Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-15-2009, 10:58 PM   #1
Captainfab
60-66 Nut
Impala SS Rear Disc Brake Brackets
Here is my latest design of the Impala SS rear disc brake brackets. These are laser cut out of 1/4" with 1/4" spacers stitch welded on and then tapped M12 x 1.25 for the caliper cage attachment bolts. These brackets will bolt onto the truck 12 bolt rear differentials from '64-'82 and the 10 bolt truck differentials from '79-'87. The price on these is $115.00 plus a flat rate shipping of $9.20. This pricing is always current and up to date. PayPal is preferred, but I will also accept money orders. The package includes one pair of brackets plus grade 8 fasteners to attach the brackets to the axle tube flange and the metric bolts to attach the caliper cages to the brackets. This setup is for the 5 x 5 bolt pattern.
If you would like a set, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
Old 04-15-2009, 11:05 PM   #2
joe231
joe231's Avatar
Re: Impala SS Rear Disc Brake Brackets
Another nice product
What did the impalas use for e-brakes?
will the impala rotor fit the axle with out any modification?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-16-2009, 12:47 AM   #3
Captainfab
60-66 Nut
The Impala e-brake was a shoe setup inside the rotor which would be a little difficult to adapt to a 12 bolt truck diff. The Impala rotor fits over the axle flange with nothing more than slightly opening up the center hole to slide over the step on the axle flange. A die grinder and a flap drum will do it is 5 minutes or less.
Old 04-16-2009, 07:54 AM   #4
badboy007
badboy007's Avatar
I'll take a set. Paypal on the way.
badboy007 is offline   Reply With Quote
Old 04-16-2009, 02:44 PM   #5
kamikazekyle05
kamikazekyle05's Avatar
Do you use the truck rotor or impala rotor?
kamikazekyle05 is offline   Reply With Quote
Old 04-16-2009, 05:18 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Uses Impala SS or Caprice/Roadmaster rear rotors.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-16-2009, 10:38 PM   #7
Captainfab
60-66 Nut
I haven't received it yet.....as soon as I do I will send a set out to you. Thanks
Thanks for replying Josh. I see you got yours today, have you put them on yet?
I'm not aware of any 5 X 5 truck rotors that would work on the rear.
Old 04-17-2009, 10:40 AM   #8
STOCKISH
STOCKISH's Avatar
They're on there buddy. Fit and quality is perfect. Couldn't ask for a better product or better service. Thank you.
--Josh
Old 04-17-2009, 11:52 PM   #9
Captainfab
60-66 Nut
Thanks for the compliment Josh.....and for the purchase too
Old 04-18-2009, 01:24 AM   #10
yellowGT
yellowGT's Avatar
If you have spares put me down for a set. Do you have the part numbers for the brake set-up?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 04-18-2009, 01:30 AM   #11
yellowGT
yellowGT's Avatar
hey cap... do you also make them for the ten bolt rearends?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 04-18-2009, 01:53 AM   #12
yellowGT
yellowGT's Avatar
payment sent. Cant wait to see how this app. fits and look on my truck. My brother might want a set too so Ill let you know.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 04-18-2009, 11:03 PM   #13
Captainfab
60-66 Nut
What year of 10 bolt? Are you referring to a 8.5 truck 10 bolt? If so I'm pretty sure the ddistance from the axle tube flange to the axle flange is the same as a 12 bolt. So they should work but I would need to verify that, unless someone here can.
I'm working on putting together a list of parts and part numbers. You basically need rotors, calipers, factory caliper brackets, pads, and hoses for a '95 Impala SS. You will also need a brake line adapter to go from metric to SAE.
Old 04-23-2009, 08:35 PM   #14
SCOTI
SCOTI's Avatar
What do you recommend for the prop valve when adding the Impala rear discs?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-23-2009, 11:09 PM   #15
Captainfab
60-66 Nut
Well not having completed an install myself, I can't make a recommendation from experience. However I do like the tuneability of having an adjustable valve on the rear line. There seems to be a few different combinations that work for those that are running 4 wheel discs. Some have good luck with the disc/drum prop valve and an adjustable for the rear. Some switch to a specific disc/disc prop valve with good results. And others use only an adjustable valve for the rear. I believe that the different bore sizes of master cylinders as well as the piston size of the calipers used plays a role in what works as valving in a given brake system.
With that said,as for the Impala rear brake conversion, I think I might recommend seriously looking at the components that GM used on the Impala for a start. Although the weight bias of a pickup is likely to be a bit different than an Impala. Also the weight bias from one pickup to another will be different in how the truck was built. This is mainly why I believe an adjustable proportion valve is beneficial to the brake system.
BTW Scot, how did that booster bracket work out for you?
Old 04-24-2009, 12:00 AM   #16
SCOTI
SCOTI's Avatar
It looks great . . ... sitting on a shelf full of parts (Vette MC, Malibu booster, Porterbuilt Dropmember, 350/700R4, van tilt, blah, blah. blah.... Also should have a couple of steelies on the way .
The parts are waiting to come together but I've gotten behind on building the frame for my retroRod project so everything else is delayed as well. Should make for a busy summer. There will be a thread w/details soon.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-03-2009, 09:15 AM   #17
chas350
Hello Captinfab,
what did the impala use for an e-brake?
is everyone using a rear disc with out an e-brake?
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 05-03-2009, 11:02 PM   #18
Captainfab
60-66 Nut
Originally Posted by chas350 View Post
Hello Captinfab,
chas
The Impala SS used a shoe setup inside the rotor for an e-brake. So using These brackets on your truck won't give you an e-brake. If you need to have an e-brake, you'll have to buy the Camaro caliper brackets that glock35ipsc is making. Thanks for inquiring.
Old 05-07-2009, 10:54 PM   #19
Dahawk
What front set up matches the ss caliper?
Dahawk is offline   Reply With Quote
Old 05-07-2009, 11:38 PM   #20
Captainfab
60-66 Nut
[quote=Dahawk;3299044]
The Impala SS used a shoe setup inside the rotor for an e-brake. So using These brackets on your truck won't give you an e-brake. If you need to have an e-brake, you'll have to buy the Camaro caliper brackets that glock35ipsc is making. Thanks for inquiring.[/QUO
The Camaro or Impala's front calipers would match, but I don't know how you would mount them to the spindles on your truck. The biggest issue would be the thicker rotor on the trucks. The aftermarket might be the option for that. I'll have to do some looking and see if there is an OEM caliper that would work.
Old 06-24-2009, 10:34 PM   #21
Captainfab
60-66 Nut
I have one set of these brackets left......I'll throw in a pair of Metric to SAE line adapters for free with this last set.
Old 06-30-2009, 03:41 PM   #22
Outlaw72
Hay Team!!
Outlaw72's Avatar
Capt....please check your PM's as I am interested.
I'm also curious to know what the diameter of the impala rotor is? Can you get me a measurement from the center of the axle to the highest point on the caliper? My wheel has a 7 inch backspacing so fitment is going to be close depending on the dimensions. Thanks in advance
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 06-30-2009, 04:32 PM   #23
61superman
61superman's Avatar
r there any left i would like a set please send me an invoice
adsendejo@comcast.net
thanks
61superman is offline   Reply With Quote
Old 06-30-2009, 11:24 PM   #24
Captainfab
60-66 Nut
PM sent, I'll let you know in the morning. Thanks
thanks
Right now I only have one set left and Outlaw72 gets first dibs, so if this setup won't work for him, you're next in line. If I could get 2 or 3 more sets sold, I'd make some more.
Old 07-01-2009, 03:44 AM   #25
61superman
61superman's Avatar
hey captinfab
just so you know i would like to buy two sets thats not a problem. let me know either way
