07-18-2009, 09:32 PM | #1 |
LMC rear gas tank install
Has anyone done a LMC rear mounted gas tank? I bought it as a kit but there was no instructions. This is how it came out when I did it. Of course, there had to be alot of modification.
07-18-2009, 10:20 PM | #2 |
Rods
Re: LMC rear gas tank install
would be nice if you did a install tech kinda thing...
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
07-19-2009, 07:13 AM | #3 |
1# Drobmember in Germany
Hereīs a few picīs of my LMC Gas tank kit!
thatīs my way to install the tank!! Pat |
07-19-2009, 10:08 AM | #4 |
Rods
nice install. what did you have to do to get it in there
07-19-2009, 11:16 AM | #5 |
that looks nice fellas!!!!
CHEVY ONLY |
07-19-2009, 12:20 PM | #6 |
thatīs really simple , put the tank under the frame , put the metal straps in place and bolt on the straps on the left side of the frame , on the right side of the frame drill two holes in the underside of the frame , drill upside two larger holes in the frame (see pic #2,it shows the passenger side with the two larger holes), put the bolt from the straps thru the frame on the right side and put the fasteners thru the frame on the bolts ! DONE!!!!!!
i hope you understand what i want to say! Pat Last edited by Apache63; 07-19-2009 at 12:21 PM. |
07-19-2009, 07:13 PM | #7 |
apache63 the tank looks great but your going to run into issues when you go to install the bed. The first cross sill in front of the rear will hit the tank and fill neck without a ton of mods. jessy66 in the first pic has the right idea with the flush top mount. Hope it all works out for you.
07-19-2009, 07:44 PM | #8 | |
Registered Loser
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. Last edited by creep; 07-19-2009 at 07:45 PM. |
07-19-2009, 10:15 PM | #9 |
60-66 Nut
IMO the way Apache63 did his is the best way to install them regardless of bed crossmember interference. That can be dealt with. I would rather have the tank as high as possible. Just my .02
07-19-2009, 10:20 PM | #10 |
I had to cut the frame a little bit for the gas filler neck. The bed went on with no problems with the gas tank flush mounted.
07-19-2009, 11:45 PM | #11 |
CHEVY ONLY |
07-20-2009, 10:22 AM | #12 |
Mine is done like Apache63. Some pictures are here. http://s49.photobucket.com/albums/f2...ucks/?start=40
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 07-20-2009 at 10:23 AM. |
07-20-2009, 10:49 AM | #13 |
Junior Member
"thatīs really simple , put the tank under the frame , put the metal straps in place and bolt on the straps on the left side of the frame , on the right side of the frame drill two holes in the underside of the frame , drill upside two larger holes in the frame (see pic #2,it shows the passenger side with the two larger holes), put the bolt from the straps thru the frame on the right side and put the fasteners thru the frame on the bolts ! DONE!!!!!!"
Huh? I think I need to see a close up of the bolts/holes!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 07-20-2009 at 10:50 AM. |
07-20-2009, 11:01 AM | #14 |
Cantankerous Geezer
You committed a major structural no-no with the way you cut the frame. I was looking at that last night, trying to come up with a solution that was feasible.
My first choice would be with a piece of round tube, say 4 or 6" diameter, welded to the inside of the frame. Something like the attached sketch.
Fred There is no such thing as too much cam...just not enough engine. |
07-20-2009, 12:15 PM | #15 |
True statment about the hight, but if it was me i would rotate the tank 180 so the filler neck is not over the mounting hole for the cross sill. Then the only mod would be to notch the center part of the sill.
07-20-2009, 12:29 PM | #16 |
Junior Member
Wouldn't that make it exiting very near the wheel well on the passenger side?
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
07-20-2009, 12:46 PM | #17 | |
CHEVY ONLY |
07-20-2009, 12:59 PM | #18 | |
iīll take this week some picīs from the frame and tank! the bed is already mounted and i fits perfekt ! but one cross sill i cut it into place to fit the gas filler neck! picīs can say more then 1000 of words!! Pat |
07-20-2009, 01:05 PM | #19 |
cool!
can't wait
CHEVY ONLY |
07-20-2009, 01:09 PM | #20 |
iīm fast like a bullet!!!!
found some picīs on my PC , i hope it helps!!! Pat Last edited by Apache63; 07-20-2009 at 01:10 PM. |
07-20-2009, 01:15 PM | #21 |
Pat, have you been holding out on us, or did I miss that you have a truck too?????
CHEVY ONLY Last edited by joe231; 07-20-2009 at 01:15 PM. |
07-20-2009, 01:30 PM | #22 | |
http://67-72chevytrucks.com/vboard/s...107362&page=18 Pat |
07-20-2009, 01:39 PM | #23 | |
Junior Member
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 07-20-2009 at 01:39 PM. |
07-20-2009, 01:52 PM | #24 | |
CHEVY ONLY |
07-20-2009, 01:54 PM | #25 | |
but i donīt know if it is the best way ! so i only can say try try try which way is the best way for you! Pat |
