11-10-2007, 06:40 PM | #1 | |
Señor Member
Re: How to: Ruin a perfectly good Blazer...
11-10-2007, 08:08 PM | #2 |
11-10-2007, 09:29 PM | #3 |
A guy with a truck
Thanks for the props everyone. You guys keep motivated.
XXL is just yankin' your chain. Could be cool though. Hmmmm... So I spent some time test fitting the inner plates. They require a lot of trimming/fitting because of the panhard crossmember. I started out by clamping a straight edge to the framerail to use as a guide to cut it straight. This allows the inner and outer plates to be parallel. Next, I made a cardboard template of the inner plate and cut it to fit. It is clamped in place and ready to burn in. I also fitted the top cap. Next step is weld it up and cut the frame!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-10-2007, 09:39 PM | #4 |
Gringo,
You wanna take a short 2 1/2 hr drive over here to Little Rock and help me lay out mine? Nice work.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
11-10-2007, 10:16 PM | #5 |
I need some help on mine this weekend also.
11-13-2007, 05:51 PM | #6 |
Well I got mine welded in without your help I also figured out that I could still use my rear trailing arms with a 3" block to use all but 1/2" of my notch. I guess I am going ahead with the nascar truck arms instead of the 4 link.
11-13-2007, 06:13 PM | #7 | ||
A guy with a truck
Lil' more progress- mostly just an excuse to post some needless pics . I used the old captured nut trick to install the 'button' bumpstops. They are slightly forward of the notch centerline 'cause that's where the axle will rest when dumped. I also got the panhard bracket trimmed and installed the other side's bumpstop.
