07-22-2008, 05:48 PM | #1 |
Fly by wire gas pedal mount - 65C10
Hey guys,
I am putting a fly by wire engine in my 65C10. Here is one way to convert while keeping the stock gas pedal. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-22-2008, 05:51 PM | #2 |
Re: Fly by wire gas pedal mount - 65C10
Here are the rest of the pics
07-22-2008, 11:58 PM | #3 |
60-66 Nut
You do some nice work.....I'm anxious to see the rest of your install on your truck.
07-23-2008, 01:55 PM | #4 |
chevelito
very nice!
New deadline...when my son can drive. Aloha from Honolulu, HI |
01-20-2009, 11:05 PM | #5 |
that is SWEEEET!!!
when you gonna start a build thread?? or have you already?
CHEVY ONLY |
07-10-2012, 12:54 AM | #6 |
I saw something interesting a couple weeks ago, a friend of mine who is a street rod builder put a late model hemi with dbw in an old Chrysler I think it was late four ties early fifties. he took the pedal and cut the foot part off and made a Bracket to mount it on the intake. The part that would mount to the fire wall was mounted to the bracket so the foot pedal part would stick up towards the hood this bracket assembly was probably two to three inches from the fire wall. He then used lo kar style pedal which was mounted regularly on the fire wall and ran the cable through the fire wall and attached it to the stubby part of the pedal that was left over from the part that was trimmed off. I hope you can under stand this I will try to get pictures later it was real clean install and used a cable pedal to actuate.
Posted via Mobile Device |
07-10-2012, 04:05 PM | #7 |
Truck and auto performance nut
Great info! Would like to see one on the later one piece plastic pedal assemblies.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-13-2012, 10:07 AM | #8 |
Very nice work, like how your keeping the original pedal look! I thought about going that Route but decided to convert engine to drive by cable instead.
8.1l 496 4l80e |
07-14-2012, 10:04 PM | #9 |
Thanks men,
I guess I should tell the rest of the story. When I tried to start the engine I got the "I ain't going to run the engine with this pedal" code from the computer. So I had to get a different style pedal. I could still use the same mount, just a new set of mounting holes in the plate and a new rod to adapt to the stock pedal. TR
07-16-2012, 02:25 PM | #10 |
Yeah, that's a bummer about the pedal. You pretty much need the matched set from the same vehicle that the ECM came from. At least same year/model/etc...
Doing work twice sure sucks. I know all about that
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
05-30-2014, 05:07 PM | #11 |
subscribed
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
06-16-2015, 03:07 PM | #12 |
So I did this on a 5.3 DBW last year and it screwed up the sensors in the pedal. It would be at full throttle at half pedal because of messing with the geometry of the pedal and the position sensors on it. Said I would never cut one again..........
