#51 |
Under Construction
Re: Left for dead: 72 2wd blazer build
looking really good. I wish i would have known you were in town... I live 3 streets over from Chad (14u2nv) always nice to meet board members.
keep up the great work.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#52 |
Tot Roddin'
Great progress on the project!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#53 |
![]() Join Date: Jan 2007
progress is progress - I got some welding done on mine, but trying to rebuild that outer floor area where the step up is located is taking me forever -
![]() Nice Work! |
#54 | |
#55 | |
Future TOTM Winner
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-26-2010 at 11:49 AM. |
#56 |
#57 |
[QUOTE=Critter;3758427]THANKS! I would love to have it if possible. As far as the woodgrain goes, I agree with 1sik52. My blazer came factory with the wood grain (99% positive). You can see my spid on the lower left says "custom trim combina", I guess one of these denotes wood grain on a Blazer
My woodgrain came on a '72 GMC Custom, but my guess is that the SPID lists it as "Com'bina", it is a rare and exotic wood only found in the darkest jungles of South Central Brazil, dunno just a guess! Nice work on saving this ol' 2 WD, some of you guys have really stepped it up. Nice to see someone doing quality work to bring it back from dead Always enjoy reading your progress, keep it up with the nice pics. as well! If you need any wood trim LMK, as I'm not using it
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-26-2010 at 02:09 PM. |
#58 |
![]() Join Date: Jul 2009
mine has the wood grain and I know that its original. how much is a full set from a blazer worth?
#59 | |
Did you say you could get patch panels for the rocker areas? I might need a set of those! Its great looking at your pictures, it gives you an idea of what it looks like under the metal! Thank you!
*1972 454ci Burb, C20 3/4T, T700, 2WD *1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES |
#60 |
Jtrux, 72BlckButy, and lks dcvn, Thanks for the compliments and words of encouragement. They really help to keep me motivated!
my67chevytruck, It's a shame I missed you. I didn't even know you two lived so close together. Maybe I will run into you at Pate this spring. 1sik52, Critter, Jaros44sr, and Clifblazer, Thanks for the valuable information. I am not sure why I thought they didn't have it, other than I just never saw it on any original sales literature. Thanks! Firebirdjones, I wish one of the previous owners of my truck wouldn't have put screw holes into all of my trim. I think most of it would have been able to be restored. Oh well looks like I need to shell out the $800 or so it will take for repro trim. 72DIRTY RAT, Yes; most aftermarket companies here in the states sell reproduction rocker panels, rocker boxes, and inner floor sections that have the back part of the rocker panels as well.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
#61 |
![]() Join Date: Feb 2005
Blazer is looking good.When you use that truck floor don't forget your bucket seat bracket supports.I did and it was a pain to go back and redo.Don't give up it will be worth it.
#62 |
Nobby, Thanks for pointing that out. How hard of a job was it to replace the entire floor section?
#63 |
It wasn't that bad.The yellow part was cut out of a parts cab and the floor pans are new.I drilled out the spot welds holding the floor to the braces on the truck and they lined up good on the blazer braces.I'm glad I did it because I was able to sand blast inside the rocker boxes and under the floor,and that will make me feel better in the long run
#64 |
That's good to hear that it wasn't a really hard task. So far my biggest problem is seeing where al the spot welds were on the floor of the donor cab. Theres nothing I hate more than drilling holes where you think there is a spot weld only to find you drilled a hole over nothing!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry Last edited by 1956cameo; 01-27-2010 at 11:09 PM. |
#65 |
![]() Join Date: Apr 2009
nice work man thank you for saving this gem, og 2wd cst man ur lucky!!!!!!!
1937 Pontiac 2dr 1970 K5 CST 1972 Jimmy 1973 Hickey ent. equipped Blazer 1977 Blazer Chalet #1193 |
#66 |
Notice how Nobby put supports in the cab to help keep things lined up. Minor movements can be problems for fit later on.
#67 |
Arizonak5, Thanks!
Muleman100, Braces will be put into place before the floor is removed. Below is a picture of my SPID for the blazer. I was wondering if anyone could tell me what the California Assembly and California Processing options meant. I assume it has something to do with emissions, but was wondering if anyone knew exactly what it meant. Thanks! ![]()
#68 |
Here's the latest progress report on the blazer. I went out to my dad's on monday and worked on getting the floor out of the donor cab. That job pretty much took the whole day to acomplish. Here is a picture of the donor cab once the floor had been removed.
![]() A picture of the donor floor once it was removed from the cab. It is by no means in great shape, but the majority of the back half is in ALOT better shape than the blazers floor. ![]() Before I removed any of the flooring on the blazer I braced the front cab area up with square tubing. I figured that since the floor is in poor contition along with one rocker box bieng almost completely gone it was cheap insurance. ![]() The next day I went back out and was finally ready to start replacing some rusty metal. I decided that instead of replacing the entire floor section like I had originally planned to do I really just needed to replace the rear section. I came to this conclusion because the front half of the floorboard was in really good shape. Instead of replacing the rear floor as one piece I replaced it in two pieces. I primarily did this to reduce the amount of good original sheetmetal from bieng replaced. Below is a picture of the tape outlining the rusty area that is to be removed. ![]() The taped of section of donor flooring before cutting it out as a patch panel. (Sorry for the poor quality. The camera got put onto a different setting and I didn't notice it until later) ![]()
#69 |
Under Construction
great progress....
#70 |
After a little bit of cutting, grinding, and air chiseling I got the bad panel out.
![]() It took alot of lining up and minor trimming, but I got the donor floor tacked into place. I will be going back later and welding it completely in. I also had to drill holes in the donor panel for the blazer bucket seat bolt brackets (Since there are more brackets than with a truck; and since they are in a different location). Fortunately the front inner seat bolt bracket is attatched to the cab floor support, so that gave me a reference point to base everything else off of. I had to take the drivers side bucket seat in and out of the blazer about 6 or 8 times in order to get all of the seat bolt brackets lined up exactly. ![]() After finishing up on the drivers side I started up fresh today on the passenger side floor board. This side was a little bit more stubborn than the drivers side; of course this side was in better shape and it had more supports attatched underneath. ![]() The bolts that hold the passenger seat rear hold down bracket were both broken off in the floor bolt brackets. I soaked the bolts with penetrating oil for a couple of hours and used vice grips on them, but was unsuccessful in removing them. Since I didn't have time to keep playing around with them I simply drilled them out. I will try to re thread them at a later date. ![]() I am not sure why but this patch panel went in much smoother and tighter than the drivers side patch. Once again it was just tacked in and will be completely welded in before bieng called done. I guess I just had better measurements this time around. As you can see I got all of the passenger seat brackets attatched and in place. This was not an easy task; not sure how Nobby was able to do it after the fact because even with bieng able to remove the floor during this job it was a PAIN. I put the passenger side seat in and fortunately the seat brackets and the floor brackets line up as they should. The seat locks down in the back very easily and releases easily. ![]()
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry Last edited by 1956cameo; 02-12-2010 at 02:24 AM. |
#71 |
Heres a shot of what was left of the donor floor after I removed the patches that I used. Of course this shows a reference of how much original blazer floor was still good and saved.
![]() Tuesday when I got home from working on the blazer I had a package waiting on me. As you can see below it was my tilt auto column that I got off of the parts board. I don't think I am going to load the blazer up with options that it didn't originally come with, but I thought for comforts sake a tilt column would be nice. ![]() I know it doesn't look like it in the pictures but that was three solid days worth of work. Next I will be starting on restoring the rocker areas. This will primarily be done with reproduction sheetmetal. Unfortunately since my dads shop is stuffed with other parts and projects we pushed the blazer back out into the freezing, pouring rain when we got thru today. Hopefully I will have more updates soon. ![]()
#72 |
my67chevytruck, Thanks! I know it doesn't look like much but this week was alot of work!
#73 |
Its always something!
Yall are doing a great job on the blazer. I would be scared to death replacing what you have done.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() ![]() Member of the patina club |
#74 |
Having spent numerous hours in the cold garage working on my stuff - I can see that there is a LOT of time there...it isn't until you do one yourself do you have an appreciation for the amount of time that goes into this stuff.
I was out there last night just trimming a floor patch and that took me more time than I thought it would... Keep up the good work! |
#75 | ||
Under Construction
Tags |
2wd blazers rule, blazin aint easy |
