#76 |
Amateur Rust Fighter
Re: Project: Custom 71 4x4 hotrod
Is the spare tire crossmember sturdy enough to handle the stress of having shocks attached? When I removed mine, I remember it being rather flimsy -- enough to hold a spare but not much more. Yours may be completely different and in better shape than mine.
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
#77 |
![]() Join Date: Jul 2009
I found a gentlemen in VA to do an even swap for my tires.
#78 | |
![]() ![]() Here are a couple of photos of it. Last edited by silver7; 01-30-2010 at 11:17 PM. |
#79 | |
1970 GMC 4x4 swb fleetside custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters |
#80 |
I know what the shackle is for but that described movement is exactly what I am trying to reduce. My set-up is similar if not identical to a lot of other 'homemade' traction bars out there so I like my chances. In fact, I found a lot more truck guys using my kind of traction bars versus the Caltracs. This guy '6600duramax' is on our forum board making and selling a traction bar which mounts the same way as mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=364788 But, if the ride happens to be a little stiffer than desired, I can always add a small shackle to my front mount to allow my springs to elongate 'a little' when compressed. Maybe that will give me the best of both worlds. Either way, I appreciate the dialogue on the subject. Last edited by silver7; 01-31-2010 at 10:54 AM. |
#81 |
SWBs: 67 2x4, 67 4x4, 70 4x4
I like what you are doing, and the fact that you are hammering through it.
I wish I'd the balls to make those kinds of changes on mine, but alas, I'm kind of an old fuddy traditionalist. If my head does not hit the roof when going over a railroad crossing, I think something is wrong........ What will happen is as the leaf spring compresses and unloads, they will force the axle to twist on the springs, since the ladder is not compressible between the axle and frame. So as it goes up, (compresses), the nose of the axle will be forced down, cause the leaf is now longer. As it unloads, goes down, the nose will be forced up, because the leaf is not shorter. You will be able to test this easily with the truck jacked up and a set of tires on it, by raising and lowering the axle. You have two different ladders in your design, one is fixed, the other, (spring), will elongate or shorten depending on load. That is the problem. Most link design have two equal length tubes on each side, not one that changes length. Look at a 32 high boy. The way around this is a hairpin type where both tubes connect at one point on the frame. That lets the axle pivot the nose to allow the drive train to stay inline. If they both have roughly the same length you may not have that much of an issue, but because it looks cool does not mean it will work real well. That pic that you posted of the long ladders under that truck looks cool but also like a lot of stuff for nothing. My thought is that a traditional simple bolt on ladder that hits the leafspring would be much better than that, like is what is used on Camaro's, and would be protected by the tires. Also, why not mount the ladder on top of the axle to get it out of harms way? I went back and looked to see how my lowered truck's shocks were mounted. We moved used the same brace you have, and made a bracket tht moved the shock back a few inches. Works ok so far. You could also bolt that spare tire carrier back after reinforcing it. There is a elegance in simplicity......... The guys that designed these trucks 40 years ago where a lot smarter than we all realize. The only real improvement in their designs have been with the computers; engine control, auto transmissions, etc. Not easy to fix the basics. It's yours! Built what you want, then tell us how it works. We might all be changing to your design if works.
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
#82 |
"something witty here"
wow nice swb frame! what size are those rear wheels? they look huge!
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
#83 |
Conroe - thanks for information. If my design doesn't work I'll man up and post it for the group.
I like the idea of trying to get a spare back on the cross member. Nice pic of your frame. Looks great! I hope to moving that way soon. Last edited by silver7; 01-31-2010 at 07:26 PM. |
#84 |
I am also not an expert on the traction bar issue but I do have some great first hand knowledge of the system. This traction bar issues is alwasys a huge debate from both sides. Yes the type of traction bars I build will provide a stiffer ride (than without the bars) but it will definatly keep your axle planted on the ground. If you mount a ladder bar system (bars on top and bottom of the axle that connect to the frame at a single point) this ride will be even harsher and allow almost zero movement in any direction. The bars I built keep the axle planted MOST OF THE TIME. I am running a 468 with 35's and a line lock. If I lock the front and mat it I get some wheel hop, if I let off and feather the throttle (keep it under 6000rpm) the hop goes away. I have found out the longer the bar the better. A true four link system is best way to ensure no wheelhop.
We have multiple trucks running the single bar system and have overall good luck all around. If I was going to critique your bars at all I think they are a little short, other than that you will have to watch the heims you are using. They will were out pretty quick and start to rattle. If you dont drive it a bunch it could take a long time though. Great build, keep it up!!
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
#85 | |
![]() Brent
#86 | |
#87 |
You have your opinion and I have mine so I guess you'll have to accept it and respect it or stop posting in my build thread.
![]() Yes I do have an update - thanks for asking yellow70GMC. Last night I was able to get my cross member lengthened 3.5" and welded together. I think I broke my vise trying to bend the added piece of steel to the same shape as my cross member. ![]() ![]() I decided I wanted to put on front axle on as well to be sure my front dual shock mounts attched without any issue but noticed my new U-bolts were lining up as well as I hoped. If you remember I have a 71 chevy C10 converted to 4x4 so I don't know if the U bolt brackets or the Dana 44 is original or not. Anyways, I needed a tool to expand and compress my U bolts about a 1/4" to get them to line up with the bracket holes. I stopped by Home Depot on the way home and was going to make a widget of some sort when I came across this sweet Irwin tool which works for compressing and expanding. ![]() I'm really hoping to have my frame and suspension completely together this weekend before Sunday. If this works out I can then take it apart next week and get it sent out for sandblasting. I still haven't decided yet if I am going to powder coat it, paint it or coat it with aSEM liner like my buddy Nick used to coat the frame of the 67 Mustang he restored. ![]() I did all of this pre-work with the hope I don't need to do any more welding or major surgery afterwards so I could powder coat - but you know how that goes. Nick loves the liner concept, powder coat is so durable and paint just seems easier. What do you guys think? Last edited by silver7; 02-02-2010 at 10:24 PM. |
#88 |
your u bolts must be 2.75" and the top plate is 3" from a slightly newer axle...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#89 |
I would say powdercoat, depending on the cost of that liner. powdercoated stuff is sooo nice if you ever take your truck offroad, mud and stuff comes right off with just a hose most of the time.
#90 |
I agree. Powder coat is very nice. Especially when it has a clear coat too.
Mike - you see any issues making the U bolts fit? Those long bolts flex a lot. I guess I could swap the bolts, Summit has always been great about that. And do you think Freeney is going to be able to play Sunday? I bet he plays all 3rd and longs. Last edited by silver7; 02-02-2010 at 11:30 PM. |
#91 |
All of mine is powder coated then toipped with clear. It was one of the best decisions I made on the build. I agree on your one thought thou....... you need to have everything mocked up EVERYTHING. I had ALMOST everyhting. I never put my driveshafts in because I thought they would be fine. Well I have a 1350 cv in the front shaft and it is a lot bigger than the stock 1310 stlye. Bottom line is I had to grind the top side of the crosssmemeber jsut to get it to fit. Plus I wish I could add a set of front traction bars (let the flaming start on why anyone would ever want to do this...ahhahah) but I have no place on the frame to attach them to now!!
Bottom line- just make sure you like everything before it goes to the powdercoaters!! Good luck and keep the pics coming
#92 |
Front traction bars would rock!
![]() Glad to hear the powder coat decision was a winner. Yellow70GMC makes a good point about cleanability too. 6600Duramax, do you know the supplier of your powder coat? The speedway black w/clear coat I have on my axles is a ' prismatic powders.' And how did you touch up the spot your spot on the cross member after you had to grind it? This speedway black has a ton of metal flake in it so I was concerned about using a 2 stage to fix areas needing extra work and the powder to be removed. I actually called NIC Industries and they said they would mix me some 2 stage urethane liquid at $64.95/qt. ![]() How did you strip your frame? Sand blast or chemically? Did you also powder coat your leaf springs and traction bars? Sorry for all the questions but I appreciate any feedback. Thanks. Last edited by silver7; 02-03-2010 at 11:14 AM. |
#93 |
My upper shock tabs were here when I returned from my trip Thursday.
![]() Yesterday I sanded my shock cross member welds flat as well as drilling 1/2" bolt mounting holes for it and my frame . I still struggle with underestimating the time it takes to cut, grind, weld and drill steel. ![]() Today I noticed my lower shock brackets did not provide enough space in between my shocks when mounted so I had to start over. I hate it when that happens. ![]() One important point I failed to mention was when determining the location of my shock cross member I had to take into consideration the max and min stroke length of my shocks. I needed to make sure the shocks I used were near fully extended without weight on them so when I put the engine and body on it, and go to carry a load down the road it could compress under the additional weight. My SLF-85140 Superlift rear shocks had a max extension of 26" and a min extension of 16" (checked them myself to be sure). My shocks will extend to 22" mounted under no weight except for the frame so I have room in both directions.. Last edited by silver7; 02-07-2010 at 06:47 PM. |
#94 |
more progress than I had... I was in little rock all week.. good news was that the chief of staff of PA informed me that i'm now promotable and moving into a Bn S3 job...
GO COLTS!!!
#95 |
Congrats brother. I was the 504 PIR BDE S-3 Air for about 2 years so I know a little bit about that stuff. Long hours, and no sleep during the MDMP working hand-in-hand with the RAVN (Regimental Aviation officer) seting up air corridors and air assaults was the norm for me. I pissed of a few BN S-3s in my day but I managed to keep my rank some how. GOOD MEMORIES.
Go Colts! |
#96 |
Freeney is "da man"...
#97 |
That was an awesome sack. He pushed that boy back like he was nothing. If the rest of the defense plays with the same passion and heart as Freeney the Saints don't stand a chance - even if they got an onside kick. . .
#98 |
worst throw I've seen Peyton make all year... so be it.
#99 |
I hate to see Peyton lose like that. Ouch. . .
#100 |
Looks like you have come a long way. The powder coating on the axles looks great. A word of advice, Do not use a cinder block on its side to support a load. The side is the weakest part of the block.
O2 sensors are emission equipment, as are your spark plugs. I would have taken it to a dealership and have them change it along with the plugs. Emissions equipment is covered under warranty to at least 100k or 10 years by federal law.
I can still count my vehicles on two... wait three hands. Last edited by Damien; 02-07-2010 at 11:54 PM. |
