Old 10-20-2007, 03:39 PM   #1
64GMCHorsepower
Justified!
Light Switch removal??
I thought I had seen this before, but I couldn't find it.....
How do you remove the dash light switch...I cannot see anything to take off to remove it...
I need to see what wires where, or buy a new one....
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 10-20-2007, 03:46 PM   #2
salazar44
65 - Chevy C10
salazar44's Avatar
Re: Light Switch removal??
First remove the knob. There is a button that you press to release the knob. Then you can remove it from the dash.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 10-20-2007, 04:33 PM   #3
64GMCHorsepower
Justified!
hmmm, I don't see a knob.....where is the button at, is it on the back, by the terminals?
Chad
Old 10-20-2007, 05:39 PM   #4
hewlett2002000
hewlett2002000's Avatar
here maybe this will help. the first one shows which way the switch is supposed to go in, i put a different one in. the second one shows the button, its right in front of my finger, just press it and pull the knob out, the third shows it out of the switch. hope it helps.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 10-20-2007, 05:54 PM   #5
64GMCHorsepower
Justified!
finally got it, thanks for the help
Chad
