#151 |
Badass
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
im liking the hole black and sliver thing going on
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#152 | ||
we'll see about the crank. i'll need to bust into the bottom end and get new rods and stuff and i've never dealt w/ that before besides high school auto. so i'll start looking into it. thanks again!!! ![]() ![]() ![]() Quote:
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 07-04-2009 at 04:11 PM. |
#153 |
got the passenger side rear brakes done today and started sandblasting the driver side gas tank brackets. got one done and ran outta sand. need to go buy a double flare tool and pick up more sand. gas tank sending unit sock/filter should have been here by now and still waiting for the anti-squeek kit so i can get the tanks on.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 07-04-2009 at 06:11 PM. |
#154 |
You can use the same rods for the stroker combo (383). It will typically want different pistons though.
#155 |
Yeah my gas tank is still sitting in the floor.
#156 |
really nice build you have going on here. i love the black chassis with silver accents
![]() i'm curious about what equipment you're using for sand blasting? the parts really come out nice and i would love to be able to do the same ![]()
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#157 |
thanks man! as for the blasting im using a 6.5 hp 80 gallon mac tools air compressor. and a 5 gallon bucket w/ 30 grit sand from lowes. and a cambell hausfeld siphon feed gun. i recommend a sandblast pot rather than the bucket if your compressor isnt putting out at least 18cfm@ 120psi. the key is the compressor($$)... bigger is always better! and dont use play sand pay the extra for the good stuff so the gun doesnt clog and the finish is consistant. good luck man, some/most people hate it but i have learned to love it. beats the heck out of wire wheels and sand paper.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#158 |
Sand blasting is the easiest and fastest way to go if you have the equipment, and place to do it.
#159 |
another small but time consuming update
![]() 1st few are kinda random... got the gas tanks on ![]() ![]() ![]() just about finished w/ 1 of the mags and put it on. what a pain getting the nicks and dings out of this sucker. its not perfect yet but its going to have to do until i atleast get the others looking the same. ![]() heres the time consuming part... brake lines reflared, sanded, painted, and bent to my liking along with the fuel lines. ![]() i ran all the fuel lines through the frame for a cleaner look... ![]() ![]() ![]() ![]()
#160 |
![]() this is the line from the sending unit that goes to the canister. i ran it inside the driverside frame instead of on the outside. looks a bit cleaner w/ everything on the inside of the frame [ ![]() ![]() this last one is of the gas tank brackets after sandblasting just to show people how clean the metal looks after. ![]()
#161 |
Nice work!!
that is one sexy frame! ![]() ![]()
#162 |
Looks awesome man!!!!
#163 |
![]() Join Date: Jul 2009
Wow, just read this whole thing and I must say that it looks GREAT! You are making great progress too. Keep it up.
#164 |
#165 |
the frame is upside down in those pics and the frame is bent like that from the factory for the big cat. converters they used to use i think. i have checked under alot of trucks and they are all the same. (i was worried too!)
#166 |
Cool! I just wondered. It does look great though!
#167 |
Fire Truck
Everything is looking awesome man!
-Nick '83 Chevrolet Silverado Stepside ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=349394 |
#168 |
hey, thanks a ton guys!
next is front rotors, bearings, seals, calipers, bolts, pads, rubber hoses, prop. valve and the brakes will be done. (of course after a few hours of sanding and grinding! ![]() ![]() good times!!!!!!
#169 |
SWEEEET!!! man that looks great! did you use a factory switcher for the dual tanks or what? on my 83, it has been sitting for a loooooong time and I was thinking of replacing it. just curious to see what others use in that dept.
#170 |
Welcome Back from the well needed vaca
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
#171 | |
hey animal!! thanks man... been off work for a knee surgery since june. i think the doc is going to send me back to work next week. so its back to reality. ![]() ![]() we need to have a get together sometime soon!! ![]()
#172 |
Sounds good Dennis
#173 |
![]() ![]() all i need now is new prop valve, steering gear box and front shocks. and this baby will be ready to roll down the driveway! ![]() ![]()
#174 |
Awesome man!
#175 |
man thats sweet. it looks so good. i cant wate tell its on all 4s agen its gona looks so awsome also the rims are looking amazing they really shine now.
