SWB vs. LWB
What is the length of the SWB vs. the LWB?
What is a c10 8' bed - is this a lwb or swb? Thanks. |
SWB & LWB refer to the wheel base.
115 inches = SWB = Short Wheel Base (OAL -bumper to bumper = 188 1/2") 127 inches = LWB = Long Wheel Base (OAL - bumper to bumper = 207 3/4") (wheel base is measured from centerline of front wheel to centerline of rear wheel) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ If you are reffering to the length of the BED Shortbed Stepside = 78 1/4 inches long X 50 inches wide Longbed Stepside = 98 inches long X 50 inches wide Shortbed Fleetside = 78 1/4 inches long X 66 inches wide (width measured at inside of top lip) Longbed Fleetside = 98 inches long X 66 inches wide (width measured at inside of top lip) The 8 foot bed would be a longbed... hope this helps... ![]() Last edited by Shane; 12-03-2002 at 05:28 PM. |
Also, you've got a *Longhorn* it is longer than a long bed, it has an additional 6" to the front of the bed and 6" added to the frame in that place. Which would make it a total of 133". Is that one right Longhornmail???
Brandon |
Fabricate till you "puke"
That right on Brabra......the other longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
its all about the +6 inches
Yep...and of course there is the one ton step side...with a 9 foot bed.
