![]() Join Date: Dec 1999
How should i smooth out my bouncy rear?
ive got my coils in the back cut/heated to give me about a 5-6" drop. but im getting spoiled now and want a smoother ride, it bounces like no other. whats the best way lower the back? just drop coils? i was thinking about putting air bags back there but at a standard pressure, and not messin with all that air up, air down stuff. cuz i know those are a smooth right
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
Almost Satisfied
![]() Join Date: Mar 2002
treadmill! Sorry, couldn't resist
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Getting cabin fever?!?!?!
damn you beat me to it!! 6 inch drop coils with some good shocks should help immensely
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
What if?
uh buns of steel video?
67-72 Addict!
Liposuction, baby!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Loose 30 lbs~~~~~may as well keep it up (so to speak)!
You could use some blocks under the axle to lower it.
Member since 2000
while your at it 15min abs.........try air shocks
Fabricate till you "puke"
Umm.....walk slower & it wont bounce so hard!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
definately set myself up for that one. thanx a lot guys, i dont think my truck would really appreciate you guys crackin jokes at her expence! guess i do need to get out more though, i am gettin kinda jiggly, lol.
now how exactly is this block installed? any pics?
Try this link on installation.... http://www.classicperform.com/goingdown6772.htm
This is a funny post.
Build Thread |
thanx for the link. thatll help a lot when im ready to switch over.
ps-ive been squeezin in a jog here and there to control the bouncing until then
Old Skool Club
![]() Join Date: Jun 2001
So, heating your rear end (I mean the rear coil springs) will cause it to bounce?
I have lowered mine 4-inches in the rear, and have an adjustable rear track bar, relocated shock mounts and shorter shocks. Of course, my springs were designed to be lower, but relocating the shocks and using shorter ones will help a bunch. The adjustable track bar, or maybe cutting/welding yours to keep the rear end centered thoughout its' working range (don't we like to see those bouncy rear ends stay centered?) will help greatly, but will still bounce more because the heating affected the tensile strenth of the springs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 |
i lowered my truck about 5 inches by heating the springs. i had alot of bounce also. i bought a set of shocks that were about 3 inches shorter and that helped. i talked to a guy at napa and he helped me find the shocks. funny they were shocks that go on a 4x4.
