Never Satisfied
Fuel tank selector switch wiring
Curently in the middle of a gen 3 swap and i need some wiring advice. Purchased the pollack switching valve and the oem dash selector switch. the switching valve came with a six terminal toggle switch but the oem only has four terminals. does anyone know what four wires go to the the four terminals on the dash switch?
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 |
Next project: 1970 K10
Re: Fuel tank selector switch wiring
Did you look at the link I posted for you? There are two diagrams in that post. One shows the wiring to the switch. They should be power, ground, left and right. The other shows the wiring to the valve, then to the pumps and sending units (for the gauge).
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-25-2010 at 01:14 PM. |
Never Satisfied
yeah just still a little bit confused. the pollack valve has a wiring diagram but it shows how to wire the six terminal switch. i was wondering how to change that around so i can use the oem switch. it looks like the lead coming from the new wiring harness for the pumps goes straight to the switching valve and then i will have to have another hot wire for the oem dash switch as well. just want to make sure when i start building this harnes i get it right.
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 Last edited by bigdnew; 04-25-2010 at 01:22 PM. |
#4 | |
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
BMW & ASE Master Certified
ive been wanting to replace my bad valve.. i noticed it when bad when it took 1/2 tank for 40 miles and I thought i smelt gas... just poured the gas out the other side (no tank installed)
heres a link to the instructions on their site... that connector l ooks identical to the OE gm one.... http://pollak.thomasnet.com/Asset/IS-41_b.pdf It looks like they just use a cheezy autozone like toggle switch. The connector sure does look like the GM. I will loook at the facotry diagram and compare it to theirs...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 04-25-2010 at 08:12 PM. |
Never Satisfied
thanks man, hey bob there you go.
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 Last edited by bigdnew; 04-25-2010 at 08:24 PM. |
It appears to be wired the same as the factory switch. I'll compare the two tomorrow when I get back to the office, but you should be able to wire them the same.
I'll let you know tomorrow.
#8 | |
![]() Join Date: Apr 2009
OK, the Pollak's wiring diagram is basically identical to the OEM.
So, on the Pollak connector: A: Right sending unit (OEM color: Pink/Black) B: To fuel gauge (OEM color: Pink) C: Left sending unit (OEM color: Pink/White) D: Left pump 12V (OEM color: Tan) E: Right pump 12v (OEM color: Gray) F: Empty At the OEM dash switch: C: 12V from relay (OEM color: Tan/Black) Opposite of C: Ground (OEM color: Black) D: Left pump 12v (OEM color: Tan) Opposite of D: Right pump 12v (OEM color: Gray) Note that on terminals "D" and "E" that the wires (12v) will go directly from the switch to the valve. You will also need to tap a wire off of those to run to the pumps. The wires running from the switch have two functions: 1] is to power the pump, and 2] is to power the valve to make it switch to that tank/pump. The OEM schematics for the switch only show terminals marked "C" and "D", and I can't find my drawing of the OEM switch, so just note above where I mention "opposite of xx" means directly across from that one. The ONLY difference between the two drawings is the location of the power and ground on the toggle switch. If you are using the OEM switch, wire it like the above. If you are using the Pollak toggle switch, wire it like their diagram shows.
Never Satisfied
thanks guys for the help. so one more question. what is the difference between the '86 switch and '87, in regards to how it's wired to the switch. other than the obvious fuel pumps.
#11 | |
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
Never Satisfied
Scratch my last thought. So the wire coming from my new fuel pump relay goes straight to the dash switch and then to the switch, got it
