#301 |
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
That blue truck looks awesome.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#302 |
Benji,
Looks good, but I have a question. In the picture you show of the spacer, the spacer is off center of the rotor (due to the slotting of the spacer holes). How do you ensure that the spacer is centered when mounting the wheels? It seems that the front would have an unbalancing if the spacer isn't centered carefully. What did you do to make sure the spacer was centered? Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#303 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Very nice looking truck, Benji.
What size tires are you running?
#304 |
Well i centered the spacer on the rotor and used a special glue, forgot the name of it, but once you bolt on the wheel the spacer goes no where. As far as tires, im running 275-40-20 on the rear and 255-35-20 in front, i still need to cut the front fenders and modify my bed to go lower when i slam the bags, but thanks for all the comments guys..
#305 |
![]() Join Date: Jul 2009
Hey Benji, your truck looks GREAT!!!
And you can use Gorilla Snot to hold the spacer in place...I've used it with great success. |
#306 |
![]() Join Date: Feb 2008
any pictures of your rotors before/after you shaved them down? How much does something like this cost to do?
MAN I WANT THESE WHEELS EVEN MORE NOW!! |
#307 |
VA72C10
![]() Join Date: Mar 2008
Liking them more and more...can't wait till they're out in chrome fixed for our trucks!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#308 |
![]() Join Date: Nov 2006
what up ben just saw the truck on the 20's
looks real good...hows the setup working? if you got any q's let me know! |
#309 |
hey Jay.! whats going on? yea ended up looking pretty good. The set-up is working good so far, i have a few leaks on the back, but the front has been perfect no leaks at all. Real happy, good job man. My boy might be giving you a call soon about his blazer that he wants to bag..
#310 |
just wanna comment on them spacers i would highly recommend you check lug nuts often i had these same ones mr gasket ones correct me if im wrong you are just asking for trouble mine came loose several times they make ones where the bolt pattern is correct your truck is bad azz wouldnt want to see it tore up
#311 |
Man Benji..... You have an amazing looking truck. Thanks for posting pics, time to get off my ass and get some work done now.
#312 |
Hi folks, FNG here in Virginia. I found the forum by searching on the (black) Boss 338 wheels.
I just bought this 1997 Tahoe, and from what I gather; I could have a problem trying to get the Boss 338 18x8 to fit on my front axle; correct? I am going to do 18x8s all the way around as I plan for this truck to be a driver with a lot of rubber on each corner. I just ordered a single 18x8 through a friend of mine & a set of 4 knock-offs. (They are only sold in a set of 4.) I plan to do some test fitting with the one wheel. I have BellTech drop spindles and drop springs, but the drop springs are coming off this week and stock spring are going back in. I don't want the raked look. Does anyone have any more info or experience they can share? Thanks in advance! Last edited by Sydwayz; 11-01-2009 at 11:09 PM. |
#313 |
Never Ending Projects
Sorry no help but VERY nice looking Blazer!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#314 |
Amateur Rust Fighter
That's correct, unless somehow you get "lucky" and have different rotors than everyone else. The design is being reworked to open up the back, but now it's been pushed back until later this month. I'd hold off until you can be sure you're getting the new design for all four corners (rather than buying two now for the back, for example, which would prevent you from rotating your tires in the future).
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
#315 | |
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#316 |
Benji_1802
What size tires are you running on the wheels?
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
#317 |
One day.....
Nice Blazer!!
DZL1. |
#318 |
Quote: Well i centered the spacer on the rotor and used a special glue, forgot the name of it, but once you bolt on the wheel the spacer goes no where. As far as tires, im running 275-40-20 on the rear and 255-35-20 in front, i still need to cut the front fenders and modify my bed to go lower when i slam the bags, but thanks for all the comments guys.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-02-2009 at 04:53 PM. |
#319 | |
#320 |
On the college boy budget...
Not completely relevant, or the best picture, but my sister saw this car when she was in Asheville this weekend and snapped a pic of it. I was looking at the picture and noticed the wheels looked like Boss 338s so I figured I'd post it.
-'68 C10 short/step- 350/350 |
#321 |
any updates as to when the retooled wheels are being released??
1986 GMC 4x4 |
#323 | |
![]() Join Date: Sep 2004
20's with a 45 series is plenty of meat to drive every day imo
#324 | |
45-series rubber on 18's will work on most set-ups if 18" wheels are acceptable.
#325 | |
ride quality like I said just IMO |
