Aftermarket Throttle Cable Bracket
What are you guys using sucessfully for an aftermarket throttle cable bracket? I have a 350 with an edelbrock air gap intake, demon carb with 2" spacer, stock throttle cable, and 700r4 tranny. I have one of those Spectre adjustable brackets you can get from any of the auto parts stores but it doesn't have enough adjustment for the throttle cable to not be bent in a bind. Thanks.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
BAD BOW-Silverado XST
Re: Aftermarket Throttle Cable Bracket
Use this to correct the angle.
![]() I use Edelbrock 8036 from www.summitracing.com. I had to modify the bracket a little. The bracket is a little short for an RPM intake. I use a RPM air gap on my ZZ4. Look through my ZZ4 pictures below in my signature. I can't post a picture from this computer because the site is blocked. |
gchemist, did that bracket allow you to use the factory brackets that hold the cable housings?
http://www.jegs.com/p/JEGS/752613/10002/-1
![]() I feel this bracket was money well spent. Being that it's carb attached, your cable angles will always be right no matter how tall the manifold or spacer is, and as a plus the throttle return springs are on it as well and are adjustable. You do have to purchase the kickdown or TV cable slider as an extra. It will share the adjustment screw with the throttle slider, OR you can do what I did and use another bolt an nut to bolt it further back behind the throttle slider if the kickdown/TV cable needs it. You will also need longer carburetor studs if your current studs don't have enough length for the bracket.
1977 GMC Sierra Grande Last edited by Pyrotechnic; 11-26-2008 at 02:38 PM. |
Bowtie overdrives sells a bracket for the 700r4 that is supposed to be fool proff, as well as Lokar. Here I just copied and pasted a lot of them from Summit. Spending some money here will ensure smooth safe operation of your throttle, as well as not smoking the 700r4 due to improper TV setting.
LOK-SRK-4000 Lokar Throttle Cable Brackets Throttle Cable Bracket, Stainless Steel, Polished, Holley/ Edelbrock/ Carter/ Rochester, Kit Today $23.95 SUM-210240 Summit® Billet Aluminum Throttle Cable Brackets Throttle Cable Bracket, Billet Aluminum, Clear Anodized, Holley 4150/ 4160 Style, Each Today $69.95 SUM-G1419 Summit® Carburetor Linkage Plates Throttle Cable Bracket, Steel, Chrome, Holley/ Edelbrock/ Carter, Each Today $20.95 HLY-20-112 Holley Throttle Cable Brackets Throttle Cable Bracket, Aluminum, Red Anodized, Holley, 4150/ 4160, Each Today $95.95 SUM-G1414 Summit® Adjustable Throttle Cable Brackets Throttle Cable Bracket, Steel, Chrome, Holley/ Edelbrock/ Carter/ Rochester, Each Today $8.95 HLY-20-95 Holley Throttle Cable Brackets Throttle Cable Bracket, Steel, Gold Iridited, Chevy, Big/ Small Block, Holley, 4150/ 4160, Each Today $19.95 LOK-DP-1000HT Lokar Duo-Pak Throttle Cables Throttle Cable, Hi-Tech, Braided Stainless Steel, 24 in. Long, Stainless Steel Bracket/ Springs, Each Today $71.39 HLY-20-88 Holley Throttle Cable Brackets Throttle Cable Bracket, Steel, Chrome, Holley, 4150/ 4160, Each Today $21.95 EDL-8036 Edelbrock Throttle Cable Brackets Throttle Cable Bracket, Steel, Cadmium Plated, Chevy, Small Block, with Edelbrock Carburetor, Each Today $25.95 EDL-8031 Edelbrock Throttle Cable Brackets Throttle Cable Bracket, Steel, Black Powdercoated, Chevy, Big/ Small Block, with Edelbrock Carburetor, Each Today $26.95 HLY-20-45 Holley Throttle Cable Brackets Throttle Cable Bracket, Steel, Gold Anodized, Chevy, Small Block, Each Today $11.88 LOK-DP1000U Lokar Duo-Pak Throttle Cables Throttle Cable, Hi-Tech, Black, 24 in. Long, Stainless Steel Bracket/ Springs, Each Today $64.99 EDL-1490 Edelbrock Throttle Cable Brackets Throttle Cable Bracket, Steel, Gold Iridited, Ford Small Block with Edelbrock Carburetor, Each Today $12.95 LOK-DP-1000HT36 Lokar Duo-Pak Throttle Cables Throttle Cable, Hi-Tech, Braided Stainless Steel, 36 in. Long, Stainless Steel Bracket/ Springs, Each Today $77.39 EDL-8032 Edelbrock Throttle Cable Brackets Throttle Cable Bracket, Steel, Black Powdercoated, Chevy, Small Block, Vortec, with Edelbrock Carburetor, Each Today $26.95 LOK-TCB-40DQ Lokar Throttle Cable Brackets Throttle Cable Bracket, Intake Manifold Mount, Aluminum, Natural, Edelbrock, Performer/ Performer AVS, Each Today $69.69 EDL-8030 Edelbrock Intake Manifold Installation Accessories Throttle Cable Bracket, Steel, Chrome, Universal, Each Today $37.95 LOK-SRK-4001 Lokar Throttle Cable Brackets Throttle Cable Bracket, Stainless Steel, Each Today $14.39 LOK-TC-1000BLD Lokar Hi-Tech Blower Drive Throttle Cables Throttle Cable, Hi-Tech, Braided Stainless Steel, 24 in. Long, Mounting Bracket/ Rod, Blower Application, Each Today $54.95 TFS-51500075 Trick Flow® Throttle Cable Brackets for 5.0L Ford Throttle Cable Bracket, Aluminum, Natural, Ford, SFI, 5.0, with 75mm Throttle Body, Each Today $51.95 SPE-24283 Spectre Throttle Cable Brackets Throttle Cable Bracket, Steel, Chrome, Adjustable, Automatic/ Manual, Universal, 2V, 4V Carburetors, Each Today $17.69 HLY-20-119 Holley Detent Cable Brackets Detent Cable Bracket, for 20-112 Throttle Cable Bracket, Billet Aluminum, Red, TH-350/ 200R4/ 700R4, Each Today $49.39 CSI-620C CSR Throttle Cable Brackets Throttle Cable Bracket, Billet Aluminum, Clear Anodized, Holley, 4500 Series, Fits GM Cable, Each Today $49.95 CSI-630C CSR Throttle Cable Brackets Throttle Cable Bracket, Billet Aluminum, Clear Anodized, Holley, 4150 Series, Fits GM Cable, Each Today $53.95 CSI-630R CSR Throttle Cable Brackets Throttle Cable Bracket, Billet Aluminum, Red Anodized, Holley/ Barry Grant/ Demon, Fits GM Cable, Each Today $49.95 LOK-TCB-40RJ Lokar Throttle Cable Brackets Throttle Cable Bracket, Stainless Steel, Polished, Chevy, Small Block, Ramjet, Each Today $51.88 CSI-630B CSR Throttle Cable Brackets Throttle Cable Bracket, Billet Aluminum, Blue Anodized, Holley/ Barry Grant/ Demon, Fits GM Cable, Each Today $49.95 CSI-612B CSR Throttle Cable Brackets Throttle Cable Bracket, Billet Aluminum, Blue Anodized, Holley, 4150 Series, Fits Ford Cable, Each Today $49.95 CSI-631C CSR Throttle Cable Brackets Throttle Cable Bracket With Kickdown, 4150 Series Carburetors, Each Today $60.69 EDL-1493 Edelbrock Throttle Cable Plate Kits Throttle Cable Bracket, Steel, Gold Iridited, Ford, 351M/ 400 with Edelbrock Carburetor, Each Today $12.95 LOK-TCB-40EFI Lokar Throttle Cable Brackets Throttle Cable Bracket, Stainless Steel, Polished, Ford, SFI with AOD, Each Today $19.69 EDL-1491 Edelbrock Throttle Cable Plate Kits Throttle Cable Bracket, Steel, Gold Iridited, Ford 351W with Edelbrock Carburetor, Each Today $12.95 EDL-1495 Edelbrock Throttle Cable Plate Kits Throttle Cable Bracket, Steel, Gold Iridited, Ford, 429/ 460 with Edelbrock Carburetor, Each Today $12.95 |
![]() Here is the bracket before I modified it. I cut it and moved the top portion up a little. All the cables align properly. The bracket does not need cutting on most manifolds. However, RPM intakes are taller than most intakes. yes, it works with stock cable clips. I have throttle, TV and cruise control all connected. Follow the picture to other pictures. |
I see how that works now. That may be my choice although I may need to change my throttle cable. The part that snaps into the bracket and holds the cable is round which doesn't seem to be compatible with most brackets. I also thinks it's a hair to long. It sucks because this holding up getting my truck drivable again.
