Old 03-25-2002, 05:22 PM   #1
mikegi
Post hei question
I've been reading alot of posts about hei,i guess i should have printed them out,there is two connections one that says tach and one that says batt,do i just make up connection from batt to fuse box and leave tach connection alone?
Springvale,Maine
71 3/4 GMC lwb
mikegi is offline   Reply With Quote
Old 03-25-2002, 05:27 PM   #2
CoryM
Post
You want the power wire on the accesories so that its only on when the ignition is in run.
Best way to do this is run a wire with a male spade onthe end to the fuse panel and just plug it into an empty hole marked "acc".
The tach plug you leave unless of course you have a tach . Make sure to use a good wire, its the only thing keeping the truck running.
Good luck.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
