Old 09-13-2007, 10:05 PM   #1
Ironhorse
Ironhorse's Avatar
' 99 Tahoe Oil Change
Just got done changing the oil on our ' 99 Tahoe and talk about PITA engineering !! No problem with the pan/bolt, 5.7 (350 CI) motor but the oil filter postioning leaves a lot to be desired. Tahoe is a 4WD sitting on 265/75/16's (which are to small and will be changed when they wear out to a decent size for a 4WD vehicle) but with the juice can size oil filter about 3" above the transfer case and sitting at a 45 degree angle I can't say much about GM engineering here. What happened to the 30 plus years of the filter hanging straight down on the driver's side of the block, what was wrong with that? I've been changing oil on my own vehicle's for close to (never mind, just a long time now) and this thing is a pain. Front drive shaft u-joints should never have a rust problem for sure. Just venting I guess, I like the vehicle but changing the oil is not what it used to be.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-03-2007, 03:23 PM   #2
Joe67
67 is sold
Re: ' 99 Tahoe Oil Change
I never had any trouble changing the oil on my 1997 or 1998 5.7l trucks
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-08-2007, 10:24 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
That's weird! I've changed the oil in a 96 Z71 and a 00 Z71 (5.7L and 5.3L) trucks and the filter hangs straight down. I wonder why the tahoe would be different?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-08-2007, 06:30 PM   #4
Ironhorse
Ironhorse's Avatar
Not sure of the reason why but sure does s**k big time when it comes time to change oil/filter. Guess maybe perhaps the shorter wheel base on the Tahoe vrs. pickups?
Wellington, Ks
Old 10-09-2007, 10:23 PM   #5
centsless
sufficiently talented fool
centsless's Avatar
All of the 3/4 and 1 ton pickups that we service for the county here have the filter above the driveshaft. I never had any problem changing them, but you are right about the u-joints staying well lubricated...
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-15-2007, 09:06 PM   #6
DavesRide
DavesRide's Avatar
That is the older body style "old school" Tahoe body style. I very successfully removed many a delco filter with my trusty Snap-On filter socket and a swivel headed ratchet. You ought to see how the newer Heavy duty truck models drain onto exhaust and splatter everywhere. Now that it has been mentioned, I have never had to replace a u-joint in that position.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 10-18-2007, 05:00 AM   #7
99-2door
99-2door's Avatar
The distance of the engine/trans/transfer case to the front diff doesn't change no matter what the wheelbase.
2wds have the larger diameter filter hanging straight down while the 4x4s have the smaller one and the adapter that makes it 90 degree to clear the drive shaft. You can take the adapter off and use a short larger diameter filter, but not if you want to keep the external cooler.
Just put a piece of card board on the shaft so that the oil drains into your pan.
and 99 Tahoe stuff should really go in the 88-98 section.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 10-18-2007, 10:36 AM   #8
TDs6t9
TDs6t9's Avatar
My '99 Z71 with the 5.3 hangs straight down also. It is an extended cab short box, but that shouldn't make a difference. Mine is the newer body style. Maybe a difference there. Just a thought
TDs6t9 is offline   Reply With Quote
Old 10-18-2007, 04:20 PM   #9
TDs6t9
TDs6t9's Avatar
Thumbs down Re: ' 99 Tahoe Oil Change
Hey 99-2dr, May I ask why '99 Tahoe should go to the 88-98 section?
Just curious. Have a good one.
Old 10-18-2007, 09:00 PM   #10
DavesRide
DavesRide's Avatar
Totally different. According to the post his truck does fit here by date but you guys are correct, he would have much more info pertaining to his Tahoe on the earlier Gen post. The Tahoes and trucks come in both forms in 99.
Old 11-08-2007, 12:31 PM   #11
truckdude239
truckdude239's Avatar
i change oil in them everyday never had any problems, but then again i got lifts
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-03-2007, 02:39 PM   #12
WLPTMP
Active Member
WLPTMP's Avatar
i was wondering why the 99 tahoes are here i own my self and its a 88-98 style
WLPTMP is offline   Reply With Quote
