6 Lug Rally Wheel Center Caps
I just restored some 15x7 6 lug rally wheels (post 1973) that I put on my 1968 truck. My truck is 2wd 1/2 ton c10 so I do not need the big 4x4 caps that I have for any clearance issues.
Does anyone make a modified (smaller) center cap for these 6 lug rallies for 2wd trucks? Seems like someone should since I see a ton of these on 60-72 trucks. Thanks.
-mgf- 1968 Chevy LWB.
Lowered. 15x7 rallies and BFG's. Built 350. Dual Flowmasters. Fast and Loud. |
I am a Referee of life.
Re: 6 Lug Rally Wheel Center Caps
Subscribed.I been trying to come up with something since I really don't like the original 4X4 caps.I wish they had nubs to run baby moons or poverty caps.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
67-72 parts collector,…
![]() Join Date: Nov 2002
I run these on my '69 6 lug ralleys.
You can find them on ebay. They require a 7/16" conversion lug nut.
'69 Chevy SWB
![]() Join Date: Feb 2009
I picked up a set of those about a month or two ago. what all do you need you change when doing this conversion? just lugs or lugs and studs? If i change studs do you have to drill the hub to the studs or do they just press in? By the way lolife99, you really were busy on that orange '69 when i was there it was damn near to the frame. NICE!! I wish i the time and room to get that busy on mine.
Are those chrome or the reproduction ABS ones? These are the ones I restored, they are just huge.
its all about the +6 inches
the ones above were always chromed plastic. They are off later model GM trucks. I have 5 lug verson of that on my burb
Is there small "bosses" on the back of those new style caps you could drill and screw from the backside?
![]() Join Date: Mar 2006
I put 6 lug 16's on my 70 newer style wheels and I got the lugs from stockton wheel they a not that expensive!
http://www.stocktonwheel.com/ |
yep. That's how I did mine.
Here's the thread for my rim job (wheel restoration) http://67-72chevytrucks.com/vboard/s...d.php?t=281527 |
Here's a shot of the 6lug versions.
Your wheels are 8",no 7" 6-lugs made.The conversion lugs are the same duplex style but in sAE thread to go on earlier truly American trucks.The plastic hold-down lugs are black,if you go that route.
I likr=e the later style,but the originals look fine.Guys were doing what you are doing way before the`88s came out.You get the center stickers for the funky wheel covers from late-70s-95 with the fake pyrmid nuts.
chevelito
chevlwb68 - I like what you did with the rims...are those trim rings or did you just paint the middles only?
thanks, Jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
[QUOTE=special-K;3280385]Your wheels are 8",no 7" 6-lugs made.
Incorrect. I own two 7" 6 lug ralleys. They aren't very common,... but they did make them.
Here's my 7's and 8's on the my '69.
#15 |
I`ve never seen factory 7" rims.What 4wd did they come on?I`m open to learning something new.
#16 |
Me too.I could use some 7's to bring my fronts in instead of having them out that extry in.
#17 |
All four are 15x7". GM factory stamped. Do not know what they came off or exact year except I know they 73 and up. I got them off a guy on craigslist for $65 bucks. Sanded them down to bare metal and primed them. Then I used Duplicolor's Performance Wheel Coating paint in a rattle can, Silver, and painted the whole wheel. Turned out great. I primed and painted the fronts, backs, and the middle part you do not see under the tire. I have a buddy who does paint at Napa so I had him use the Spectra Eye Gun and get as close of a paint code for the truck color as he could . Mixed me up a quart of that in Enamel Lacquer. Shot the middle with of the wheels with that using a Siphon Paint spray gun.
The beauty rings are the 3'' deep dish ones. Kinda wish I would have the done the 2'' ones, but oh well I got a good deal on them. I got the rings brand new for $60 (all 4) at the swap meet. They are the SS ones, not the pop can aluminum Taiwan ones. The Center Caps I got at the swap meet also for $20 bucks for all four. Used and beat up. Peeled off the center faded metal stickers, scrubbed them with steel wool, and then buffed and polished them with Blue Magic chrome wheel polish. Running BFG Radial TA's. Front: 245/60R15 Back: 275/60R15. I spent a lot of love and time with these things. I like to stare at them a lot now. lol. Hope this helps anyone looking to do the same. Here are some new pics I got of them.
#18 |
chevelito
perfect!
#19 |
Redefining LowBudget
ok you didn't hear this from me but if you have a hot rod shop for BIG trucks you can get a 6" center cap for there axles ...it locks on the edge of the nuts that hold the axle in on the hub of big trucks..the same should work for you...it wil look ike a baby moon.....as soon as my truck hits the road its heading the the shop to try some on
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#20 |
Let me know how that turns out and how I can get some.
#21 | |
I was telling member tcb-1 how hard they are to find,... then I meet him last year at the Lawerence, KS swap meet,... and there were 2 complete sets there. My buddy, member "hot trux",... also has a pair. I've had one wheel for many years,... trying to find another one, to make a pair. I finally found the second one about 2 years ago.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-07-2011 at 12:38 PM. |
#22 |
Ok,so they were prolly used on TerraVans.I guess they need a narrower track.I can see the wheels look different.Look kinda like a Yota wheel profile,but GM style.Those would be rare.
#23 |
okay so I just realized also that the 6 lug wheels have 10 holes (openings?...don't know what to call them) in them, while the 5 lug have 16. interesting, but cool......so it does seem to be a little rare.
#24 |
The 8" ralley have the same 10 holes (slots) They are a little bigger slots than the 5 hole ralleys.
#25 | |
![]() ![]() (Just worked out that way,not into tit for tat ![]()
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-28-2009 at 07:44 AM. |
