hard starting with new Edelbrock when warm
The 1406 on my 400 makes cold starts a breeze...fires up on the first crank every time. The problem is when the truck is warm, it doesn't like to start and usually requires me to pump the gas pretty good while turning the starter. Eventually it catches.
What do I need to adjust? The carb is brand new and unaltered. Let's assume timing is fine becuase this was not an issue with the previous carb, though it did have other issues. I'm also down on "stab it" power compared to the 730CFM Holley I took off. Ideas? I'm not crazy about rejetting, etc., as I've never torn one of these down, but if that's the only option, well... Last edited by D-Rat; 04-21-2010 at 12:37 PM. |
Re: hard starting with new Edelbrock when warm
Sounds too rich. Next hot start don't pump it, just hold the throttle half open and crank. If it starts right up then you are definitely too rich.
Your "stab it" power is down because it's only 600cfm.
do you have a carb spacer like edelbrock recomends in the instruction booklet so that the fuel doesnt boil
Is the choke plate open when it is warm? If not, then the choke is not working and it needs to be fixed/replaced. When you pump the gas, you are actually opening the butteflies and allowing more air to enter, which is what the engine needs when warm. A warm engine should not need to be pumped to start up. However, when the engine is cold the choke plate needs to be closed, which explains why your cold starting is great. A closed choke plate will also kill your power. The cfm is fine for your engine and should not be a source of your "stab it" power issues.
Shake and Bake!
![]() Join Date: Feb 2010
Are you getting any hesitation on take off? And re-jetting an Edelbrock is quite simple, and can be done while it is on the engine although I doubt this is your starting problem. Edelbrock makes a nice jet kit for this. Also, like Cdowns said, a spacer is recommended.
What type of choke did you get, electric or manual? even though your last carb worked well, its a good time to check you timing anyways. The PO of my truck had the timing way to advanced and it would be a bear to start in certain conditions.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
#7 | |
Thats what I would guess
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
Choke is working fine.
There is no carb spacer. It's bolted directly to the manifold with just the gasket in between. That explanation makes sense. What part are others running here? How thick? Anyone have one laying around they're not using? Last edited by D-Rat; 04-21-2010 at 02:34 PM. |
Shake and Bake!
Do you have a spread bore or square bore intake?
my truck has a dual plane intake..never boiled
my surburban has a open intake..it boiled until I installed the spacer
Not sure I know the difference, but it's one big hole. It's an Edelbrock RPM intake if that helps.
I'm looking at spacers...which is better - open design or 4 hole? |
use the 4 hole
that should stop your problems..and it will also help you idle circuit
#13 | |
Shake and Bake!
Just make sure it will match your carb and intake. The 4 hole designs should help as well, as Charlie said. Here is a pic of a spread bore dual plane intake for reference. ![]()
I had the same problem until I installed a 4 hole plastic spacer to insulate the carb from the manifold heat.
"Negative people always seem to have a problem for every solution" |
#15 |
Parts and more parts
Definitely sounds like a "Heat Soak" issue. I would try the phenolic spacer to remove the heat from the bowls of the carb. I am running one on my stroker engine with the Edelbrock carb and intake.
Frank Last edited by piecesparts; 04-21-2010 at 03:51 PM. |
#16 |
Nabbed a 1/2" one off ebay new with gaskets and studs for $22.99 shipped. Will see how that works. Thanks guys.
#17 |
Most of the edelbrocks i have require about 1/4 throttle push with no pumping when warm. I have been told that all these drip a little fuel out the bottom? Sometimes i give mine 1 pump before i start it?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
#18 |
Hey D-RAT I'm having the same problem with my 1406, I had a 1405 and it would start fine every time, the 1406 takes a while to start when hot, I have an edelbrock performer intake so it has the 4 holes. let me know if that spacer fixes the problem.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
#19 |
will do.
#20 |
Junior Member
Don't me to hijack, but since you all are talking about Edelbrock carbs.
What would be the best one for my stock '73 454 with an manual transmission. Thank you. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#21 |
The 600CFM is marginal for my small block 400 but might work ok on a bigger motor with larger jets. A stock '73 454 is pretty low compression and probably doesn't have much in the way of high flow heads, so you might not get much benefit out of anything larger.
#22 |
Spacer seems to have done the trick!
#23 |
Iv got the same problem, and my motor also diesels when ever i get to my destination and shut it down will the spacer fix this as well.
