Old 04-13-2009, 05:27 PM   #1
bsgmcc20
Im afraid of purple hangers..
bsgmcc20's Avatar
396 Big Block starter? 1970? help?
http://static.summitracing.com/globa...i-356000_w.jpg
Ok, so i have this 70 gmc with a stock 396 with a automatic tranny. The starter has been chirping and today the solenoid started to spin with no flywheel engagement. So I crawled under her today to yank it out. taking off the heat shield from the starter. ( yes the battery is disconnected) and start to go after the positive cable and the ingnition wire. the cable post comes off in my hand with the bolt and nuts from the solenoid with out even using a wrench. So I have to take her off now for sure. As I get to the Staggered bolts holding her up backing them off one of the cast "ears" falls an inch from my forehead on the ground. Great this thing is in in pieces. So i take it to the "parts changers" to get a re-manned starter. And there computers are telling me that my truck only came with a 350 or 402. Nice to see there computers are up to date on motors. LOL
So I call a mobile mech. I know who shoots me to his parts guy. They tell me that most of the starters they have to fit a big block are aluminum housings and not cast. He called the "warehouse" who works on there rebuilds and says they can fix mine if i send it out.
So now that my short story is long. here are my questions.
1. Will they keep my Starter housing and just replace the cast nose housing and solenoid?
2. Is the attached picture i got from summit a high torque it looks alike to mine minus the yellow powder coat?
3. Could they substitue a high torque for a low one on me?
4. Is there any other year or make that i can use to chase down parts for my 396 out of my 1970 gmc c-20?
bsgmcc20 is offline   Reply With Quote
Old 04-13-2009, 05:32 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 396 Big Block starter? 1970? help?
your 70 has a 402, there computer is right.
They never made another 396 big block chevy after the end of the 1969 model year
Old 04-13-2009, 07:08 PM   #3
72chevyk10
I built it
72chevyk10's Avatar
if you have a 168 tooth flywheel all the starters should be the same.(on a auto trany)
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 04-13-2009, 07:55 PM   #4
WillW23
I stay away from the high torque starters. I had one eat up my new flywheel on my 68 Chevelle SS 396. Try a NAPA store, they have new starters that look and fit just like originals, on your 402. I assume this is a slant offset holes starter.
WillW23 is offline   Reply With Quote
Old 04-13-2009, 08:57 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Advanced Auto carries rebuilt delco remy starters for around 100 bucks with a lifetime warranty
I put one onto my big block and it works just fine
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 04-13-2009, 11:53 PM   #6
bsgmcc20
bsgmcc20's Avatar
So the Protect-O-plate should of said 402 and not L-47 396 like it says? ?
T0804TBG was stamped on pass. side head plate
Code Year Model CID HP Trans Comment
TBG 1970 Truck 402 310 400 L-47 10, 20, 30
Ok now i feel like a rookie..... I sent the starter out to a shop to rebuild the starter from the truck. I didnt get a replacement. Im having mine rebuilt.
So i need to rethink and check what the previous owner had installed? would it matter if it was a part for a 396 block?
Old 04-14-2009, 09:20 AM   #7
70cstjr
70cstjr's Avatar
[QUOTE=bsgmcc20;3255907]So the Protect-O-plate should of said 402 and not L-47 396 like it says? ?
Ok now i feel like a rookie..... [QUOTE]
dont feel bad, its ok to learn, my dads 70 cst shows the option code L47 and shows a 396 but the L47 option code is for the 400 also his SPID shows he has west coast Jr Mirros and yet below the eyeline mirrors have been installed on it from day one so go figure lol..cant always trust what they tell ya
PROJECT CIRCUIT RIDER
70cstjr is offline   Reply With Quote
Old 04-14-2009, 04:35 PM   #8
Longhorn Man
I'm almost certian that the casting numbers remained the same.
Either way, if it is original, it isn't a 396.
Old 04-14-2009, 05:35 PM   #9
leddzepp
Moderator
leddzepp's Avatar
[quote=70cstjr;3256266][QUOTE=bsgmcc20;3255907]So the Protect-O-plate should of said 402 and not L-47 396 like it says? ?
Below eyeline mirrors/west coast jr are the same thing. On my SPID it lists "below eyeline mirrors" On the build sheet, they are listed as west coast jr. The 67-68 west coast jr mirrors are different than the 69-72 ones, in that they are long and vertical. Also 71-72 uses slightly different mounting arms than the 69-70.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 04-14-2009, 08:34 PM   #10
Mike C
Mike C's Avatar
I had a cast iron nose starter on my '70 402. I had all sorts of hot start problems and ditched it for a CVR mini-starter. Best $150 I EVER spent. I had a battery with a failed cell, only 10.2 volts max, and it still cranked 'er up until I got a new battery.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-14-2009, 09:32 PM   #11
leddzepp
Moderator
leddzepp's Avatar
x2. A high-torque mini starter is the only starter I will buy from now on.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 04-15-2009, 01:01 AM   #12
longhorn70gmc
longhorn70gmc's Avatar
I bought a starter for my 402 at Kragen 8 years ago. Here about two weeks ago I took that old starter in with the receipt and walked out with a new one for 0 cash. I was so happy. I know Kragen will have one for your 396 or 402 BB. Good Luck!
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 04-15-2009, 01:17 AM   #13
mr48chev
mr48chev's Avatar
If nothing else is wrong with your starter you should still be able to buy an new End frame for it. But by the time you buy a solenoid, brushes, bushing for the commutator end and drive you will probably have more in it than buying a top quality rebuilt starter.
Old 04-15-2009, 01:24 PM   #14
bsgmcc20
bsgmcc20's Avatar
The main body of the starter is still good. the end frame has a cracked "ear" and the solenoid was broken and loose. I have it being rebuilt, I hope to hear from them today. The quote i got was $35. for the cast frame. and then what another $40. for the added work?
So I will see. Im just trying to keep this ol' dog as close to what orginal as i got it in. You know the old saying if its not broke dont fix it. I learned that a long time ago. If it is working why tear it all apart. atleast not yet that is...
Old 04-15-2009, 03:15 PM   #15
bbadfred
bbadfred
bbadfred's Avatar
I never have had a problem with hi torque starters on big blocks unless you do not have the starter brace. Even with the two front bolts tight without the brace the starter can move sideways a bit and break flexplate teeth or break the starter drive. the brace fits on that long bolt on the starter and the holes in the block close to the starter.
bbadfred is offline   Reply With Quote
Old 04-18-2009, 11:15 AM   #16
bsgmcc20
bsgmcc20's Avatar
I am interested in that "starter brace" does anyone have a pic of one?
I just got my starter back. new end frame and solenoid. I am only out $45. better than the 199. quote i got from the "parts changers" outlet.
While i am under there bbadfred i will look for he bolt area you speak of and see if i can fab up a brace. thanks for the heads up on the support brace.
Old 04-18-2009, 11:26 AM   #17
mr48chev
mr48chev's Avatar
The auto electric shop that I take my stuff to when I can't or don't want to do it myself http://www.smithae.com/ charges just about the same to rebuild your starter or alternator as you would pay for a rebuilt at a parts house.
40.00 Labor doesn't sound out of line as it usually take about an hour for me to rebuild one.
After reading about the troubles a lot of guys are having with the "high torque" gear reduction starters on some of the other boards I think I would rather have a good strong starter that was built for the application to begin with.
Old 04-18-2009, 11:31 AM   #18
americanmusc1e
americanmusc1e's Avatar
The only difference in a 396 and 402 is the name. same bore/stroke, same displacement, all parts should interchange--as long as its a big block and not a 400 small block, which wasn't available in these trucks anyway
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 04-18-2009, 11:37 AM   #19
mr48chev
mr48chev's Avatar
I think this should be the correct starter brace
http://gilbertautoparts.com/Starters...s/03965588.jpg
Scroll down the page to starter braces
http://gilbertautoparts.com/Starters...arts/index.cfm
You should be able to order it at your local dealer.
Old 04-18-2009, 06:10 PM   #20
bsgmcc20
bsgmcc20's Avatar
Thanks for the brace picture. If I get the time I will pick it up. just to have most the parts if not all of them back on it.
now to the sadle tanks.... arg
