69 c10 -- first project!!
So i picked this baby up off a guy for a bargain price, already stripped right down and ready for me to get busy!! heres some gentle progress pics so far. i work on a civil servants salary so bare with me this project may take a while!! haha
Re: 69 c10 -- first project!!
some more.....
detailed the guage cluster, wish i had have taken a before AND after pic it came out awesome!
started getting ready for the frame shortening, took the rear cab mounts off, front bed mounts and cut the 8" off the back of the frame, aswell as removed the tranny crossmember and the brake lines and wiring.
my compressor kept dying on me and we had little more option. so we just cut the 8" off with a hacksaw haha. turned out as good. also opened the diff up to see what ratio and if i had posi or not. well it looks like a brand new set of 3.73's in it but no posi, oh well, locker on order!! could anyone tell me what spline axles came stock on these? having to pull an axle to check? |
![]() Join Date: Nov 2008
im also working on my first project, also a 69 c10! what are your plans with the truck? why did you cut the end of the frame off?
69' 1/2 ton LONGBED__ _______ |__\__ |__(O)______(O)] ![]() My build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=354115 |
well im going to shorten the frame, and you have to take 8" off the back end and 12" out of the middle, so i took the end piece off first. i have to take the frame to my buddy's cuz i dont have a welder or 220 to weld it back up.
plans for the truck are a supercharged ls motor, 4l80e trans with manual valve body, 12bolt rear just gonna run the 3.73's for now and see how they hold up, got a locker on the way. shaving everything that can be shaved, fuel cell behind the rear tires mounted in the frame, getting an 88-98 stepside box, 1piece fiberglass front clip. truck will be lowered unsure how far right now. and some other tips and tricks im picking up from guys on here as i go! |
truck looks in decent shape....good luck with your 1st proj.!!!!
#8 | |
yeah fishplating for sure!! uhh not sure bout the front clip, havent looked to deep into it, just know that they are out there. i'll run the factory front till i get it.
I hope you don't plan to cut the frame strait down in the middle like you did in the back. It is stronger if you do a kinda curved cut. I will try to find the thread about it.
EDIT: Here is what I was talking about... http://67-72chevytrucks.com/vboard/s...d.php?t=123624 Im not saying it has to be done this way, I just heard it was stronger this way and thought you might want to know about it. Last edited by thebrown83; 09-01-2009 at 09:43 PM. |
#11 | |
ive followed a couple threads on this site, did some pretty good research on how to do it and im confident we've got a good plan, so im excited to do that, should be done in a couple weeks, going on a little vacation for a week and a bit so when i get home we're chopping it. |
Eat My Rust
You used HACK SAWS to cut the frame... Holy Hot dogs....
You are determined. Or I'm spoiled with power tools, either way. ![]() |
Power tools rock ha ha
well this time equipped with PROPER POWER TOOLS haha we got the frame cut, shortened, welded and plated!!! was really suprised how do-able the job was. took the frame over the the gf's parents garage due to lack of space, 220wiring garage, welding machine and welding experience in my garage.
worked out well, her brother and I did all the grinding and he did all the cutting and welding. he's a 35yr veteran welder so i had full confidence. we ended up using the 12" piece we cut out of the frame for the fishplate, just cut one flange off and swapped sides and filled it in, should be super-duper strong far as im concerned!! heres some pics of the battle.......... |
#15 |
and seeing as its a gorgeous rig i figured id show my gf's dads last resto, they did this 72k5 4x4 blazer. its got a 383stroker, total ground up resto. its a sweet ride, we used it to tow the trailer and my frame around this weekend!!
#16 |
Eat My Rust
Now THAT's a dad I can really get along with.
#17 |
haha yeah man, first time i went to their house when we first started dating, we watched barret jackson for 4 hrs and got WASTED haha.
#18 |
Nice looking Project.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#19 |
so in the middle of moving right now, getting a new place with a bigger nicer heated and insulated garage. so more work to be done soon!!!
#20 |
pick up my engine and tranny today. found an lq9 and 4l80 in town for $1400 and i jumped on it!!
woo hoo!!! |
#21 |
That's a smokin deal!
#22 |
yeah eh!? 23000kms on it too!! out of an 05 silverado.
#23 |
some work done, got the wiring harness off and most of the front drive accessories. more to be added tomorow.
#24 |
Heres the new garage space, and my buddies truck.
#25 |
more engine teardown.
