02-15-2010, 11:44 PM | #126 |
Re: lowered shortbeds on stock wheels?
4/6 notched flipped 15x8 1" spacer
02-16-2010, 02:19 AM | #127 | |
If you noticed my 2.5" front drop and the 4" rear drop, they look pretty level. Even up close it looks pretty good and level. This set up has been done by many and it a proven combination -- without any issues to suspension or geometry. Like I mentioned earlier, the only thing I had to do was to cut away some of the bed support pieces to accomodate the taller drop shackles. I've read that some drop spindles of 3" had issues with caliper clearances but some minor grinding will resolve that issue. You can also go with drop "A" arms which are good but you will need to spend some cash. I wanted to keep everything pretty stock looking so I reused my "A" arms and rebult them. On that note, here's what $1000 looks like. Additionally, I included some pics of the taller shackles for your reference. |
02-16-2010, 09:55 AM | #128 |
Yeah I lowered my old 94 truck 2.5/4. This one though, I'm just not sure I like both ways. I won't go A-arms due to $$. From what I have seen on here, a lot of the guys that do the shackle/hanger route end up wanting lower. So I'm trying to take that into consideration. I'm real good about doing something, and then deciding something else later.
02-16-2010, 10:27 AM | #129 |
Wow.. this thread is making me miss my ralleys!
02-16-2010, 10:52 AM | #130 |
hey 86 swb your truck is looking sexy bro.
how did you get the back half cleaned up like that? and what did you use to coat it? |
02-16-2010, 01:44 PM | #131 |
02-16-2010, 03:25 PM | #132 |
Formerly- 1972SuperCheyenne
I'll help you John. Buy the 20s and send me the Ralley's. Anything I can do to help a friend you know.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-16-2010, 03:55 PM | #133 |
to be totally honest you cant beat rallys, i tried my buddies 20" TT 2's on my truck and i thought they made it ride like ****, i guess because of the smaller tires, and $1500+ no thanks lol
02-16-2010, 03:58 PM | #134 |
02-16-2010, 04:00 PM | #135 |
here's what $1000 looks like.....Where did you get all the parts for that price?
03-15-2010, 12:43 AM | #136 | |
Here's some additional pics. |
03-15-2010, 12:48 AM | #137 |
To qualify the $1000 purchase, I bought the majority of my parts from Classic Parts of America when they had their 10% off sale plus free shipping. However, I did reuse my A-arms, front coil springs, front sway bar, rear leaf springs. They are shown in the pic repainted and installed with the new bushings.
03-15-2010, 01:06 AM | #138 |
Here's an updated after pic with the new suspension and Magnaflow exhaust. Sorry but you can only see the Magnaflow tips.
I'm looking at installing a larger diameter front sway bar as well as a new rear sway bar. And maybe some rear traction bars (nice thing is that they will be hidden from view). I'll post some pics when they are done. But next up is installing the new OEM-ish black interior .... Current interior color is red/burgundy. Nothing wrong with the interior. In fact, the interior is near mint, with the exception of a little fading on the tops of both door panels. |
03-15-2010, 07:25 AM | #139 |
OL BLUU
Subscribing... great thread... and some real nice trucks!
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
03-15-2010, 09:39 AM | #140 |
03-15-2010, 10:22 AM | #141 | |
20" cast wheels @ 29" diameter vs. 15" steel wheels @ 29" diameter should have very similar centrifical forces @ speed (similar weights & diameters).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-15-2010 at 10:23 AM. |
03-15-2010, 10:50 AM | #142 | |
Its the same with brakes. Going from a 10.75" rotor to a 12" rotor increases braking ability tremendously. The little changes make a big difference in performance. I like the looks of 20's. I just don't like the sacrifice that goes with them. Last edited by Tony_SS; 03-15-2010 at 10:52 AM. |
03-15-2010, 01:19 PM | #143 |
Right in front of you.
Stock wheels never go out of style...nice to see so many trucks with 'em....
Rarely do I like a truck with 20"+ wheels.... Here's my pile.....
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A Last edited by 69BBsuburban; 03-15-2010 at 01:19 PM. |
03-15-2010, 01:51 PM | #144 | |
I weighed mine & was suprised how similar the over-all weights were between the 20" Coys & 15x8" steelies (again, similar pkg. diameters despite the difference in wheel diameters). Yes, that weight can be farther from the center-point but I doubt many actually scale the two choices for accurate analysis.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-15-2010 at 01:54 PM. |
03-15-2010, 02:52 PM | #145 |
My ol '80 on Rally's.....3/5 drop...
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
03-15-2010, 03:13 PM | #146 | |
03-15-2010, 04:16 PM | #147 | |
That's also true for the tires.... The 20" wheel has weight further out vs. the 15" wheel. The 15" tire has more shoulder & weight further out vs. the 20" tire w/the shorter sidewall. You indicate you could feel it.... I sure couldn't in my truck. I'm not saying your wrong. I will however challenge the broad statement that there's a significant impact on acceleration & braking when there's not been a breakdown of the equipment to determine the actual weights.
03-15-2010, 04:53 PM | #148 | |||
Here, read this: http://www.pro-touring.com/forum/showthread.php?t=35886 Some highlights are: Quote:
03-15-2010, 11:22 PM | #149 | |
box junkie !!
- 500mg of crazy a day ...... will keep the straight jacket away !!! :burno |
03-16-2010, 12:15 AM | #150 | |
I've read all that stuff too. Maybe you don't understand I'm considering the weight of everything (dissimilar material weights). What I read was a broad statement.....
Again, I agree w/your statement when it's an apples to apples comparison (15x8" steelies vs. 20x8" steelies). But if the materials are different (15x8" steelie vs. 20x8" aluminum wheel) there is a mathmatical difference. To me that has to be calculated & not just assumed.
