Old 09-01-2009, 01:47 PM   #1
orbot
orbot's Avatar
Equus fuel gauge..
Anyone run this gauge ,they say it will work directly with gm floats
orbot is offline   Reply With Quote
Old 09-01-2009, 02:03 PM   #2
Gibson
Gibson's Avatar
Re: Equus fuel gauge..
I've been looking at them too and had the same question...
From what I've found researching it, the important stat to look for is:
"0 Ohms Empty / 90 Ohms Full"
I believe those are the resistances that all the factory senders used on any C10 truck from 73-87.
But hopefully someone more knowledgeable can confirm or correct this.
Gibson is offline   Reply With Quote
Old 09-01-2009, 02:30 PM   #3
orbot
orbot's Avatar
Yep i saw he same info, i already have the other gauges, Volts, Water temp, Oil press.
I think ill try it out.
Old 09-02-2009, 05:34 AM   #4
BIG KRIS
BIG KRIS's Avatar
How are there guages compared to autometer?My dads 85 has a sun pro tach and it is not accurate so i have been looking at other options but dont know anyone that has used equus stuff.
BIG KRIS is offline   Reply With Quote
Old 09-02-2009, 09:16 AM   #5
Damien
Damien's Avatar
My honest opinion of the Equus stuff is its junk. I used to use them in my endro car. It got to the point I would run two water temp gauge because one would fail. I never had a problem with the oil pressure gauge though. I would have used something else, but they were under warranty.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 09-02-2009, 03:33 PM   #6
orbot
orbot's Avatar
Well autometer aint all that people think of them, its just the brand!!
i rather go equus, besides i already have the other gauges equus.
Old 09-02-2009, 06:03 PM   #7
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have a full set of equus gauges they work fine for me and the price was wright to
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-02-2009, 06:12 PM   #8
orbot
orbot's Avatar
I have never complained about them..
How do you hook the fuel lever gauge??
I took my cab apart today because im going to do a cage and i wont be using the stock gauges, only the fuel level worked, so i only need the speedometer and a fuel lever gauges, so i got no idea how the work, when i took the gauges ou i did not see anything hoked directly to the stock fuel level gauge i only saw a plug with lots of wires on it.
Old 09-02-2009, 06:15 PM   #9
flamingbig10
6.0 powered square
you'll need a sender wire that's come from the fuel sender in the tank to the gauge, a + switch wire and a ground
Aaron
Old 09-02-2009, 07:15 PM   #10
orbot
orbot's Avatar
Seems easy enough!
Thanks.
Old 09-03-2009, 07:16 AM   #11
BIG KRIS
BIG KRIS's Avatar
So they are ok to use then.Flamingbird i want to do them just like yours.White face gauges in a white 85 sivlerado.
Old 09-03-2009, 07:22 AM   #12
BIG KRIS
BIG KRIS's Avatar
How much does a full set run?
Old 09-03-2009, 08:00 AM   #13
BIG KRIS
BIG KRIS's Avatar
And one more thing what size guages would i need for them to be mounted in stock locations.
Old 09-03-2009, 12:27 PM   #14
flamingbig10
6.0 powered square
Originally Posted by orbot View Post
Seems easy enough!
Thanks.
no problem
they work good
around 200 to 250 at O'reilly auto parts
for the smaller gauges 2" work and for the speedometer and tachometer 3 3/8 since they only make a 5" tach so it would require a overlay panel and a little more info on the gauges
http://www.equus.com/products.php?ca...=100_105&all=1
Aaron
Old 09-04-2009, 05:54 AM   #15
BIG KRIS
BIG KRIS's Avatar
Thanks!
Old 09-04-2009, 11:27 AM   #16
flamingbig10
6.0 powered square
no problem
Aaron
Old 06-02-2010, 06:56 PM   #17
jsmithbm
jsmithbm's Avatar
i bought several of them too! seems like the water temp doesnt always work. But the oil psi works great. Just bought the fuel gauge. Can you expand on the installation of the fuel gauge?
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 06-02-2010, 11:33 PM   #18
slamd83c10
i have the black gauges for everything, they wrok perfectly fine, the temp never fails, its a little slow in coming up to operating temp, it will stay on 130 for 10 minutes or so and then all of sudden it will pop up to 190, but its accurate...i love em for the simple fact they are a hell of alot cheaper than any others and look great
slamd83c10 is offline   Reply With Quote
