Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-29-2007, 11:45 AM   #1
NYC-10
screamin eagle
NYC-10's Avatar
under seat sub box up or down
just bought 2 12" subs for under seat installation-should I face them towards the seat or floor
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 10-29-2007, 02:51 PM   #2
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: under seat sub box up or down
It doesn't really matter. If you do face them down, I would recommend having 2" of space between the floor and the bottom of the box to move the air. Most people have them face up though.
Good Luck
72 cheyenne pdx is offline   Reply With Quote
Old 10-29-2007, 04:09 PM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
Face them up............Ive done it both ways............UP
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 10-31-2007, 05:12 AM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
isn't it a different tone of base if their down?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 11-01-2007, 02:36 PM   #5
Beas5713
Beas5713's Avatar
It mostly depends on the style of music you listen to. If you primarily listen to rock, country, etc. then you should face them upwards for smooth response. If you are looking for hard hitting bass for R&B, Pop, etc. then the down firing position will be best. If you aim them upwards be sure to protect the speakers with grill plates, or your rear may bust them. If you choose to go with the down firing position the box should have 2” of clearance towards the rear and 2 ¾" at the front. The angle will result in better sound due to the fact that bass has a sound pattern that disperses across surfaces flat, so the angle will provide more efficient reflection. You will need to invest in sound deading material for your cab and doors for the best sound.
Beas5713 is offline   Reply With Quote
Old 11-09-2007, 01:35 AM   #6
chevy72blu
chevy72blu's Avatar
2" is far more than neccesary to down fire them. 1/2"-3/4" is plenty.
I dont really agree with the above posters. Downfiring seems to provide a better all around low end sound in tight areas whereas upfiring them makes the stage seem "punchy". Of course, every system is different and things such as box construction play a huge factor. Try both and go with what you like better.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-21-2007, 12:22 AM   #7
djracer
djracer's Avatar
I prefer down fire! Subs need a hard surface to resonate off of!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-24-2007, 06:15 PM   #8
Tom
driving is in my blood
Tom's Avatar
I took my 10" custom fit down firing box out of my 98 after one day. I had a 12" in a behind the seat reg. cab box sitting around so I put that in facing up. It sticks out past the seat but it sounds 200% better.
Old 12-19-2008, 05:06 PM   #9
Hair
Did you get them under your seat, and could you post a picture of your box?
Hair is offline   Reply With Quote
Old 12-20-2008, 05:42 PM   #10
killacheyenne
killacheyenne's Avatar
lets see a pic of your box
72 cheyenne super
83 chevy...4x4...454
killacheyenne is offline   Reply With Quote
Old 12-22-2008, 11:51 PM   #11
Hair
Well... did you get them to fit under the seat or not??
Old 12-24-2008, 12:27 PM   #12
NYC-10
screamin eagle
NYC-10's Avatar
they fit under no problem-I did this during the summer so I don't have a picture right now
SCREAMIN EAGLE
Old 12-26-2008, 11:36 AM   #13
Hair
I'm trying to do the same exact thing now (2 12's under the seat). I'm trying to get at least 2cu ft for each speaker. I have the shallow mount 12" Kickers.
I'd really like to see a picture of what you did!
How does it sound?...and did you end up pointing them up or down?
Old 12-26-2008, 07:26 PM   #14
djracer
djracer's Avatar
I don't know of any truck you can get 4 cubic feet under the seat.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 12-27-2008, 12:20 AM   #15
NYC-10
screamin eagle
NYC-10's Avatar
I put the subs facing up-and I'm very happy.I had a 72 blazer with a big box in the back and the base had a harder kick,but for what it is it sounds really nice.Between the subs and the bostons in the kicker panel It sounds mint.
SCREAMIN EAGLE
Old 12-29-2008, 10:52 AM   #16
Hair
How much cu ft did you end up having in your sub boxes?
Like djracer said, I'm scratching my head trying to figure out a box.
I am planning on removing the stock seat brackets and making my own that will give more clearance.
I'm planning on the box on the driver's side to extend over to the passenger side, and then the passenger side box will extend up behind the seat where I have a little space beside the gas tank. I think I can barely sqeeze 2 cu ft out of them, but I don't know yet. It looks good on paper...but that's paper.
So when you came on here and said that you are going to throw two 12" subwoofers under the seat like nobody's business and just wanted to know if they should be pointed up or down you became my instant hero.
So how much space did you end up with in your boxes or or they like free air mounted or something?
Old 12-29-2008, 08:45 PM   #17
NYC-10
screamin eagle
NYC-10's Avatar
I just built the biggest box I could fit under a stock height seat and divided it in half.I didn't get to technical.If the box is not big enough You can buy a filler (pillow stuffing)that tricks the speaker into thinking the box is bigger.Maybe in two weeks I'll have pics
SCREAMIN EAGLE
Old 12-30-2008, 12:55 PM   #18
badblu97
Double 6's
badblu97's Avatar
Heres a pic of mine, 2 10" Kicker CVT's DOWN firing....wouldnt have it any other way, and I listen to all types of music. And I know its a new body, but same thinking I would imagine...I would say 2' is just about right for spacing. Look at how a sound wave works and it will make more sense...just my .02
badblu97 is offline   Reply With Quote
Old 02-14-2009, 08:23 PM   #19
pumpgas
pumpgas's Avatar
So where's the pics??
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 02-16-2009, 12:07 PM   #20
Hair
That's just it pumpgas. No one "NO ONE"!! has ever made a box to fit under the bench seat of a 67-72 truck and fit two 12" woofers in it. You hear about it all over this site, but you will NEVER see a picture of one, because they do NOT exist. It's just a bunch of talk. Maybe a few small boxes with like one 8", but that is it. If I am wrong, then shoot me down... anybody... show me a picture and I'll eat crow. Anybody can stick a box under the back seat of a extended cab truck, but lets see a box under the bench seat of a 67-72 reg cab. I think that they are just a myth that is discussed on here, but never has been accomplished.
Old 02-19-2009, 06:58 PM   #21
NYC-10
screamin eagle
NYC-10's Avatar
ok I finally took the seats out-here's the pics-2 12's ,2 Pioneer amps that I put where the jack used to go and the Bostons in the kick panel
SCREAMIN EAGLE
Old 02-20-2009, 03:01 PM   #22
Hair
Hmmm... well... okay... looks like you got that all figured out.
I was wrong. You are the man!
What does that box measure?
Thanks for the pic.
Old 12-16-2009, 08:06 PM   #23
lil blue
lil blue's Avatar
i fit 2 kick comp 10 ins under my seat and im about to get 2 kicker 10in shallow mount cause they louder. but i had them facing up and the seat soaks up the sound i made them fire down and i noticed they are a lot louder and i have them about 1inch off the ground and that plenty of room
1978 c10 stepside
lil blue is offline   Reply With Quote
Old 12-17-2009, 11:08 AM   #24
foosed
foosed's Avatar
what are the dimensions on that box? any pics?
1970 c/10 swb (show truck)
1972 custom/10 deluxe 4x4 (restoration pending)
2011 silverado ecsb z71 (daily driver)
foosed is offline   Reply With Quote
Old 12-19-2009, 10:17 AM   #25
pumpgas
pumpgas's Avatar
I'd be interested in some pics of this box or is it 2 boxes?
