Old 10-16-2009, 05:58 AM   #76
HarrisonTX
Re: 90 burb (( daily dragger))
Originally Posted by 87 dually burb View Post
the 3rd pic is with the 6" flip and no over load springs ( bottomed out on frame alot) 2" of travel in rear
the front is 3" belltech spindle and a SD bag kit the height you see in pic 3 is with the front aired out sitting on inner fender wheels
also note they are 31" tires it sat about 2" high in front at that time
So, thats not exactly a reccommended method? It looks real good, but if i was to do that, i'd drive it everywhere, with it being 2 inchs off the frame, im sure that destroys you after a while.
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 10-16-2009, 09:20 AM   #77
justpball
justpball's Avatar
LOL yea it would be ruff!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 10-16-2009, 11:07 PM   #78
87 dually burb
my short bus
87 dually burb's Avatar
shaved driver mirror
shaved tails added roll pan
shaved pass mirror and antenna
filled tailgate 1' from each end ( will round corner and add a mural later on like a jack label
nick named 80 proof
all spots are white primer with no body work yet
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 10-17-2009, 09:40 AM   #79
justpball
justpball's Avatar
any pics of the rear setup?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-17-2009, 11:56 AM   #80
87 dually burb
my short bus
I can take some after 4 today
Old 10-17-2009, 12:20 PM   #81
justpball
justpball's Avatar
tail lights?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-17-2009, 07:15 PM   #82
87 dually burb
my short bus
not sure what I want yet for lights or where I want the tag
I'm thinking on putting the tag below the rollpan in center
and using cats eye led lights above where the stock ones were
Old 10-18-2009, 07:05 PM   #83
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Looking good so far! Why not put your plate in the recess on the gate?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 10-19-2009, 12:28 AM   #84
87 dually burb
my short bus
the recess area is for a whiskey label mural like a jack daniels bottle
I just ordered a tag frame with lights that will hang below roll pan on a hinge
also ordered my tail lights and peep mirrors
if it warm up this week I'll start on the body work
Old 10-20-2009, 11:33 AM   #85
justpball
justpball's Avatar
did you do bag over axel and leave the leaf springs or what?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-21-2009, 10:23 PM   #86
87 dually burb
my short bus
yes its a bag over even with the triple bags I dont get the lift I need I mounted the frame bag mount to high but will be changed in spring to a 2 link with a watts linkage with bag on bar,I had to use my front bag cups as spacers in the rear to keep the bag at a soft ride height
starting on body work got pass side done
finish rear and driver side thurs after work
will send it out next week for exhaust then get it inspected so i can drive it again been off the road since may
Old 10-22-2009, 03:49 PM   #87
justpball
justpball's Avatar
rear setup pics man pics...LOL
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-23-2009, 01:14 AM   #88
87 dually burb
my short bus
I'll have some after noon when I get off work today
Old 10-28-2009, 08:23 PM   #89
87 dually burb
my short bus
I forgot to get pics will this friday after noon when I get home
I'll get them this time
Old 10-29-2009, 03:39 PM   #90
justpball
justpball's Avatar
yea yea...i have heard that before...LOL
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-29-2009, 06:24 PM   #91
87 dually burb
my short bus
I got friday off so lookin to spend a few hours working on the burb
Old 10-31-2009, 09:50 PM   #92
87 dually burb
my short bus
Old 10-31-2009, 11:25 PM   #93
lolife99
67-72 parts collector,…
lolife99's Avatar
Ever think about running a sleeve bag instead?
They are suppose to ride much better than the double convoluted bags.
Keith
Convert to disc brakes.
Old 11-01-2009, 11:25 AM   #94
87 dually burb
my short bus
future plans are a 4 link mounted inside the frame rails to run a 22x12" rim in rear thinking about going with a pro tour theme
Old 12-24-2009, 10:13 PM   #95
87 dually burb
my short bus
no real update it's just buried under 2 feet of snow for awhile
plans for jan are 2"dropped crossmember and raise gas tank 4"s will lay on pinch weld then
feb I start all the interior going to stay mostly stock with suede covered pieces
looking to drive it alot next years and work on what I like and dislike
Old 12-26-2009, 08:06 PM   #96
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sounds like you have a plan, with out the snow.
tvblazer78 is offline   Reply With Quote
Old 12-27-2009, 08:40 PM   #97
87 dually burb
my short bus
also plan tear out most of the tub kit and mold in the 3rd row seat
not happy with what they did some times it better to just do it your self
lesson learned the hard way
Old 01-03-2010, 10:05 AM   #98
87 dually burb
my short bus
change of plans and of heart going to part with it and buy me another 4runner to build I will be back in the spring looking for a 6.5 diesel burb for a tow rig
will update with who ever buy it to start there own thread and finish the build
Old 01-03-2010, 12:40 PM   #99
flamingbig10
6.0 powered square
flamingbig10's Avatar
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-03-2010, 01:38 PM   #100
tvblazer78
Low & Fast!
tvblazer78's Avatar
That's sad, hope you can come back soon..
