Old 01-29-2003, 03:44 PM   #1
68 Suburban
68 Suburban's Avatar
Towing a 4x4 on a tow dolly.
I might be towing a blazer on a tow dolly. It is a 4 speed, so if it was a 2 wheel drive I would not have to disconnect the drive shaft, but since it is a 4 wheel drive, what do I need to do?
If I put the transfer case in the 2wd position, will it disconnect the front driveshaft?
68 Suburban is offline   Reply With Quote
Old 01-29-2003, 03:52 PM   #2
sakohntr
sakohntr's Avatar
neutral
Place the transfer case in neutral or remove the driveshaft from the axle that is still in contact with the ground. Either way. Third option is put the rear axle on the dolly, placing the front axle on the pavement and unlock the hubs (if so equiped).
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 01-29-2003, 03:56 PM   #3
68 Suburban
It the transfer case is in neutral, I should be able to leave the rear drive shaft connected, since it is a 4 speed and will self lubricate as the back wheels turn? Thanks
Old 01-29-2003, 04:08 PM   #4
junkyardjohn
junkyardjohn's Avatar
Thumbs up
YEP -- YOU SHOULD BE OK WITH A 4 SPEED THRUCK IN NUETRAL, & IT WONT HURT ANYTHING TO TOW IT WITH THE FRONT WHEELS ON THE GROUND IF THE TRANSFER CASE IS IN NUETRAL EITHER.
(PS EVERYONE NEEDS A TOWTRUCK OF THIER OWN )
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-30-2003, 12:11 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Where you finding a dolly that is wide enough?
I've never seen one.
Old 01-30-2003, 12:20 AM   #6
68 Suburban
http://www.demco-products.com/Pages/...ar-Kaddy-30797
Model KK360SB
Plus, take a look at this link
http://67-72chevytrucks.com/vboard/s...threadid=38089
Old 01-30-2003, 12:51 AM   #7
Longhorn Man
Interesting, I never read that thread.
The only dollys I ever seen wide enough were home made.
Cool.
