Old 06-22-2009, 04:06 PM   #1
drob_NY
Question -Difference Between 1/2 & 3/4 Ton Chassis
I am currently looking for a frame for my 1968 4x4 1/2 ton (Chevy) and was wondering if anyone could advise me on the differences between the 3/4 and 1/2 frames. I have found a 1972 3/4 rolling chassis (GMC) but I would like to stick with my 1/2 ton running gear and suspension. Are the frames the same? Will the 1/2 ton running gear and suspension bolt up to a 3/4 frame? If so is it a major fabrication project? Any advice is appreciated.
DROB_NY
drob_NY is offline   Reply With Quote
Old 06-24-2009, 02:32 PM   #2
vexvader
1967 C10 SWB
vexvader's Avatar
Re: Question -Difference Between 1/2 & 3/4 Ton Chassis
I noticed that no one has answered your question so I will give my 2 cents. I am not a 4x4 guy but I would think that they are the same. GMC and Chevy used the same basic frames for all of the 1967-72 C10, K10, K5. They just had different brackets and attaching points. It doesn’t take much fabricating to swap any of the frames between each other. I believe that it is the same for swapping a C10 to a C20 and so on. As long as you are going 4x4 to 4x4, I think you should be fine. (remember there is always some fab work even with “over the counter bolt on” parts)
If it were me, I would spend some time taking a few measurements on the 2 and you should be able to figure it out with out too much effort.
Just a thought? Why not use the ¾ running gear. You would have a much stronger foundation for your project.
Are there any 4x4 guys out there that can help???
Keep up the good work!!
vexvader is offline   Reply With Quote
Old 06-24-2009, 03:24 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I'm moving your thread to the 67-72 forums instead of the projects forum. You will get a lot better response there.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-24-2009, 05:18 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the bare frames are the same.
Old 06-25-2009, 08:04 AM   #5
old Chevy guy
old Chevy guy's Avatar
What kind of condition is the 3/4 frame you are looking at ? I have a 1/2 ton rolling frame that I was getting ready to change over to 3/4 ton. It is in really good condition.I am in R.I.,its not exactly across the street but its not that far either. I drove there to see a dead show in 83. My frame is a 69 and I have all new brake drums,pads, wheel cylinders and hardware for all 4 wheels.Maybe a swap would save us both a lot of work?
old Chevy guy is offline   Reply With Quote
Old 06-25-2009, 09:55 AM   #6
lpaine
lpaine's Avatar
The trac bar brackets are different 1/2 to 3/4 ton, ask me how I know!
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 06-25-2009, 10:57 AM   #7
Longhorn Man
he has a 4x4
Old 07-01-2009, 08:49 PM   #8
drob_NY
Thanks to everyone for all the feedback, especially vexvader for breaking the ice.
DROB_NY
1/2 ton, 3/4 ton, 4x4, chassis, frame
