Old 11-09-2009, 11:04 AM   #1
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
winshield washer does not work-- 06 Silverado
I never needed the windshield washer since I bought my truck last year and now I notice when I twist the deal to turn it on ..nothing happens.
I filled the tank but thats as far as I have gone to see what the problem is .
any ideas from you all other than take it in to the dealer to trouble shoot this .
GOPAPA is offline   Reply With Quote
Old 11-09-2009, 11:55 AM   #2
bpeters5814
bpeters5814's Avatar
Re: winshield washer does not work-- 06 Silverado
Mine did the same thing. The hose from the bottom of the fluid reservoir was cracked. Went to NAPA and got a rubber hose for about 2 bucks. I had to take my battery off to fix it, but it was better than getting charged $80 an hour for the dealer to figure it out.
bpeters5814 is offline   Reply With Quote
Old 11-09-2009, 08:20 PM   #3
GOPAPA
GOPAPA's Avatar
thanks ,,but before I take the things apart can you answer me this and maybe save me some time .. If the hose beneath the fluid reservoir is cracked ,,should all the liquid be gone from the reservoir? Mine is full and has been full for a long time anyways..
Old 11-09-2009, 10:19 PM   #4
Gray Ghost
Gray Ghost's Avatar
Does the washer motor make a noise when you try the washer?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 11-09-2009, 10:45 PM   #5
bpeters5814
Mine held fluid, but nothing would come out at the wipers. I'm guessing whenever I tried to use it, it just shot all the fluid out of the hole.
Old 11-09-2009, 11:46 PM   #6
GOPAPA
GOPAPA's Avatar
thanks for the quick reply ,,I'm on it soon as I can get to it .
Old 11-10-2009, 08:06 AM   #7
truckdude239
truckdude239's Avatar
the nossles might be stoped up when you hold the button do you hear the motor running
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-11-2009, 09:05 AM   #8
GOPAPA
GOPAPA's Avatar
No,, I do not hear any motor running.. I should hear it shouldn't I ?
Old 11-11-2009, 11:57 AM   #9
truckdude239
pull the inner fender and pull the plug off the washer motor and i use either test light or a mutlineter and have someone push the washer button and see if you are getting power at the motor if not it could be a fuse, if you are it probleya bad motor
David fuller
2000 Tahoe 5.3l 378
Old 11-11-2009, 12:47 PM   #10
GOPAPA
GOPAPA's Avatar
that about covers it for finding out whats wrong,,thanks for help and ideas .. gopapa
