LET'S GO...MOUNTAINEERS
Electric radiator fan
I have a problem with my Old Air Products radiator killing my battery. I know this has two sides, one for all time use and one for controling. My problem is, I have it wired up so as soon as the key comes on it comes on. I want to wire it up so it won't come on until after the truck is started. It is taking alot out of my battery. Does anyone know how to wire this up? I wish I could wire it up so one side works at one temp and the other works at a higher temp. Right now it won't let the temp get up above 160. Any suggestions will be welcome. Thanks in advance.
72 SWB/Step Last edited by westbrookw; 01-17-2009 at 11:25 PM. Reason: title was wrong |
Junior Member
Re: Electric radiator
First you could control the unit with a toggle switch and relay so it does not come on until you flip the switch.
Does it have an adjustable temperature controller? Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
It has an adjustable for the second fan. I was looking at doing the toggle.
72 SWB/Step |
its all about the +6 inches
hook it up so neither one comes on till it's needed. (getting hot)
The way you have it now, you are just burning up the electric motors, killing your battery, shortening the life of the charging system, and making lots of noise that you don't need. |
Junior Member
I forgot to mention earlier that I have a dual fan setup on my '92 GMC K-3500 and they are both controlled by the the temperature controller.
Just like LHM said. Danny
How would you hook that up? I am not a wiring gew rew.
72 SWB/Step |
Old member
Do you have A/C? If so hook one up to it so it only comes on when you have the A/C on.
The other one can work off the ground of the temperature senor in the block. Put hot wire to relay and fan and run the ground to the senor. When the temperature senor grounds so does the fan and walla it comes on. If you don't have A/C then hook both up like I said and add a toggle switch into one of them to control yourself.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-18-2009 at 09:13 AM. |
just make sure that sensor is actually made for controlling the fans, and not a dummy light.
I would also add, you are better off with the sensor in the rad, and not in the engine. You are trying to cool the fluid in the radiator, not the fluid in the engine. |
Wired them both together and put a switch in the block. Works like a champ.
72 SWB/Step Last edited by westbrookw; 02-22-2009 at 03:11 PM. |
Old member
Glad you got it working.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanx. I had to buy a couple different switches until I got it right. I tried a switch out of a Camaro, but it was set too high. The truck would almost over heat and not even kick the fan on. So, my buddy looked up another switch set close at a lower temp. Works like a champ. That fan only runs for about a minute before it kicks off. Doesn't use a lot of power now.
72 SWB/Step |
Old member
What part of NC. I was born in Charlotte. Are you going to the meet in April? Here is the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=321985
I wish I was going! That is my wife's B-day. I know, I know. She will have more, but she is also pregnant. I am going to go to the Raleigh auto fest on the 13-14 of March. I am from Southern Pines, NC. Just south of Raleigh on US 1.
72 SWB/Step |
Oh that meet. I thought you were referring to the Good Guys show and swap meet in Charlotte on the 3-5. I want to go to that meeting. We will see when it comes time.
72 SWB/Step |
#15 |
Old member
I lived in Raleigh for a while but was only like 2 years old at the time. I have lived all over the south with dad working for GM it was like living a miltary life. We lived in Charlotte 4 times before I moved out on my own.
The meet is in Salisbury NC.
#16 |
Yeah, I will try to make it to the meet. I am in the military myself. I have recently moved to the reserves so my daughter and baby on the way wouldn't have to move a lot.
What is up with the Site Supporters putting up pictures of junkyard red 'stangs?
72 SWB/Step |
#17 |
Old member
I don't know about the junkyard red 'stangs. In lighten me please.
#18 |
It isn't 'stangs. One other supporter that has been in touch with me has a pic of a red s-10 extreme manguled on his avatar also. Just wondering if it was a game like one of my other forums I am a member of.
72 SWB/Step |
#19 |
Old member
That was my daughters Blazer she flip awhile back. She was 17 when she wrecked it now she is 21. Yea he sent me some pictures of it after he saw mine.
Tags |
old air, radiator, wiring |
