Old 03-08-2010, 05:09 PM   #1
Shon
FAST LSx 102mm Intake
$840 shipped
FAST 146102 102mm LSXR INTAKE MANIFOLD
for GM L92 / LS3 RECTANGULAR PORT
FAST™ engineers teamed up with airflow specialists at RHS™ to develop a polymer intake manifold for rectangular port GM L92/LS3 engines. Testing on a stock LS3 engine with a Big Mouth 102mm Throttle Body™ produced gains of 14+ horsepower and 11+ ft/lbs of torque at the flywheel over the stock intake. The LSXR™ 102mm Intake Manifold features a three-piece modular design that allows easy disassembly and porting. Extensive testing led to a runner design that is longer and less restrictive and gives the user the ability to remove individual runners from the manifold for modification.
Constructed from the same advanced polymer material as the LSX™ 92mm Intake Manifold, the LSXR™ offers a host of benefits over aluminum aftermarket intakes, including lighter weight, increased strength and improved heat dissipating characteristics. While the LSXR™ features a 102mm air inlet that is perfectly suited to the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock or aftermarket 90mm or 92mm throttle bodies. Other features include integrated nitrous bungs and perfect bolt-on fitment that allows the use of factory accessories without modification or clearance concerns.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 03-11-2010, 03:06 AM   #2
ShredSled
ShredSled's Avatar
Re: FAST LSx 102mm Intake
what about the "RT"?
ShredSled is offline   Reply With Quote
Old 03-11-2010, 02:30 PM   #3
Shon
I know alot of acronyms but RT does not ring a bell that makes any sense to me, do you mind helping me?
Old 03-11-2010, 02:48 PM   #4
ShredSled
ShredSled's Avatar
yeah, that was kind of vague, but was referring to the new FAST LSXR-T version, "T" standing for "Truck".
Old 03-11-2010, 02:57 PM   #5
Shon
yeah the 14302, same price $840 shipped.
if you want new intake gaskets (not included with the intake) is $30.
We can add a Nick Williams TB to the package, pricing depends on if you want a cable driven or need a ETC style TB
