Old 01-25-2008, 07:32 AM   #1
**grumpy**
**grumpy**'s Avatar
No panhard bar with trailing arms??
I'm sorry if this has been covered, but I didn't see it anywhere.
Can I run 2- 20" angle bars from the rearend backwards to a crossmember along with my stock trailing arms on my 64, instead of using a panhard bar?
I did a homemade notch, and didn't leave myself much room to run a panhard that wouldn't be real short.
Any advice or pics would be great.
I appreciate it.
**grumpy** is offline   Reply With Quote
Old 01-25-2008, 07:45 AM   #2
redsled04
redsled04's Avatar
Re: No panhard bar with trailing arms??
Im not positive but I dont think it will work. Your stock arms will bind were there bolted to the rear end. Cause theres no bushings. It would hold it side to side but through out up and down travel it wont work.
redsled04 is offline   Reply With Quote
Old 01-25-2008, 08:50 AM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
like a watts link? http://totallypolished.com/watt's_link_kits.shtml
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 01-25-2008, 10:24 AM   #4
Slmd92DIME
Slmd92DIME's Avatar
I highly doubt it will work cause it will need a pivot point on the forward arms. Think about it. The axle will need to rotate having the bars from the rear or front. There is not pivot out of the stock arms where it is bolted to the axle..
Slmd92DIME is offline   Reply With Quote
Old 01-25-2008, 12:02 PM   #5
**grumpy**
**grumpy**'s Avatar
Yeah, makes sense once I picture it in my head.
Thanks.
guess I'll try to make a panhard bar work.
Old 01-25-2008, 12:43 PM   #6
Slmd92DIME
Slmd92DIME's Avatar
i have seen many trucks with a diagonal bar that goes from one link bar to the other. They refer to it is a "trac bar" I have never done this so dont hold me on it on how great it works. Get some pics up of your rear and we can try and help you find a place to put your panhard. Just an option..
Old 01-26-2008, 08:44 AM   #7
XXL
Seņor Member
XXL's Avatar
A setup like that wouldn't keep the rear centered. Something needs a frame mount point or the rearend gets to walk from side to side.
XXL is offline   Reply With Quote
Old 01-28-2008, 05:56 AM   #8
**grumpy**
**grumpy**'s Avatar
Thanks guys.
My camera is MIA, so you'll just have to close your eyes and imagine
I was reading posts here, and think I may consider a watt's link.
I see they are sort of expensive. Has anyone used the $69. watt's that Speedway sells? It looks like it should work....?!
I'd go that route if that one would work.
Opinions?
Old 01-31-2008, 08:55 AM   #9
1LoC10
Insert Title Here
1LoC10's Avatar
holy crap XXL you belong to alot of clubs...lol
BOBBY
_69 SWB_
Old 01-31-2008, 09:34 AM   #10
jkaylor68gmc
jkaylor68gmc's Avatar
I agree that it will not work, it controls side to side movement. You should be able to fab up some mounts for a panhard. It centers the rear-end. I would jut work on the centering the rear-end and installing a panhard.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 01-31-2008, 10:36 AM   #11
502tripower
502tripower's Avatar
As jkay said...What you have described will not work. I think you would be best relocating the panhard bar. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 02-03-2008, 01:56 AM   #12
LONGHAIR
If you have space in front of the axle, you could fabricate a "sliding wishbone". It will keep the rearend centered and still allow the suspension to travel w/o binding.
LONGHAIR is offline   Reply With Quote
Old 02-03-2008, 01:12 PM   #13
**grumpy**
**grumpy**'s Avatar
I guess I don't know what a sliding wishbone is.......
Pics maybe??
Old 02-04-2008, 01:44 AM   #14
LONGHAIR
I couldn't find a decent picture, so I drew a quick little sketch. In the drawing the wishbone is red. It is nothing more than tubing with rod ends. You need brackets, similar to a 4-link, to mount it to the axle housing. A new crossmember goes between the frame rails. These points pivot up and down allowing for the suspension travel. The front point, the black line, is the "sliding" part. It allows the wishbone to change length as the suspension travels. This eliminates any binding from the mounting points having different lengths.
Theoretically it can mount either way...The single point could be on the axle housing and the other end on the crossmember. It could be mounted behind the axle too, wherever you have the most space for it. As I drew it, seems easiest to me. It uses most of the same space already needed for the rest of the suspension parts. Plus it is easier to weld the brackets to the housing instead of what would be a casting on most rear-ends.
Old 02-04-2008, 07:14 AM   #15
mdmontess
Computer mogul Bill Gates
mdmontess's Avatar
other Watts Links from kplinks.com that is what i am getting
mdmontess is offline   Reply With Quote
