Old 02-14-2008, 11:55 AM   #1
Wreckless_71
Wreckless_71's Avatar
CV joint
Is it a bad idea to remove the Cv joint assm. from the front drive shaft? They just seem like such a pain...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 02-14-2008, 04:36 PM   #2
OldCreek
OldCreek's Avatar
Re: CV joint
I think it needs it because of the short length of the front driveshaft. Otherwise, there would be too much vibration and bind. I believe this is especially true if there is any kind of suspension lift.
I believe this is why Jeeps normally have a rear cv joint... their wheelbase is so short.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-14-2008, 08:29 PM   #3
Blazer1970
Blazer1970's Avatar
Re: CV joint
As long as you never go over about 30 mph with the hubs locked in you can probably get away without it. It is there because of the way the u-joint angles are set-up on the front shaft. It eliminates the vibration you would otherwise get from mismatched angles.
Blazer1970 is offline   Reply With Quote
Old 02-14-2008, 11:44 PM   #4
Wreckless_71
Re: CV joint
Hey thanks for the replies guys I think I'll just stick with the CV joint after all... It's gonna be my daily driver, not a hard core off-roadin' machine.
Old 02-20-2008, 02:03 AM   #5
jacobs
jacobs's Avatar
Re: CV joint
I removed my CV joint 15 years ago and I'm glad I did....no vibrations even at 80 mph. It's not lifted though.
jacobs is offline   Reply With Quote
Old 02-23-2008, 01:36 AM   #6
Wreckless_71
Re: CV joint
Yeah... it's lifted 4 inches. I decided to just stick with the CV set-up so is there any tricks to putting it together? I took it all a part but it the seal and all that good stuff was gone so it just fell a part. I got the new U-joints and a new CV piece that bolts to the transfer case, but the guy at the auto parts store said there was some trick to putting it all together? Any comments or tips please let me know!
Thanks,
J.D.
Old 02-23-2008, 03:23 AM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
Re: CV joint
Rebuilding CV's is usually left for a driveline shop. When mine was wasted I thought about doing it myself, but to actually replace the ball could require cutting the end off the shaft. From looking at mine and talking to a shop I know it's worth the money to have a pro rebuild the cv.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-23-2008, 11:01 AM   #8
TC70C10
TC70C10's Avatar
Re: CV joint
I just got mine back from HSV driveshaft yesterday afternoon. CV ball kit and sleeve and 2 new Spicer u-joints and labor was $117
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 02-23-2008, 11:02 AM   #9
TC70C10
TC70C10's Avatar
Re: CV joint
He charged me 42.50 in labor in 2003 and 45 dollars labor in 2008. Not bad
Harvest, AL 35749
Old 02-23-2008, 01:24 PM   #10
Wreckless_71
Re: CV joint
This is what I got for replacement...circled in red. I'm not really sure what the big deal is with doing the replacement myself? Looks pretty straight forward...
Old 02-23-2008, 04:36 PM   #11
Blazer1970
Blazer1970's Avatar
Re: CV joint
It is all easy as long as the yoke (part #5) is not worn out. This yoke has a little boss that keeps the two u-joints aligned properly, and it can wear out. To replace the yoke you obviously have to cut and weld a new one on. I normally tear them apart, and if the yoke is OK you just put it back together with the new u-joints. If the yoke is bad take just the shaft to a shop and have them weld a new yoke on for you. That way all you will ever pay for is the part that you can't do at home.
Old 02-24-2008, 03:59 AM   #12
Zoomad75
K5Camper
Zoomad75's Avatar
Re: CV joint
Tim's got it right there. On mine the ball/socket deal on #5 was worn out. It needed a new yoke. Got mine done for $77 through a shop I deal with. The big issue is when welding the yoke back on besides making sure it's true is making sure it's in correct phase with the joint on the other end of the shaft. If it's not in phase, the joints can't cancel each other out and it will vibrate regardless if it's been balanced or not.
From what I've heard, even if you just end up replacing the part you circled you almost need 4 hands to get everything together correctly. Meaning it's not as easy as you might think it looks.
Rob Z.
Old 02-24-2008, 12:54 PM   #13
Wreckless_71
Re: CV joint
HAHAHAHAHAH! The deed is done... and yes it just about takes four hands to get it all together but other than that it was pretty simple...
Thanks for all the help guys.
