#76 |
Tot Roddin'
Re: 1966 Chevy SWB Gasser influenced truck
Man that thing is sick!
Awesome work!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#77 |
1962 C-10
SICK!!!! I friggin love this truck.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#78 |
Chevy Chica
Awesone truck!!!
~La 'Mona' Lisa ![]() |
#79 |
Still working on it time for some pics
#80 |
PICS before and after I moved rear crossmember
#81 |
Spear and magic helmet!
Much better
-- Will |
#82 |
*NO REGRETS*
This truck kicks ASS for sure! Cool build!
#83 |
wow!!! . very cool
#84 |
I've always wondered if I should move the front wheels forward and inch or two. The front wheels always seem like they're set to far back toward the rear and the space in front of them bugs me. I'll either move it or fill the whole space with rim and rubber. Probably the latter.
Great lookin' truck.
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 07-09-2009 at 04:42 PM. |
#85 | |
#86 |
very cool and such an improvement!!!
NICE WORK!!
#87 | |
![]() if you move dropmember forward and not motor motor will have to raise atleast 1 1/2inches more than the 2inches it already does. If you slide motor with dropmember motor gets close to rad electric fan a must. Thought about all this briefly then nate told me dropmember centers wheel in wheelwell when air out I decided not to mess with it. Hope this makes sence not good at typing better at talking ![]() |
#88 |
The DM does move the spindle C/L farther forward vs. the factory (1.5" IIRC). Did you want to move it another 1.5" forward?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-09-2009 at 09:47 PM. |
#89 |
Schlongbed MEMBER (heh)#15
Great thread. Everytime I see the dropmember in action I fall a little deeper in love.
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
#90 |
Rods
![]() Join Date: Nov 2002
I'm going to have to look into moving mine now.. after i stretch the cab. ill have to look at the best way to move the axle rearward.. thanks another project on the plate.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#91 |
Keep in mind that everything attached to the trailing arms is affected when the rear wheelbase is moved.
#92 |
Rods
yeah. I am goin to bags I think so that shouldnt be a big deal.. also. shock mounts will change when i bag anyway. but I think its woth the effort if I can make it look as clean as that is.
#93 |
#94 |
#95 |
Wow.... That's a bunch. I wonder how it would look? I guess in pics your front wheels look just about right to me. Do they still appear to be too far back in person?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-10-2009 at 01:12 PM. |
#96 |
I am digging this mucho. Nie work.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" |
#97 | |
![]() ![]() ![]() ![]() My computer is broken on a friends will post more updates once I take more pics and save to my NEW computer ![]() |
#98 |
Gotcha. I'm doing the 1.5" F/R for 3" of total 'stretch'.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-18-2009 at 07:51 PM. |
#99 |
Resistance is Futile
I noticed this effect on my pick-up, too. I thought maybe I had bolted the suspension together wrong way back when I did the work
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#100 |
"Where were you in '62?"
![]() Join Date: Jul 2004
The Frame on my 62 has been Modified and Altered. I have a Mustang II IFS Clip on the front and the Wheelbase has been extended to 117". The front wheels were too sunk in so I bought some wheel spacers and put them on. Brought the wheels out a little more close to the fender.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 07-19-2009 at 09:23 AM. |
