Old 04-30-2010, 01:47 PM   #1
jimmybeus
jimmybeus's Avatar
Broken ear on block for starter?
Hey all, here is my problem. I recently picked up a 350 motor (new rebuild) 4 bolt main,bored 30 over, new cast crank, 202 fuely heads, RV cam and more. The guy I got it from told me that the outside ear piece where the starter bolt threads into the block was broke. He told me it would only be about $75 bucks to fix it. I took his word and drove four hours to pick it up. I got home and started calling around and was told around $300 to fix it if at evenly possible. My question has this ever happened to anyone else and if so what was the best fix. One option I was told was to have a stud welded in the hole and then get a gear reduction starter with a narrower lip for the stud to slide in. Possible or bad idea? Any and all help is appreciated. Thanks in advance.
jimmybeus is offline   Reply With Quote
Old 04-30-2010, 02:34 PM   #2
Togart
Togart's Avatar
Re: Broken ear on block for starter?
I had this happen to me with a 400...I never came up with a solution at the time and ended up swapping in a different motor. However, I did learn later that the early small blocks (like 55-?) had the starters mounted on a "plate":
http://www.classicchevy.com/product....8&dept_id=1315
Not sure if that would work or not...I have always wondered if that would have fixed it for me. Maybe someone else on the board has experience with these?
Togart
Togart
'66 GMC 1500
'77 C-10 Scottsdale Big 10
Togart is offline   Reply With Quote
Old 04-30-2010, 02:44 PM   #3
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
i have a 350 sitting in my truck with the same issue. If the bolts break ur fine if the ear breaks.... SCREWED
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 04-30-2010, 03:38 PM   #4
jimmybeus
jimmybeus's Avatar
Well I talked to a trusted machine shop. He was up front and told me that there was a 75% chance he could fix it. 3-4 hrs labor and probably a pound of nickel rod. Then drill and tap the threads. He'll know more when I get it to him. At least he is up front and honest about it. I'm keeping my fingers crossed. I was hoping it was a more common problem with an easy fix. I should have known with my luck there is no such thing.
Old 04-30-2010, 04:17 PM   #5
JMac11
JMac11's Avatar
Which part broke, most blocks are machined for 3 starter bolts, I am assuming the outside hole at the rear of the block?? Some bolt straight across the back, some bolt at about 45% from the flywheel. I think I have a starter with a cast iron nose on it that bolts at a 45, I always used them on my race cars.
JMac11 is offline   Reply With Quote
Old 04-30-2010, 05:53 PM   #6
ron350
ron350's Avatar
jimmybeus
Please post a close up picture of the broken corner.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 05-01-2010, 07:14 PM   #7
str8axle55
The early 265 blocks had no starter provisions. The started bolted to the bellhsg. If you are running a stick, you could maybe use an early bellhsg, and starter set up. The 235 6 cyl, didn`t share the ame bolt pattern as the V-8s. I also think this bellhsg was used in the trucks, not sure what years, I may have 1 or 2.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 05-14-2010, 10:51 PM   #8
jimmybeus
jimmybeus's Avatar
Well I just got back from taking it to the machine shop. They did an awesome job on it. It looks like it came from the factory that way. It took half a pound of nickel rod and 3 hrs labor but it only cost $200. I told the owner of the shop it looked professionally done, he turned to me and said "It should, that's what we do". I am really happy with the end product. I will get the before and after pics up when I get them downloaded.
Old 05-15-2010, 09:20 PM   #9
Togart
Togart's Avatar
Sweet...Congrats!! Wish I would've known that could be done back when I had that 400!
Togart
'66 GMC 1500
