06-24-2007, 10:15 PM | #1 |
SBC 350 oil pressure, how much is too much ?
I've got a realtively-new-to-me 350v8 from a GMC C20 camper special, now in a 64 Chevy C10. The 350 has (allegedly) about 35K miles on a rebuild, but that rebuild was two PO's ago, and I have no facts, no idea what was put in there. I will say though, it seems to run clean and strong.
I'm using the original stock oilt pressure gauge in the C10, I believe it is working. With the worn out 230L6 that came out, oil pressure would range from 0 to 20 psi or so. The range on the gauge is 0 to 60, and this 350 pegs it at 60 on cold start, so maybe it is actually higher. After five minutes of warmup, it goes down to 30 psi at idle, up to about 45 psi at what I'de guess is 2000 RPM or maybe a little more (no tachometer, so guessing at gentle throttle cruise 35 mpg or so). At freeway speeds it is up to near 60 again. This seems like a lot, but then again I am used to old worn out stuff. Should I be happy with this pressue or is it too much, going to cause some problem? |
06-24-2007, 10:43 PM | #2 |
Re: SBC 350 oil pressure, how much is too much ?
That sounds like a tight engine, no problem. New bearings with tight clearances will give a high pressure reading.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-24-2007, 10:51 PM | #3 |
all sounds well to me. buy a gauge that reads 80lbs on the high side..
and don't use fram filters u will be just fine.. |
06-24-2007, 11:27 PM | #4 |
That's a relief, thanks guys.
So if it pegs an 80 psi gauge, then that would be too much? And what would be the best filter to be getting? I used Purolator in the old 230L6, because that it what the closest place that sold filters had. But I want to treat this "new" engine to the best. I have no hot rodder history (vintage MX guy here) and am a complete newby to SBC350 care and feeding. |
06-24-2007, 11:48 PM | #5 |
GEARHEAD
I agree with the others your oil pressure sounds just fine to me.
BTW I recommend WIX filters or NAPA Gold witch is a WIX filter. RJ22...
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! Last edited by RACINJASON22; 06-24-2007 at 11:49 PM. |
06-25-2007, 10:50 PM | #6 | |
NAPA Gold #1061 Wix #51061
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
07-03-2007, 01:10 AM | #7 |
MOTORHEAD!
Not to steal yer post or anything, but mine will hit 80 psi when it is cold and you tromp on it, maintains about 45 at 2500rpm cruising, and drops to about 25 when idling and hot, does this sound okay???
910
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
07-03-2007, 04:35 PM | #8 |
+1 on Fram filters being trash.
Carquest also brands those WIX filters as their own. It's part # B4631. You can also ask for the fleet pack of them with 12(i think) in a single box, which is cheaper since they are just wrapped in plastic instead of individually boxed. |
07-03-2007, 04:47 PM | #9 |
Thanks for the Carquest #B4631 tip.
What is it about Fram that's gotten the wrath of y'all? I would have thought that was a good name brand, but then one has to watch out for "name brand", I know. Like Volvos made by Ford, some things just ain't like they used to be. |
07-03-2007, 06:25 PM | #10 |
GEARHEAD
rickf do a search on here about FRAM filters and you will find some good readings about why not to use FRAM filters.
They have went down hill alot over the years. I still like there HP line of filters but IMO that is as far as I will go with them and, I most of the time pick over them when I can get K&N oil filters in advance to when I need them. RJ22... |
08-24-2007, 11:03 PM | #11 |
Hey Pyro, great tip on the filters. The part number for one of the plastic wrapped ones is a B4631MP. However, these are Purolator filters. All of the Carquest brand filters in the red box with the "B" part number designation are Purolators.
They all beat fram! |
08-24-2007, 11:04 PM | #12 |
Wow, just noticed I dug up an old post...sorry!
08-27-2007, 10:15 AM | #13 |
How about great pressure at start up and road speeds, but very low at idle 10-15 lbs. tops! The motor is still in the "break in" stages of it's life, only has about 250 miles on the thing. Should I be concerned or buy another aftermarket gauge? The worn out 350 that came out of it did the same thing at idle.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd Last edited by OLDIRON69; 08-27-2007 at 10:16 AM. |
08-27-2007, 10:49 AM | #14 |
Spanked once
You may want to start a new thread on that Old Iron , That pressure should concern you at 250 mi.
08-27-2007, 11:10 AM | #15 |
Thanks Richard..
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
08-27-2007, 12:50 PM | #16 | |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
08-27-2007, 02:15 PM | #17 |
I forgot to mention..in drive, sitting at a stop sign the gauge (aftermarket tri gauge set) will drop to almost NOTHING. I'm tempted to hook the factory oil pressure gauge back up and throw the triple gauge set up as far as I can. I trust the origional 40+ yr old gauge more!
NICE 65 BTW!!!!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd Last edited by OLDIRON69; 08-27-2007 at 02:16 PM. |
08-27-2007, 02:51 PM | #18 |
Dirteh Kitteh
Heh, my old '81 with 335,000 original miles gets 15psi no matter what. It doesn't matter if it's cold 50W at shift point or VERY hot 5W30 at idle.
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD Sign up with the Contact List RIP ESLL |
08-27-2007, 03:51 PM | #19 |
I've always heard that about 10 psi per 1000 rpm is fine and a small block will live all day long on minimal oil pressure (less than 10 psi) at idle.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
08-27-2007, 04:51 PM | #20 |
a lot of small block chevies will go as low as 5 or 6 psi at idle and live a very long time. i know mine does and has forever. will peg the guage out at cold startup then after a hard highway run will idle between 5 and 10 psi. i have seen the same thing with countless small blocks that never had any issues
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-27-2007, 09:50 PM | #21 |
This is what I have been taught as well. If you are running at 5000rpm you should have 50psi. If you are idling at 800rpm you need 8 psi. I had a 70 El Camino that had those readings. The bearing were obviously worn but it ran fine. The more steady the oil pressure the better, it would be ideal if you had 50 all the time, but if you have 60 cold and 25 when it is hot I would say it is a good motor.
