Old 05-26-2010, 12:49 PM   #1
jimmygee
hooking up a kick down cable
I have a 1964 6 cyl chevy engine with a 1974 350th but I don't have the knowledge how to hook up the kick down cable. Speedway Motors said that they don't have the adapters. Any ideas or pictures would sure help.
Thanks in advance.
Jim from Gig harbor, WA.
jimmygee is offline   Reply With Quote
Old 05-26-2010, 03:53 PM   #2
mr48chev
mr48chev's Avatar
Re: hooking up a kick down cable
You may have to build a bracket and modify the linkage.
The engine in my 48 came out of a 70 something with a turbo 350 on it. I'll try to see if my linkage is different than yours and has something that will work to work the cable.
Good looking motor mounts by the way.
Old 05-26-2010, 04:23 PM   #3
jjjmm56
jjjmm56's Avatar
You may need to use a aftermarket cable. When the throttle is wide open the kickdown should be pulled all the way out.
jjjmm56 is offline   Reply With Quote
Old 05-26-2010, 05:46 PM   #4
jimmygee
Thanks for the replys. I have the cable length to make it work. I guess I just have get a detent bracket and go from there. That's the thing about us Americans we have ingenuity.
Old 05-26-2010, 06:28 PM   #5
raycow
Since the TH350 didn't start until 1969, all the factory installs will have a Monojet instead of the Model B carb like you have. I don't think the linkage is much different between the two carbs though, so look for a donor vehicle in the 69-74 range. The engine changed to an integral manifold around 1975, and I don't know if the linkage on those is the same.
I don't think you are very likely to find an aftermarket cable bracket for the 6 cylinder because of less rodding interest in those engines as compared with the V-8s. However, it couldn't hurt to ask the inline specialty vendors like Patrick's or Langdon's
Ray
raycow is offline   Reply With Quote
Old 05-26-2010, 07:34 PM   #6
jimmygee
I'm on it. Thanks.
