Old 02-01-2009, 04:22 AM   #1
whitetrash_elky
steering column question.
has anyone taken the 3 on the tree column and converted it to work a regular automatic tranny?
whitetrash_elky is offline   Reply With Quote
Old 02-01-2009, 10:38 AM   #2
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Re: steering column question.
Anything is possible with these old trucks. A degree in mechanical engineering might help.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 02-01-2009, 02:05 PM   #3
whitetrash_elky
well i guess i'm S.O.L!!! is there enough lateral movement in the shifter to even pull it off?
Old 02-01-2009, 02:07 PM   #4
B17CRX
B17CRX's Avatar
Thats not a bad idea, anyone here done it??
B17CRX is offline   Reply With Quote
Old 02-01-2009, 03:23 PM   #5
mr48chev
mr48chev's Avatar
I haven't done it but I don't think it would be difficult to do. There is plenty of lateral movement as the arms on the bottom of the column swing through a pretty good arc when you go between first and reverse or second and third. I think the 54 pickups with Automatics had a shifter that wasn't far removed from the column shifters for three speeds.
Looks like a sneaky way to put in an automatic.
The big thing will be getting the lever on the shift rod out of the trans in sync with the lever on the column. One of the goodie vendors used to make and sell a lever for the trans that was adjustable both in location and in travel of the shift rod but a bit of junk yard hunting would probably produce a lever that would suffice.
Old 02-01-2009, 04:02 PM   #6
whitetrash_elky
thats the idea!
Old 02-01-2009, 04:41 PM   #7
Wrenchbender Ret
Its been done but is not safe. There is no lockout for park or reverse. It would be awful easy to shift to reverse or park at the wrong time.
Wrenchbender Ret is offline   Reply With Quote
Old 02-01-2009, 04:46 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
That just puts the thrill back into driving.
Old 02-01-2009, 05:11 PM   #9
BIG CHEVY 3600
Good point. what about setting it up so that reverse is where second gear was and drive is down where low was? But what about D2 and D3 and Neutral?
Abraham Lincoln
Old 02-01-2009, 11:41 PM   #10
OrrieG
OrrieG's Avatar
I drove mine for a while with a pretty worn out Camaro floor shifter that would not hold drive or neutral. After shifting from 2nd to reverse the second time I got one that worked. Yes, its pretty thrilling especially to the person behind you!
Old 02-19-2009, 03:59 PM   #11
Sinisterspeed
Sinisterspeed's Avatar
There is supposed to be a lock out on floor shifters?
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
