01-18-2010, 12:52 AM | #1 |
Disc Brakes on 14-Bolt Full-Floater
I'm New to the Forum
I have Owned Several 1974 to 1985 Trucks + 1 (1976 Blazer)in my 20 years or so(driving) // 4/ Wheeling/ Glad to see So many Chevy Trucks Fixed-Up on this Forum. I would like Idea's on Disc Brake conversion for 1978 14 Bolt FF Axle. I have brackets from http//www.ruffstuffspecialties.com from E-Bay I have 1978 Edorado/Cadillac Calipers (from Pull-A-Part) for Core & Also have Levers & springs I will need for E-Brake Set-Up Now my Question isoes any body have Pictures of this swap or Info??????? #1-Brake hose Set-Up---AN Fitting or Regular Stuff #2-E-Brake Set-Up---Try to Hook up to Foot E-Brake or CUSTOM Lever Thanks in Advance Getter-Done Last edited by Getter-Done; 01-18-2010 at 01:10 AM. Reason: mis-spelling |
01-18-2010, 11:18 AM | #2 |
Re: Disc Brakes on 14-Bolt Full-Floater
I think this has been done on here before. I would like to see pics as well.
05 Chevy 3500 Crew Cab Dually Sold 1984 Custom Deluxe K/30, 350 SBC with 4 Speed, 6" Lift, 35" Boggers, Headmen Headers, Custom Full 3" Dual Exhaust, Qualitex Buckets with Flip Center Console |
01-18-2010, 11:01 PM | #3 |
Hey Slick17
I plan to buy a Camera Also. Hee Hee Hee I like your Truck Getter-Done |
01-19-2010, 02:47 AM | #4 |
When I did my swap I used the hoses for the front calipers and re-ran my brake lines so that they went through the frame like the front does.
Pull the axle shaft out Pull the brake drumb off Remove the Hub (this requires a special socket) Take the brake line loose from the wheel cylinder Remove the brake backing plate Press the studs out of the Hub with a hammer and punch Put the new rotor on the back side of the Hub and press the studs back through Mount your new bracket from Ruff Stuff so that the bleader is facing Upward (the bend should be towards the wheel) Put the hub back on Put the caliper and pads on Re-install the axle shaft Repeat on other side As for running the E-brake lines I don't know because I used front Calipers from a Dana 44
1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 01-19-2010 at 03:06 AM. |
01-19-2010, 03:20 PM | #5 |
I saw a good idea the other day that I'm gonna do for an e-brake: Just run a portion of the rear brake line into the cab (I'm going to have a center console, so mine will come up into it) and put a valve on it. That way when you stop, before taking foot off the brake, close that valve & it'll hold the back brakes.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
01-19-2010, 06:57 PM | #6 |
the line lock idea for a park brake is good, but not as an Emergency brake. If you lose your master cylinder you got neither. If I'm not mistaken, for inspection the E-brake must be mechanical.
If it ain't broke broke don't fix? Get a hammer. '89 K1500, Reg. cab/long bed, 350/700r4, 285/75-16. |
01-19-2010, 09:11 PM | #7 |
Everything is work in progress
You should swap out your master cylinder for a 4 disc model. Some peeps don't and get away with it. But it you really want the full benefit of the 4 disc's, swap the MC
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
01-19-2010, 11:24 PM | #8 | |
Thanks Getto Luxury
You gave me several Idea's I probably need to stick with Rubber lines. Quote:
01-19-2010, 11:30 PM | #9 | |
I was Thinking more of Cable E-Brake. But that is Definately an Option.
Thanks for the Idea. Quote:
01-19-2010, 11:41 PM | #10 |
That's what I Want a Cable System Either foot or lever Operated.
Thanks Big Phillip That backs up my thinking on I need E-Brake |
01-19-2010, 11:45 PM | #11 |
Have you got a Part # for Master Cylinder????
Thanks in Advance Getter-Done |
01-20-2010, 08:25 AM | #12 | |
Addicted to Rust
Google Mico brake lock. I had several on different tow trucks. Not an emergency brake, but will hold your truck as anchor to winch from/to. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
01-20-2010, 08:58 AM | #13 |
No prob, this it what we are here for.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-20-2010, 11:37 AM | #14 |
Check this out.
http://www.pirate4x4.com/tech/billav...b_disc_brakes/ Btw, you can use 78 caddy eldorado calipers for cable parking brake. Doug Last edited by doug70; 01-20-2010 at 11:38 AM. |
01-20-2010, 01:01 PM | #15 |
I've read about the caddy calipers and alot of people that have used and ran them say they are junk. They have said by the time that you spend the money on finding them gathering all the parts needed that you could buy a better set up.
I'm thinking about doing what Ghettoluxury said and for a E-Brake use a transfer case disk brake. Now granted if your axle brakes I won't have a E-Brake but if that happens I won't be driving it and I can use a brick lol. Thanks Getter-Done.
01-20-2010, 09:17 PM | #16 | |
Fun in the Dirt also mentioned this I found one on E-Bay I think I will go with it. Because I do some Winching from time to time. Last edited by Getter-Done; 01-20-2010 at 09:21 PM. Reason: wrong info |
01-20-2010, 10:14 PM | #17 |
[QUOTE=Slick17;3745160]I've read about the caddy calipers and alot of people that have used and ran them say they are junk. They have said by the time that you spend the money on finding them gathering all the parts needed that you could buy a better set up.
I'm thinking about doing what Ghettoluxury said and for a E-Brake use a transfer case disk brake. Now granted if your axle brakes I won't have a E-Brake but if that happens I won't be driving it and I can use a brick lol. Thanks Slick 17 I will read up on that caliper problem /I seen something about Lincoln Calipers On the Thread?.I don't have much money in it yet just $18.00 at pull a part and $50 Bucks on Brackets. I seen that Transfer case Brake,that's Awesome. Thanks again, Getter-Done |
01-21-2010, 01:16 AM | #18 | |
Napa #UP 390278
01-21-2010, 11:45 AM | #19 |
Yeah that's exactly what I had in mind, just didn't know who made such or how to go about searching. I really like the lever lock style ...THANKS!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 Last edited by fun in dirt; 01-21-2010 at 11:49 AM. |
