Old 02-03-2003, 09:59 AM   #1
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Question Bonding adhesive for body panels...Anybody use this stuff before?
I have some custom work I want to do and welding is not an options (actually grinding would be the problem). I'm concerned about rust under a sheetmetal over sheetmetal application (about 12" x 24") . Also, on adhesion, how well does this stuff hold? Is it user friendly?
BTW, I posted on paint and body and got no information so I posted here. Thanks
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 02-03-2003, 11:32 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I had new floor pans and rockers installed at a body shop. Some of it was welded-in and some was installed with their adhesive system. I have had no problems with it at all. The way they use it seals the joint from air infiltration. Welding creates oxidation, so I am feeling pretty good about what I have. Hope this helps.
Member Nr. 2770
Old 02-03-2003, 11:44 AM   #3
meathead95
computer illiterate
meathead95's Avatar
i believe snowman uses it you could ask him.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-03-2003, 02:48 PM   #4
srhart71
A good friend of mine owns a bodyshop in Michigan and he swears by this stuff. (No, not at it) Says it makes some repairs better than could be done with welding. He also brought up the sealing out of air.
srhart71 is offline   Reply With Quote
Old 02-03-2003, 05:43 PM   #5
Canada20
I think we've discussed this one on here before too so it might be worth a look.
www.autobodystoreonline.com has people who know plenty about this stuff.
There's an Eastwood kit for this that sounds like it would do a pretty good job. Classic Trucks replaced a cab-corner in their Feb issue using the Eastwood kit. I'm interested in trying this method too. I've also talked to a guy in a body shop and most of their work is with adhesives now and he believes it's better than welding for non-structural things. He seems to me to be a non-bs kind of guy with lots of experience with repair.
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 02-03-2003, 06:32 PM   #6
mtdave2
newly minted old timer
mtdave2's Avatar
i used it on my sidecar. the stuff holds well, i dare say just as strong as weld. easy to put on too.
the down sides... cost a lot.. it well come loose when exspoed to lots of heat! this made a big mess for me. after i put on my sheet metal, i needed to weld a piece on the botton. the area of sheet metal around the weld started to come part from the frame... not good. i couldnt refuse it, had to reweld.. more heat,, more reweld. ended up welding the whole thing.
i promiced myself id never use it again (fuzeor it think its called)
however for some applications it would be just the stuff.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 02-03-2003, 08:29 PM   #7
70 Jimmy
70 Jimmy's Avatar
Cool. Here's what I'm hearing:
Easy
Works well for non-structural
Do all my welding on the panel first!
Be prepared to pay (any idea how much?)
Better than welding as far as oxidation is concerned.
Thanks!
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 02-03-2003, 08:34 PM   #8
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
I used it for the patches on the holes from my Auxiliary fuel tanks. I am not sure if it was from the vibration from my bed jumping, or what, but it is now cracked through the paint, causing me much grief!!!
I am going to tach weld them this time, and grind!!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 02-03-2003, 09:10 PM   #9
68 Suburban
68 Suburban's Avatar
Ok, does this stuff need to be used with the repair panel overlapped, or can it be used where a butt weld would be used? If so, how is it applied for a butt weld? Thanks
68 Suburban is offline   Reply With Quote
Old 02-03-2003, 09:19 PM   #10
Stano
Stano's Avatar
I just used it today as a matter of fact, put a roof skin on a Tundra with it. Its made by 3M and is called Panelbond. I don't trust it but it does make for a nice finished result. You can't use it for a butt seam. For this type both metal surfaces have to be ground clean then you apply a fine bead to both bare surfaces and spread it over the bare metal with a spreader if you will. Then you apply another bead on top of the skim layer to actually bond the panels together. Then it must be clamped tightly until dry or about 24 hours to be safe. We have had a couple bed sides come back with cracking of seams though. I will have to let time show me that its as good as they say it is. It has miniscule glass beads in it to keep from squeezing it all out when it is clamped. It does work well as a plastic repair and on fiberglass.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 02-03-2003, 09:26 PM   #11
Blue Beard
Blue Beard's Avatar
Have you looked into using something like POR-15 over it when finished?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-03-2003, 09:59 PM   #12
Canada20
I've heard a couple of different ways of clamping;
Use regular body clamps,
Use sheetmetal screw and grind them off when you're done,
Use rivets instead of screws. Not like I'm a salesman for Eastwood or anything but from that writeup in Classic Trucks, they have a dimpling tool (which I'm sure could be home-made) that you use once you've drilled the holes for the rivets or the screws. That way there's a metal spike going through the panels every few inches.
As for the butt vs lap method; usually the write ups say just pick a spot that it's going to be less conspicuous to overlap the pieces and use kitty-hair as a filler but I've been thinking that if a person were to take a strip of metal a couple of inches wide to span the gap between the panels, you could usse that as a backing and it would make for a more invisible patch. (Holy run-on sentence, batman!) Again, referring to that article...that apparently works.
Greg
Old 02-03-2003, 10:10 PM   #13
matt_field
matt_field's Avatar
ive talked to a body guy in town here , and hes actually said hes seen the panels fall off before. so he doenst use it
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 02-03-2003, 10:16 PM   #14
DanoDMano
DanoDMano's Avatar
I screwed the panels in, and ground down the heads and it held up for ahile. But I think that because of the jolting my bed got that it just
cracked loose around the edges.
The stuff is great to work with though, and I think I would still use it for patching my fuel hole when I relocate my tank!!!
Power Locks,
Truck Photos
Old 02-04-2003, 12:42 AM   #15
68 Suburban
What is the process for finishing the panel after it cures? Does it sand easily?
Old 02-04-2003, 01:10 AM   #16
DanoDMano
DanoDMano's Avatar
We ground mine down, and body puddied til nice and smooth. It really came out nice except for the stress cracking.
I'll post a few pictures tomorrow of the cracking I am experiencing..
Power Locks,
Truck Photos
