Old 05-13-2010, 10:23 PM   #1
99 to Life
99 to Life's Avatar
Gauge Cluster questions
I am just learning about all this wiring biz. I got some
clusters for a 51' chevy truck gas,temp,volts,oil
I am running a 12v set up with a 350 engine
When I look at buying replacement parts, they have ones
for 6v and 12v, so that led me to believe, I can't just wire
up my gas gauge to a 92' s-10 gas sending unit right?
Same goes for my heater switch and headlights, say I have
original switches, what would I have to do to run them on
my current setup?
I want to keep everything looking original but functioning with
more modern stuff. thanks
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-14-2010, 02:17 PM   #2
mylow53
mylow53's Avatar
Re: Gauge Cluster questions
6 volt switches seem to work I'm running my original headlight switch...the gas sending unit needs to match the correct ohm setting the gauge needs and also must be 12 volts. the temp gauge probably wont work either. the amp. gauge will work but be careful of overloading it they tent to cause fires it the draw is over 30 amps....
good luck
wheres the build pictures!!!
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 05-14-2010, 04:25 PM   #3
99 to Life
99 to Life's Avatar
thanks for the input
click on my link for the build link below, I got 3 pages right now.
Old 05-14-2010, 05:38 PM   #4
OrrieG
OrrieG's Avatar
There is a tech article at stovebolts.com on what is required to convert 6 to 12 v.
Old 05-16-2010, 10:50 PM   #5
sweet70beast
sweet70beast's Avatar
For the head light switch I would run a relay because the newer headlights might pull more juice than the stock switch could probably handle.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 05-17-2010, 07:46 AM   #6
Dan Bowles
AD Addict
6V wiring can handle more because it is thicker wire. Follow the Stovebolt.com list and you'll be fine. Unless you are running HIDs or something stronger than the standard sealed beams, you don't need a relay.
You'll need all new bulbs and one reducer for the fuel gauge from my recollection to go with a new coil.
Starter and horn will continue to work on 12V but be louder and faster. As long as it is for limited use, they should both last a long time. You might want to look at the heater fan, though.
Dan Bowles is offline   Reply With Quote
Old 05-18-2010, 04:50 PM   #7
mylow53
mylow53's Avatar
that may be true but i'm still running my original 1953 headlight switch with 100k candle halogen headlights. i've had this set up since 1985. mind you i didn't run it 100k miles but it still works... to be safe i could see you running a relay that i wont argue but it is possible to run the original
GT
Greg
Old 05-19-2010, 12:03 AM   #8
sweet70beast
I run the original switch too but I guess i wasn't very clear, I actually meant the HID light and composite housings.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 05-19-2010, 09:39 AM   #9
Kid
Kid's Avatar
I ran halogen lites thru my original head light switch & worked for a while, then one night comming home from a car show, just cruising down the hiway & the lights went out till the circut breaker cooled down (that got my attention!). Just depends on how good of shape your head light switch is in. After my experience, I installed relays, don't want to relive going down the hiway at 70 MPH & loose my head lights again, it was a dark moonless night & couldn't even see the road.
Kid is offline   Reply With Quote
