I have some slop in the coupler on the steering column. This is the piece under the hood about a 1/3 of the way down the column. One half of the shaft slides into the other with a couple of bits and pieces inside. It's the piece just after the spring.
Ugh I hope this explanation helps cause it sounds like a mess to me ![]() I took the truck to the alignment shop and they called with a list of pieces to fix before I bring it back to actually get it aligned. Thanks for any help Terry
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's |
I believe what you are refering to is called the steering shaft extension, and it is an assembly from the upper shaft to the rag joint. I would try posting on the parts board and someone should be able to help you.
Jim |
