Packrat
vibration question: 72 k20
'72 k20 w/4"lift
had a couple of vibrations when going over 60 mph. first would happen once I went over 60 mph, then when letting off the gas, there was a different vibration until I got down to about 55 mph. first vibration was taken care of by new tires/wheels, and a new tie rod end/alignment. second vibration is still there.... just between 55-60 while decelerating. thoughts?
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
#2 | |
Bloo
Re: vibration question: 72 k20
check the splined slip yoke on the front of your driveshaft. your describing my truck almost spot on, i had a vibration from 45-50, then over 60... found 3 bent wheels. also had a vibration on deceleration from 65 down to 50 so i took the driveshaft to a driveline shop.. he inspected it and found the slip yoke to be worn VERY bad... he said that was causing it, but i cant gaurentee it because i have yet to have it fixed... the guy told me it would cost about $200 for both sides of the slip yoke, and welding and balancing the shaft.
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Keepin it runnin!
U-Joints ok?
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
Packrat
well, it's over 2 years later, and I finally got a new driveshaft
![]() the splines on the slip were worn as predicted. it finally started to get worse.. new shaft has lifetime spicer u-joints ( 1350 ) and the tube is slightly smaller diameter with greater wall thickness. the same tubes they use for the pulling trucks... ![]()
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 Last edited by 72-c20; 01-07-2011 at 10:36 AM. |
#5 | ||
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains ![]() Quote:
![]() want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
I bet it feels better at all speeds. She's tight now!
Packrat
