Hey guys....... New to this forum but not new to forums in general looks like a great site
![]() Anyways I'm in the process of buying another 67-72 SWB 4x4 (owned a few including k-5s) and would like to know which year axles off a 3/4 ton Chevy i.e. only 67-72 or other years & models etc. will be a direct bolt in for a 67-72 1/2 ton SWB 4x4 truck. BTW I tried searching the forum for my answer with no luck before posting this thanks in advance for your help fellas. Last edited by SWB4x4; 01-30-2010 at 10:13 PM. |
Re: What 3/4 ton Axle Fits 67-72 1/2 ton 4x4s?
I know the dana 44 and 10 bolt front from 73-87 is a direct bolt in provided you use the later u bolts and clamps. Then you get disc brakes. Dont know of a bolt in rear as the spring pads need to be moved and shock mounts as well to run the later 14 bolt.
SWB 4x4 Collector
![]() Join Date: Jun 2001
Welcome aboard from another swb 4x4 collector. I believe, like stated, both the dana 44 and 10 bolt will bolt in fine up front. The only rear you could use without moving the spring perches is a Cab and Chassis rear end. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
The widths are all the same on the 67-72 1/2 ton axles and the 73-87 3/4 ton axles then?
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 |
for a rear end, any 1ton 73-87 will bolt in...all other later rear ends require moving perches....which isnt that big of a deal
I just put a 1995 14 bolt dually from a cab and chassis in mine and it was a direct bolt in. The e-brake cables are different length and the shock mounts are different. That's ok for me since i will use the 95 style shocks.
Doug
68 CST 396, 60K original miles 70 Longhorn project 72 Stepside (150% complete) 67 Stepside project 71 RS Camaro 90% done 71 BB Corvette 50% complete 78 K5 project |
SWB 4x4 Collector
Yes, the widths are fine. The ONLY rear axle though that will not require modifications is a 1 ton Cab and Chassi rear end. Everything else will requires the shocks mounts to be moved and possibly spring perches as well. Trevor
Living In The Past
besides cab and chassis, the single rear wheel c30 pickup also has the same width on the spring pads. 73 87
![]() Join Date: Jan 2009
I put a '79 14 bolt 10.5 ring gear posi full floater unit under my '72 and the shock mounts and the spring perches had to be moved in.No big deal
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric ![]() Last edited by bignbad; 02-16-2010 at 08:06 PM. |
Tags |
3/4 ton 4x4 axle swap |
