Drop spindles
Does any body know how much you would have to drop a 67 chevy to make it evenly droped
Thinking about going 2 1/2 drop spindles in front and 4 inch spring drop in the back
Adrian |
68cst_ss490
Thats about the same drop i want to do to my 68. I wish I could see a straight on from the side shot of that drop.....
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
If you find any picture let me know
Adrian |
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
14.1 @ 96MPH
![]() ECE 2.5" spindles and 245/60-15 tires front ECE 4" drop leaves and 275/60-15 tires rear
Project1970 - LS1 Swap Complete! ![]() |
I am assuming that 275/60/15's won't go in the front with the drop spindles? Just wondering, I plan on doing the same drop.
72 Cheyenne Super 402 daily driver. A lifetime project! |
14.1 @ 96MPH
The problem isn't the drop, but the wider track from discs. It would depend on your wheels, though, and their backspacing...I think with more backspacing I could run wider fronts, to an extent at least...
Low & Slow
Project 1970 I've got a question, How tall from top to bottom are your tires on the front and the rear. I've got bfg 255/70/15's on all four right now. Thanks in advance
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
14.1 @ 96MPH
The rears are 28" tall, the fronts are 26.6" tall.
Hey PROJECT 1970, where did you get the center caps? I have similar or the same off an '86 Blazer. I need some center caps though. Those are the ones with 3 screws holding them on?
14.1 @ 96MPH
Those were the 4x4 ones that came with the rims, just covered with vinyl stickers...
Dreaminator
I am running 2 1/2 with tweaked front springs that makes the total front drop about 3 1/2 inches. In the back are 4 inch drop coil springs in a carrier adjusted about another 3/4 inch for a total rear drop of about five inches. It sits nearly level with a level placed on the bed. With 17x9 255/60s on the front and 17/9 285/60s on the back I am one inch from top on both fender wells. Off sets are five and one half inches. On my truck the perfect off set would probably be 6 to 6 1/2 inches. Only problem on front was need to adjust stop so tread would not hit stock placed shock. On the back if I go lower and wider I will have to raise and widen the wheel wells inside the bed. Be very careful of the off set. I have already sent two rims back.
The Dreaminator Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400. |
