avatar
that is awsome. I see this going to the FAQ!
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 03-02-2007, 10:20 AM   #19
Yukon Jack
Yukon Jack's Avatar
Incredible . . . just incredible. You could surely make some money marketing these conversions!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-02-2007, 05:03 PM   #20
gmc1969custom
Very, Very Impressive!!!!
1969 Custom w/Turquoise Interior. 75k miles, 350 Auto, (Almost) All Original
gmc1969custom is offline   Reply With Quote
Old 03-02-2007, 05:15 PM   #21
Orange
Licensed to Thrill!
Orange's Avatar
Very impressive. I have a factory AM radio. I may do something with it someday.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-02-2007, 05:17 PM   #22
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Frizzle,you do realize this is a great mod but probably only a few on here are 'lectronically literate.This is a great write up and pics for a FAQ,maybe it should be used as a template for them.You should look at posting it on an audio forum or maybe selling it to them as a mod from stockers.
BTW my TV wont work do you do house calls.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-02-2007, 05:37 PM   #23
grant's72
grant's72's Avatar
could I plug a i-pod in to that and have it work
grant's72 is offline   Reply With Quote
Old 03-02-2007, 06:35 PM   #24
Frizzle Fry
Yep, with the iPod RCA adapter. All this mod does is give you the ability to adjust line level into your amp or crossover (and on/off). So anything that puts out an analog audio signal can be run through it. The best iPod RCA adapter is the one that runs from the bottom port, not the headphone jack. You can get this type with RCA out and charge capability.
Old 03-02-2007, 06:49 PM   #25
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
You should try using audio or log tapered pots for volume controls, instead of linear. This will give you the "normal" control you expect from a volume control.
Neat setup. A lot of AA5 tube radios in the 60's had a "fader" arrangement for plugging in a phono; with nothing plugged in, the volume control worked as normal, but, with a audio sourse plugged in, and the radio tuned to an empty spot on the dial, the knob was used opposite of normal (full clockwise was min. volume). I have thought of modifiying my truck's stock radio this way so I can still use it as an AM radio. I know it wouldn't be stereo, but I could mix both channels together with two 1K resistors and get true mono from any stereo source. It wouldn't be hifi, either, but that's why I got a nice amp at home.
Anyway, nice job!!!!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
