HaV0KSR559<~~~
anyone with custom woofer boxes in their trucks
can you please post sum pics so i can have a few ideas im leanin more towards 2 12s but not to sure how i will get away with it i will be relocatin the gas tank here shortly so theres a lil more space... thanks to everyone for your ideas
...1969_CUSTOM_1O
FLEETSIDE_LONGBED ![]() ![]() [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
Location: Sunny, Florida, some might call it South Alabama
Re: custom subwoofer boxes
There are a few companies that sell the shallow sub woofers and the shallow boxes, I measured some a while back at best buy i want to say. They will fit if you remove the seat. That is what I was thinking of going with.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
![]() Join Date: Oct 2005
Here's mine. I just wanted one small 10" sub cuz I'm at the age where I don't need to "bump".....just wanted quality sound. In the truck, my amp is mounted to the enclosure as well and you will have to use a shallow design sub. Even with the tank removed, there's not alot of space to work with and you will be limited to your choices of equipment.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
screamin eagle
heres mine
SCREAMIN EAGLE |
SactoJim, That is a nice box. Is your tank still behind the seat?
P.S. Looks like the truck isnt so bad either
![]() 69 burb/01 yukon chassis 65 Comet Caliente 289 4 Door Sedan 99 Millenia S (supercharged) 4 Door Sedan 02 Yamaha R6 69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136 building with a buddy: 85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194 Last edited by lclippard; 09-16-2009 at 11:55 AM. |
An American Soldier
![]() Join Date: Feb 2005
SactoJim,
That looks pretty sweet. I'd like to see it after it is installed. How will it mount in the truck?
Dan dan.brue@us.army.mil |
![]() Join Date: Aug 2008
You could try Bazookas also. I don't know what diameter the enclosure is but it might fit at the bottom where it is the roomiest (is that even a word?)
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
I have also been tossing around the idea with my truck.. Then i found 3 small leaks in my stock tank so its getting tossed out of the truck and going to be putting in the speakers when i get the extra money.. I dont really think you would need 2 12's in that small of a space.. Lol we have 2 12's in my Girls scion and it is more then what i would ever need... i think i am just going to go with one 10'' like sacto
#9 | |
70 Chevrolet=Obsession
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
HaV0KSR559<~~~
if i was to go with one sub it would have to be a w7 but thats a little too spacy for me rite now i think id b better off with 2 12inch mtxs im younger and i love bass...
id like for ppl to hear me coming from blocks loud pipes n super beat lol
...1969_CUSTOM_1O
#11 | |
HaV0KSR559<~~~
beautiful now this is what im looking for... what kinda amp is pushin that sub n how many watts??? and if u dont mind what thickness is that box???
...1969_CUSTOM_1O
Hey Jim, when you get that box in there will you take some more pics so we can see it installed? I was curious on how you were going to mount it to the back of the cab. It is a very nice enclosure by the looks of it!!!!
Here's some pics of it installed. Right now the thing fits nice and tight and nothing is holding it in and it's not going anywhere. I have to make a finishing piece that runs along the top (ribbed area) and use that to tie in the speaker box.
The amp in an old Soundstream Reference 405 amp...back when they made real quality products and I've had it for a long time as well as the door speakers. The doors already had gigantic holes hacked from PO, so I fabbed up a piece of flat metal to mount the components into. I also built an aluminum shield that is installed in the door that keeps water away from speakers. I'm just about done with some lower door panels to cover the speakers. ....anyway works and sounds just fine to me.
I bought 2 10" Rockford Fosgates Shallow subs and then covered some plywood with some vinyl to hold everything in place. Mounted an amp in between. Haven't heard how it sounds yet because I just got the wiring done...well, almost done.
67 Stepside Atomic Orange Fastburn 385 TH350 The wheels are fronts are 255-45-18 with 5" bs. 18x8 wheel rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit) Budget: A method for going broke methodically. You only live once! |
#15 |
Gearhead and audio junkie
I had two 8"s under my seat powered by a way underpowered amp wasn't half bad. Doesn't take much to bump hard in these trucks because the cabs are so tiny. I put a cheapy JL 10" in my buddies 82 toytoa 4wd and it is INSANE! SO much bass for a little cab. If I had the bucks I'd spend it on one of JL's thin 12"s
#16 |
Here was my cheap install two 8"s and two 6 coaxials crossed over at like 650 Hz. It cost me practically nil and wasn't bad but it wasn't great either but hey I got bored on a friday and said what they hay might as well.
![]() Last edited by mikajo39; 09-17-2009 at 09:25 PM. |
#17 |
![]() Join Date: Jan 2007
How much extra room do you get behing the seat when you take the tank out?
#18 |
About 6" at the bottom and it gets down to around 4" around 3/4 of the way up. Not a whole lot of room, buts its something.
#19 |
That's right, it's Copper!!
Here's mine.
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
#20 |
69 Fleetside
![]() Join Date: Mar 2009
Fastom, I plan on doing something resembling your setup once I move my tank, I bet with those rear components it really helps out the soundstage. Having no rear fill sucks...nice work!
Here's mine. I really like 8's in this small cab because they don't rattle it apart, just produce nice full bass from the music. I have 2 Polk 8's along with Polk 5.25 components in the dash and Polk 6x9's in the doors, powered by a Kenwood head unit(5.25's crossed at 100hz) and MB Quart DSC480(6x9's full range and 8's crossed at 100hz). It was a damn tight fit under the seat but I can't imagine needing anymore bump or spl for my 34year old ears...until I move my gas tank and rebuild it with 2 more 8's and a bigger box where the current tank is! ![]() Trying 2 box designs ![]() Settled on this one, as my 250lb butt still never touched it during excursion even with the old seat springs ![]() Wouldn't even know there was a badass setup in here, until your butt starts vibrating and your ears bleed... ![]() Last edited by Beatcoaster; 09-18-2009 at 01:37 AM. |
#21 |
Old member
OK here goes. This is fixing to get moved to the audio section since I'm posting mine. I know it will because every other one has too!
It's not a thumper but Brooks and Dunn sound great! Got the tweaters almost at ear level used the clothes hanger mounting hole to screw them in with. Built mini inclosure for drivers side three way. Passenger side is in the orignal case. Have 2 singles up in the dash above the radio. I have 2 amps. 100 watt and a 400 watt.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#22 |
HaV0KSR559<~~~
thats nice what size are those subs n whats the wattage on ur complete set up???
...1969_CUSTOM_1O
#23 | |
HaV0KSR559<~~~
whats the dimensions on them sub boxes you have i think i have sum in the garage... And did u fab them or buy them???
...1969_CUSTOM_1O
#24 |
69 Fleetside
I fabbed them myself, and will have to measure them tonight, forgot what dimensions I was using
#25 | |
HaV0KSR559<~~~
do you remember the width of the wood you used???
...1969_CUSTOM_1O
