Front/Rear axle Option Codes
I just looked at mine, and this is what I saw, does anyone have something similar
I have both front and rear axle options on mine 79510AA Positract RR Axle 79501BB Positract Frt Axle options on my Glove Box What exactly does that mean, not lockers right? Is there a List of option codes out there?
1968 4x4 swb |
Input?
1968 4x4 swb |
You should have positraction on both unless something has been changed. These are not lockers. My posi front end had a metal tag on one of the bolt holes as well. You could jack it up and rotate the tires to see if it still is posi as well.
I think my lockers are listed as "no spin" on glove box, but I don't have one in front of me. They are all the Eaton/Corporate rear end. ![]() |
The 12-bolt rears have either an Eaton positracion unit or a GM positraction unit based on the Eaton. Both are friction disk limited slip units. That is what you have in the rear of your '68.
I don't know what they put in the Dana 44 in the front of your '68. I would bet it would be the same style. GM was pretty good about calling that type of limited slip differential a "positraction", and lockers something else (No SPIN, etc..).
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
